Question about Crosley caw9444xq 3.4 cubic foot top load washer
Top Cover Part
I need to replace plastic cover and no one have giving help where to find a new one. Need price and availability to by please help me. Contact marinly12@yahoo.com with info requested.
  • 400 Answers
You might check http://www.appliancepartspros.com/ or Sears parts (on-line or your Sears store. There are probably appliance parts stores in your town who might help as well. I hope you find your part.
Posted on Mar 25, 2014
I NEED A SPOOL COVER WHERE CAN I GET IT ?
How to make a spool cap cover for an American Gardener YS24 (Weedeater XLT24) Trimmer
If you've tried to buy parts lately for your trimmer, you've noticed they are harder and harder to find. In fact, I was unable to find a spool cap cover, so I came up with this work-around.
Before you start this project, it's important to save any parts from the old spool cover-especially the top, if you can. The top is needed to make a spacer for the new cover that will still allow you to "bump" out the string.
I used a Craftsman 71-64215 replacement spool retainer to make my new spool cover cap. It fits the Craftsman C3 19.2 volt 74381 String Trimmer (CRAC06540 spool cap). I found this cap at a local Ace Hardware, but apparently it is also getting hard to find-I googled the Ace Hardware number to find it on the web-"7314644 cap." I bought a couple extra from HardwareDistributors.com. Note that the diameter of the cover at the tabs is the same diameter of the old cover-although the diameter of the cap is slightly larger.
Take the old cover, and using the tab from the old cover, mark a line on the new tabs the same width as the old. Make sure you center the old tab on the new tab so you will remove the same amount of plastic from each side of the new tab. I used a dremel tool with the cutoff wheels to cut the tabs on the new cap to the same size as the old cap.
If you look at the new cap, there is a round plastic circle ridge on the bottom of the cap. If you look closely you can see a slight indention, or discoloration on the top of the new cap matching the circle on the bottom. You need to cut the plastic out of the new cap matching the plastic circle. I used a dremel tool with a metal cylindrical grinder to do that.
Once you get everything cut, put the old cap into the new cap so that the spokes face down toward the similar spokes on the top of the spool. You may have to trim the old cap so it fits into the new cap.
Finally, snap everything together into your trimmer-don't forget the spring. Note that the new cap has about a 1/8 inch gap above the spool. However, this doesn't seem to affect the trimmer-and you can still "bump" the head to eject the string.
Apr 27, 2015 | American Gardener Get the lower price on...
Looking to replace a broken glass covertop for a Magnetic Induction hob
I looked up your cooktop and discovered it to be made by Frigidaire.
Hence & therefore, try the website "searspartsdirect" and see of they will give you schematics to buy the parts for your needs.
God bless your efforts.
Mar 06, 2018 | Sunpentown Cooktops
Try to replace spug pluks but i dont know how to remove the cover , please i need help thank you.....
REMOVE TOP ENGINE COVER,REMOVE THE TTHREE TOP PLASTIC PLUGS ON TOP OF COVER WITH SMALL SCREW DRIVER TO ACCESS THREE SCREWS RETAINING THE ENGINE COVER.
Jul 27, 2011 | Volkswagen GTI Cars & Trucks
Hi there, I have a fisher price train set number on bottom of the engine is H5698. My grandchildren love this toy, but we find that the engine, although still playing the music and sound, will no loger...
the train carrage uses 4 clip points two at the front and two at the back using a sharp point knife insert and clip the cover off either a wire has come off the motor or the small 3mm motor has burned out if so replace it
need more help email me
best of luck to you good to see kids playing with trains instead of play stations and x box well done.
Nov 27, 2010 | Fisher Price Fisher-Price L8341 Digital...
All keys on laptop faulty. Cannot write one sentence without letters missing, including space-bar
Either the cable connecting the keyboard to the laptop's motherboard has come loose, or the keyboard itself is bad.
You don't give a brand or model so I can't be too specific, but it's usually not difficult to remove a laptop keyboard. On most models you need to remove the plastic hinge covers and trim strip along the top edge. Often these are one molded piece, but on some computers the hinge covers are separate pieces. Look for small screws that may hold the cover down on the back edge or possibly through from the bottom. After removing any screws, the plastic pieces snap off. Be careful not to break the strip or hold-down tabs. Just work slowly and carefully.
With the trim strip off you can see the top edge of the keyboard. On some computers there are 3 or 4 screws holding the keyboard down. Other models have screws that go through from the bottom, and these are often labeled with a K.
Once the keyboard is free, lift it carefully by the top edge and tip it toward you. You'll be able to see the cable that connects to the main board. Make sure it's firmly seated in its connector. Set the keyboard back into place (you don't need to worry about putting all the hardware back yet) and see if the trouble continues. If it's back to normal, put all the screws back in, snap the covers back on and you've fixed your laptop. Otherwise, check online (eBay's a good place) for a replacement keyboard. They are widely available now for most models, and the prices are usually reasonable. Plug the cable from the new keyboard into the motherboard connector and replaces all the other stuff.
It is possible, but not common, that the keyboard controller on the motherboard itself is bad. If that's the case, the only fix is to change the board. That's a job best left for a professional. Replacement boards are available, but can be costly, so if the board is the trouble it may be time to consider replacing the computer. But the keyboard is normally the culprit.
Good luck, and thanks for using Fixya. If this has helped you, please take a moment to give a thoughtful rating.
Oct 22, 2010 | Computers & Internet
How do i replace a valve cover gasket? How do i take the screws off the valve cover gasket? Do i need a special tool? I just ordered a new valve cover gasket and i need to know how to replace it..please...
First take the plastic cover and carefully loss out the bolts and take every one of them and replace the new gasket and place the bolts back , it is as easy 1234
Aug 24, 2010 | 2002 Volkswagen Passat
I need the plastice marker light cover for my 2005 S80 Volvo.
The best place to get this part is from an auto recycling center ( i.e. junkyard). Get the Yellow Pages and look up
Automobile Parts & Supplies Used & Rebuilt for local parts. You can even use www.yellowpages.com for help. Call several places for prices. If no one has it, they can usually get it from another place for you.
Of course you can pay full price for a new item.
Jun 24, 2009 | 1996 Volvo 960
Looking for Metal blade in Black and Decker -BL12475G
If it is 2 yrs old,Just call the customer service,they will give you the parts for blender for lesser price or else go for new one.
Apr 27, 2008 | Blenders
Crosley caw9444xq 3.4 cubic foot top load washer Logo
21 people viewed this question
Top Crosley Washing Machines Experts
Charles T Nevin
Charles T Nevin
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
