Question about Kitchen Appliances - Others
Need switches very old machine with missing switches. numbers on switches:VDE 0660 IEC947-5-1 3 SB 14 00-OB
How to fix a errow ob on maytag washing machine
OB is an out of balance load error, try re-distributing the clothing and see if it helps, also make sure the machine is level, if this doesn't help there may be a fault with the out of balance switch or lever.
Mar 06, 2012 | Maytag Neptune FAV6800AW Top Load Washer
Machine is about 7 years old and gets stuck in one cycle, will not drain. Recieved code CA, LD and OB. Machine is stuck and won't drain!
The OB indicates and out of balance condition has been detected by the motor control.
One thing about the OB error is that the lid must be opened to clear the error and allow the washer to advance to the next part of the cycle. If the lid is not opened to adjust the clothes then the OB error will happen again.
If the OB error was cleared and the OB occurs with an empty load then the motor control has failed.
The drain pump must work. The image below shows how to run a diagnostic test to check the drain pump. Follow the instructions in the image below and check the drain pump operation. If the pump runs and the water does not drain then the sump is clogged. If the pump hums but does not run then the pump needs to be replaced.
http://media.fotki.com/1_p,wkktswgwqtqrbwfxgtqsskgwtqkq,vi/gftrgbbtfxfffgqskfk/1/1303472/5961857/image48348img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 11, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
I have an error message that reads ob. I have an
OB MEANS OFF BALANCE if the motor controller detects an unrecoverable off-blance condition, the machine controller will shut down and display ob. the lid switch must be opened at least once before restarting the cycle if this condition occurs. opening the lid will allow you to view and redistribute the load. press stop/cancel to clear the display. hope this helps.
Oct 27, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Error SB SIG MISS on FURUNO CRT radar?
Either your reed switch is bad or your antenna is not rotating. You may hear the motor spinning but that does not mean the array is. If the array is not spinning make sure the belt did not come off the motor. Start there.
Jul 05, 2009 | Furuno 1715 LCD Radar System GPS Receiver
Autorization code of photo shop Cs2
You need to contact Adobe.com customer support.
Mar 16, 2009 | Adobe Photoshop CS for PC
Need authorization code for Photoshop cs 2
here the Auth code for ur serial
2432 6368 2444 2935 9169
rank my solution..
Jan 02, 2009 | Adobe Photoshop CS2 for PC
LD and OB on Calypso
“Ld” flashes if it takes longer than 5 minutes to pump out water to a point where the operating
pressure switch resets.
Press STOP/CANCEL to clear the display.
OB:
If the motor controller detects an unrecoverable off-balance condition, the machine controller
will shut down and display an “ob” for off balance.
The lid switch must be opened at least once before restarting the cycle, if this condition
occurs. Opening the lid will allow the customer to view and redistribute the load.
Basically, it sounds like your drain pump is bad or clogged, and the extra water is throwing the spin cycle off balance
-Perry
800-Appliance San Diego
Dec 16, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Burnt part. no pic. no sound
You can get them online at http://www.partstore.com . they run about 55.00 each part
Nov 23, 2008 | RCA HD56W58 56" TV
Whirlpool Calypso ''ob'' problem
ob Off Balance If the motor controller detects an unrecoverable off-balance condition, the machine controller will shut down and display an ob for Off Balance The lid switch must be opened at least once before restarting the cycle, if this condition occurs. Opening the lid will allow the customer to view and redistribute the load.
if this does not fix the issue it is most likely the strut and shock system that is falty on the machine. you could replace them yourself but they are fairly expensive
Nov 12, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Can't activate Soundblaster LIVE 5.1 audio card on msi k8mm-v
Locate the file from your other machine and copy it over. it will most likely not be the only missing file.
Windows device manager will almost never find a suitable driver on the web and you may need to locate it yourself from the installation cd.
May 02, 2008 | MSI K8MM-V Motherboard
Kitchen Appliances - Others Logo
64 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
