Question about Frigidaire Dishwashers
The hi temp wash and air dry lights are blinking on my firgidaire dishwasher
Ffbd1821mw
  • Official Brand Answer
  • 2,267 Answers
Hi Dan, this is AP!
I understand you are experiencing some trouble with the lights on your Frigidaire dishwasher. On your particular model, FFBD1821MW, if there has been a power failure, then the "Hi-Temp Wash" and "Heat Dry" LEDs will flash. In order to stop the LED lights from flashing press Start/Cancel. This process should relieve your concern regarding the LED lights flashing. I hope this information proves helpful to some degree.
Best of luck,
Posted on Apr 03, 2014
  • 1122 Answers
SOURCE: Status Lights Blinking
status lights blinking is trying to tell you something in the dishwasher is bad,go to your owners manual to see the fault codes first,then you can try turning the breaker off 30 seconds an on to see if it resets its self,if that does not work i think you might have a bad mother board,thanks-mike
Posted on May 28, 2008
  • 4 Answers
SOURCE: Dishwasher lights blinking
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
Posted on Jul 01, 2008
SOURCE: Kenmore Ultra Wash Quiet Guard 3 problem
Thanks Munkee,
I started having this problem, blinking green light,  three days ago with my Kenmore QG3 and finally was tired of not being able to use my dishwasher. I've had it for three years with no problems until 3 days ago. You solution, use of commands, really helped and no money wasted on tech assistance. Thanks again!!
Posted on Oct 10, 2008
SOURCE: Kenmore 665 dishwasher blinking clean light
you'll need to enter a diagnostic mode, press in this order, hi-temp(sani-rinse)----heated dry--hitemp---heated dry... all lights should light, close door and let cycle for about a min, after press the cancelbutton, you should be good to go, the buttons on your model may read slighty different names, if this "toggle of buttons" does not work, you can remove thelower access panel and htere willl be a tech sheet/trouble shoooter behind the panel, in there it will explain how to enter diag/test mode
Posted on Jul 02, 2009
  • 127 Answers
SOURCE: kenmore dishwasher ultra was quiet guard 3 model
that would be model # 66516012403 correct??
you may have inadvertently set the lock on function..
check this out from your manual...
Lock On
Use the Lock On to prevent unintended use of the dishwasher
between cycles. You can also use the lock feature to prevent
unintended cycle or option changes during a cycle.
When LOCK ON is lit, all buttons are disabled.
NOTE: The dishwasher door can be opened while the controls
are locked. However, the lock must be turned off and the Start/
Resume button pressed to resume the cycle.
To turn on the Lock
Press and hold HEATED DRY for 4 seconds. LOCK ON glows.
If you press any pad while your dishwasher is locked, the light
flashes 3 times.
NOTE: If the Heated Dry option is selected, the light will
temporarily turn off until Lock On glows.
To turn off the Lock
Press and hold HEATED DRY for 4 seconds. The light turns off.
hope this helps,
best of luck,
ttfn
Posted on Oct 25, 2009
Why is heated dry blinking?
FIXED Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry ...
www.applianceblog.com/.../40588-Kenmore-dishwasher-lights-flashing-...
Aug 26, 2013 - 10 posts - ‎3 authors
Thread: Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry" ... A few months ago, we had a brief power outage and the next morning, noticed the "Hi Temp" and "Heat Dry" lights were flashing. ... Well since then, the dishwasher intermittently stops mid-cycle and these same lights ... Thread: GE Eterna QuietPower 2 Normal and Heated Dry ...
Feb 24, 2012
Kenmore Elist 665 dishwasher Smart Wash red light ...
Dec 23, 2011
Heated dry blinking +17 times - ApplianceBlog
Nov 14, 2010
Heated Dry light blinking
Nov 7, 2010
More results from www.applianceblog.com
Why won't my dishwasher start and why does the "Heated Dry"
www.shopyourway.com > Manage My Life > Questions
Nov 16, 2009 - When I hold down the Heated Dry button to turn the control lock on it ...my dishwasher start and why does the "Heated Dry" light keep blinking ...
Dec 01, 2015 | Dishwashers
How to reset Kenmore Elite 665-16572202 Dishwasher...clean light blinks 7 times pauses then repeats. My model does not have a Heated Dry button it has an Air Dry button.
