Question about Garden
OIL TYPE WHAT WEIGHT OIL
  • 1,162 Answers
Regular oil such as you use in automobile. Any 30 weight oil is fine.
Posted on Mar 26, 2014
What kind of oil replaced the Harley Davidson type "c" oil fork ina SS Sprint 350cc?
Fork oil is the same as hydraulic pump oil. Depending on your preference choose a light weight oil, 5-15 will give a soft ride. As the weight numbers go up the comfort level goes down. However, the heavier weight oil provides better handling. A bit of experimentation will varying weights should be considered for the optimal combination of ride comfort and handling. One final note. Always. Purchase a non-detergent oil
Nov 21, 2015 | Harley Davidson Fork Oil
What type of oil for yard machine 16.5
30 weight oil only it will say thirty weight on bottle do not use 10 w 30
Sep 02, 2014 | Yard Machines 13AN775S000 500cc 16.5 HP...
Dont know what type of oil to use
Put straight 30 weight motor oil in it. Not 10W30 or any multi-viscosity oil. Straight 30 weight motor oil. If you're doing a complete oil change, then you may want to use Synthetic 30 weight, which will last longer between oil changes and also make your engine last longer (but it costs more too). Best of luck to you.
James
Sep 12, 2011 | Toro Power Lawn Mower
In changing 2005 Harley Heritage Model FLSTCI fork oil, how many ounces of fork oil should I use? What does wet or dry mean?
I'm sorry but I don't have the specs on the quantity and type of fork oil for your year and model bike. I work on the older bikes that the dealers will no longer service. But, I can describe the difference between the "wet" and "dry" conditions of the fork assembly. If you take the front forks apart, clean them out, and put them back together with no oil in them, they are considered "dry". For a simple drain and refill type oil change on them where you don't get all the oil out of them, they are considered "wet". I hope this helps, You can call you local dealer's service department and they should tell you the quantity and viscosity of the oil that goes in the front forks on your machine. They'll tell you something like 6 ounces of "Type E" oil, for example. Harley-Davidson uses these types of specs to describe their oils. If you go to a website for fork oil, like PJ1, they may give a cross reference or equivalency chart for converting H-D "Type E" to their oil. I think that would be their 30 weight oil. If the front end seems too "stiff" with 30 weight, you can drop down to 20 weight. I think Honda makes a 25 weight but not sure. Your Harley won't mind the Honda oil. BG.
Good Luck
Steve
Aug 23, 2011 | 2005 Harley Davidson FLSTC - FLSTCI...
For the Skil 77 worm drive circular saws what type of oil is required?
Use 90 weight gear/differential oil but if you use it outside in the cold weather it's too thick, use 40 weight oil then and switch to the 90 weight in the summer.
Jun 03, 2010 | Saws
What type oil. the weight
For 1994 Ford Taurus 3.0L EFI 6cyl the Engine Oil Type and Weight is:
4.5
Application:
Oil for use in all temperature ranges
Quarts with filter change
VV174
Application:
Valvoline Premium Conventional 5W-20 Motor Oil
Hope thos help (remember rated and comment this) Good luck.
Mar 29, 2010 | 1994 Ford Taurus
My forks just dont have enough resistance.
This is an old thread but just in case you haven't gotten the problem fixed, you need to change the fork oil in your forks. The main reason is to make sure you've got the correct amount in them.
If after changing the oil they're still too spongy, you need to change the oil to a heavier weight oil. Use 30 weight "FORK OIL". Do not use any other type of oil as it may foam. Use fork oil only and in the correct amount. Your owner's manual should tell you how much oil to add.
To drain the oil, there is a plug down near the axle on each fork slider. At the top triple trees, there is a large cap on each fork tube. Take this out and add the proper amount of the proper weight oil. Only do one tube at a time. You may have to get the weight of the bike off the front end.
Apr 02, 2009 | 2000 Harley Davidson FXSTD Softail Duece
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
