Question about EdgeStar ES TWR325ESS-32 Bottle Dual Zone Wine Cooler with Stainless
Edgestar wine cooler blowing fuse on the left side circuit board
Changed both circuit board fuses ...the left side fuse blew immediately I plugged the unit back in.
    New Friend:
    Problem Solver:
  • 13 Answers
If you have replaced the circuit boards it's probably associated with a wiring short circuit or compressor failure. Suggest you get a professional technician to further investigate the fault. In the interim check for a short to the frame of the unit, an internal light or for moisture issues or a condensation issue from water.
Posted on Apr 29, 2014
Just plugged in wine cooler, it sparked and gave off smoke. Is it safe to put in a new fuse. Or should I dispose of it?
another fuse will not hurt but no doubt if it blew one it will only blow the replacement unless you find the short first
Aug 22, 2015 | Furniture
Just purchased and is not cooling at all
please see this steps and fix it. God bless you
1. Unit not running
Possible Causes Response a. Power cord unplugged
b. No power at all
c. If display lighting, temp setting high
d. If temp setting ok, sensors or control board bad
e. Compressor unit malfunctioning a. Check for power cord plug
b. Check receptacle voltage & fuses
c. Lower temperature setting
d. Call service for replacing sensors or control board
e. Call service for component check
Nov 27, 2013 | EdgeStar CWR361FD - 36 Bottle Built-In...
Goodman furnace GMT115-5B Turn fan to on on
Bypass the tstat first but that's where I'd be leaning.
Aug 14, 2017 | Goodman GMS90703BXA Heater
Edgestar wine cooler eh error code
You can download the owner's manual at: http://www.edgestar.com/TWR215ESS-EdgeStar-21-Bottle-Dual-Zone-Wine-Cooler/TWR215ESS,default,pd.html?cgid=Wine_and_Beverage-Wine_Refrigerators
Apr 10, 2013 | EdgeStar TWR181ES
Wine cooler not working - checked all fuses and found the fuse on the circuit board had blown.Changed that fuse- reconnected and the fuse blew straight away what do I do next?
If the fuse blew immediately..then there is a hard short somewhere in the circuit...if you have an ohmmeter you will need to check the compressor, fan , and whatever type of controller for a short circuit
May 09, 2011 | Refrigerators
6 bottle unit model cwc-600 died after 6 months. Acts like it isn't plugged in or a blown fuse. But no fuse!
The fuse is on the circuit board, behind the rear cover. It's a 2.5 ampere metric fuse. These boards are very voltage spike sensitive, and chances are you need a new board, as the rectifier diodes in the switching power supply blow and short out easily. If you get a new board, use a voltage spike power strip to protect it.
Nov 02, 2010 | Cuisinart Private Reserve CWC-600 Wine...
Avanti EWC16B (wine cooler) got fried by power surge
A lot of time during storms the control boards in appliances get messed up. Try unplugging it and plugging it back in after about 20 seconds. A lot of times that will reset the controls.....if they did not get fried.
Sep 12, 2009 | Refrigerators
Edgestar Dual Wine Cooler
Well... it is tough to get wine to spoil.
Keep it out of the sunlight and don't get it really warm
(after all... is just grapes that have already spoiled...
I'm just saying).
I bought the VERY EXPENSIVE Kitchen-Aid
48 bottle... took the 5 years & about another month
for the evaporator FAN to rub a hole in the evaporator aluminum return line (made in USA (opinion: junk)).
KITCHEN-AID never even returned a call or e-mail.
Handling circuit boards: You MUST WEAR anti-static
wrist straps when handling them... ELSE you could be popping those semi-conductors like POPCORN.
The only other REPUTABLE source of information I have ever found on EDGESTAR (very helpful) were the folks at
Compact Appliance.
https://www.compactappliance.com/edgestar-wine-coolers/
ESD wrist-strap
Amazon com Rosewill ESD Anti Static Wrist Strap Components RTK 002 Black...
Mar 13, 2017 | Refrigerators
Fans not working
I had the same problem as other bloggers--temp would not decrease and fan did not run. . . as suggested by others, I replaced the 5A heat-shrink wrapped fuse in upper left corner of circuit board (fuse is covered in black heat shrink wrap and is in a U-shape). I unsoldered the two ends of the fuse on the circuit board (be sure you locate the correct two holes) and then replaced it with two parts from Radio Shack--a 5x20mm Inline Fuse Holder rated at 250V AC, 5A (part # 270-1238) and used a 6.3A slow-blow 250V fuse (part # 270-1066). Now the wine Refir works great!
To replace the part take all the screws off the sheet metal covering on the back of the refrigerator. Remove the circuit board from the plastic holder. I left all the wires plugged in and just unsoldered the fuse with the circuit board still connected--but to solder you will need an extra pair of hands to hold the board while you solder.
If you don't have it, get some silver solder while at Radio Shack and a thin, needle-point soldering iron tip. Radio shack has 30W soldering irons for less than $10. You really don't need soldering experience--just a steady hand. Even if you have none of these parts your total outlay at RadioShack is less than $25 for everything.
Apr 14, 2008 | Oster 12-Bottle Wine Cellar - Black
HAier HVT12ABS wont turn on
I had the same problem. My 18-month old Haier HVT 12A wine cooler stopped working. I unplugged the unit, opened the back, and saw the circuit board and the two fuses soldered to the circuit board. The top fuse was OK. The bottom fuse, labelled FUSE2 5A/250V on the circuit board, was blown.
I went to Radio Shack and purchased a spring-loaded push and twist fuse holder ($3) and a bag of fuses (another $3). I soldered the leads from the fuse holder to the top and bottom of the dead fuse 2, inserted a new fuse, plugged it in, and it has been working fine ever since (1 month). If the new fuse fails, it is easy to replace. Total cost $6.
Oct 10, 2007 | Haier HVT12ABS Compact Wine Cooler
EdgeStar ES TWR325ESS-32 Bottle Dual Zone Wine Cooler with Stainless Logo
462 people viewed this question
Top EdgeStar Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an EdgeStar Furniture Expert? Answer questions, earn points and help others