Here's the key sequence(s) to use, depending on how your keys are labeled:
Heated Dry - Normal - Heated Dry - Normal; or
High Temp - Air Dry - High Temp - Air Dry; or
Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or
High Temp Wash, Heated Dry, High Temp Wash, Heated Dry.
This will start the diagnostic cycle. Let the dishwasher run for a few minutes, and then press Cancel to stop the dioagnostic cycle and clear the error. Please note, that this clears the error, but if you haven't found the cause (water-not-heating error), the condition will come right back the next time you run the dishwasher.
Jan 19, 2015 | Kenmore Dishwashers
My KUDS011JBSO undercounter dishwasher is blinking the normal wash light. What do I need to look for to fix this?
Hi
If light is blinking then it may be an issue with heater circuit, door switch or the thermal fuse, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry or High Temp Wash-Heated Dry-High Temp Wash-Heated Dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the thermal fuse located on the control or the door switch that is bad and should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 31, 2011 | KitchenAid Dishwashers
I have a whirlpool gold quiet partner III Black dishwasher. All of a sudden it stopped working. I push the accusense button and start the cycle for washing, it looks like everything is working normally, I...
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry or High Temp Wash-Heated Dry-High Temp Wash-Heated Dry . Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 30, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Timer will not advance, stuck on "Clean" blinking light, will not do anything else
Your control has detected an issue with the heater circuit. You may be able to reset it by performing the following "button dance." Press the buttons in order within 5 seconds to reset the control.
Hi Temp Wash Air Dry Hi Temp Wash Air Dry
You may have Energy Saver Dry, but it is the same thing. If it does the blinking clean light again, look closely at the heater for burn marks or breakage.
Kelly
May 25, 2011 | Dishwashers
My clean light is blinking and it will not start
Push in this order within 5 seconds...
Sani Rinse Air Dry Sani Rinse Air Dry....if you dont have those buttons, substitute:
Hi Temp Wash Heated Dry Hi Temp Wash Heated Dry
Let it go through the diagnostics cycle, about 10 minutes. Push Cancel/Drain. If it occurs again, you have something wrong with the heater circuit. Check the heating element for breaks.
Jan 13, 2011 | Kenmore Dishwashers
Blinking clean light, will drain with cancel button,wont wash
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
May 26, 2010 | Kenmore 13853 Stainless Steel Dishwasher
Next Step
This machine was made by Whirlpool and the flashing clean light is a common error code for them.
If the clean light is the one flashing then your dishwasher could have a heater circuit problem (depending on the age) or this could simply just be water colder than it is used to getting.
Repeatedly press the Heated Dry and Hi-Temp Wash(scrub) which ever yours has untill all the LED lights come on, press cancel twice and try the dishwasher again making sure to run the water at the kitchen sink till it is hot before starting the dishwasher, if this trips and locks you have a problem with the heating element, or temp sensor.
Press the heated dry button followed by the normal cycle button, and then repeat once. You should see all of the lights come on for a second or two, and then the dishwasher will work again.
If you haven't already, take a look under the kick plate in front to see if there is a schematic tucked in there somewhere. Whirlpool has put their diagnostics for specific models on these.
I don't have the specific repair manual for you model.
So, if the above combination does not work here are two more that have worked for me.
HiTemp Wash + Air Dry + HiTemp Wash + Air Dry in less than 5 sec
or
Hi Temp Scrub/Scour + Air Dry + Hi Temp Scrub/Scour + Air Dry in less than 5 sec
Let me know, if you need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 08, 2010 | Whirlpool DU1055XTSQ Built-in Dishwasher
Blinking Clean Light
  • Close dishwasher door
  • press "Hi-Temp Wash"
  • press "Energy Saver Dry"
run the 'normal' cycle without the hi temp feature
Nov 16, 2008 | KitchenAid 24 in. KUDI01FL - Multiple...
Clean light keeps blinking and I can't start a new cycle
Puppa, clear the fault by pressing the keys in this order: high temp scrb--air dry--high temp scrub--air dry. Or, depending on your model..Sani rinse--air dry--sani rinse--air dry. The dishwasher will enter the service mode. Let it do it's thing or advance it through it by pressing the start key. The fault came from the board not sensing a rise in the water temp. Make sure to run the hot water before starting the dishwasher. The heating element runs through the nuetral side of the door switch so make sure the d/w is level and the door switches are all making. The element itself could be at fault. Catriver...post back
Apr 01, 2007 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwashers Logo
650 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
