Question about Systemax Venture C11R PC Desktop
No usb ports recognized
Neither front or rear usb ports are recognized
  • 400 Answers
If I understand your problem correctly, I would go to device manager... and see if there are any RED Xs or YELLOW exclamation marks under "universal serial bus controllers". If so, or maybe even anyway, update the device driver. I hope this helps you with your problem.
Posted on Mar 25, 2014
  • Systemax Master
  • 27,725 Answers
W 7
First, please disconnect all USB devices and then perform the following steps: Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for XP or earlier
Click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
if you need more help with this or if i have missed the problem post a reply
Set-up won't recognize that the USB cable is connected to both printer and computer and therefore printer won't work. What's up with that??
1. Confirm the USB port on the computer you are connecting your printer to is being recognized by your computer. The easiest way to do this would be to plug a known good USB Memory stick into the USB port you want to use. If you can read the contents of the USB Memory stick then the port should work. Remove the Memory stick, start the printer installation program (Make sure you don't the printer connected), want until the setup program tells you to connect the printer before you attach the Printer's USB cable.
If the printer isn't recognized try a different USB port, when picking a new USB port to try select a higher priority port, for example in increasing priority from, an external USB hub, a powered external hub, a monitor based hub, USB ports on the front of the computer, up to the USB ports at the computer rear. For USB ports on the same circuit select an USB 2.0 before an USB 3.0 port
Aug 04, 2015 | HP OFFICEJET PRO 6830 E-ALL-IN-ONE PRINTER
My computer link software is not recognizing my calculator
You need to make sure you are using a USB 2.0 port. Also, many laptops tend not to recognize the calculator due to a lack of sufficient power. I have also noticed that in desktop computers, the calculator will work in the rear USB ports but not the front, or vice versa.
Jan 24, 2011 | Texas Instruments TI-Nspire Graphic...
HP Pavilion zv6000: USB ports are inop. USB port on rear of computer works fine. USB port on left/front will power my flash drive, but the light stays on constantly. The flash drive is does NOT show up in...
After reading the description, I think you need to try updating BIOS and latest device drivers for USB. Because USB are getting power on that means there would not be any fault to from the motherboard.
So please try updating latest BIOS for your notebook.
If you can provide me the product no for your notebook and the operating system which you are using currently then I can find the one for you.
Otherwise you can also do the same.
Type in the product no. on www.hp.com. Then go to software and driver download page, select the proper OS and search in BIOS ROM pack available for your notebook.
I hope this will help.
Jun 11, 2010 | HP Pavillion ZV6000 Notebook
I am having a problem with my computer (e-machines T5082). I does not recognize any devices plugged into the USB ports. Printer, cameras, Zune, ect. They have power because my speakers draw power from a...
Greetings....
Please try to check if your USB port both rear and front USB port are not defective. Most common problem of defective usb ports are when plug your usb devices it won't recognize the device you inserted. So to make sure that your USB Ports are not the main cause why your computer won't recognize devices you inserted.
Nov 03, 2009 | E-Machines T5082 PC Desktop
All USB ports on my emachines T6542 do not work
try to see the BIOS SET UP if the USB port are in enbled status..
if its not,, enabled them...
and see the connection of the USB port into your motherboard if it connect properly..
Oct 27, 2009 | E-Machines eMachines Desktop PC
Computer does not recognize it
assuming your using a windows xp or 2000 os, try another cable if you have one..turn the gps off, plug in the usb cord and restart the gps. if that fails, if the cable is connected to a port on the front of the computer,move the usb cable to a rear port on the computer and try the previous way i just explained.
if those fail, disconnect all usb devises connected to the pc and restart the computer and try again. (always use a rear port on the pc if you can)
good luck
Aug 03, 2009 | Magellan Maestro 4040 GPS Receiver
Gateway gt4010 usb ports are all failing.
It's your hard drive going bad! I had the same problem in my company. Could not figure it out but when i flopped the hard drives they started working agian.
Mar 26, 2009 | Gateway GT4010 (RBGT4010) PC Desktop
Usb not recognized on sansa e280 (sandisk)
Unfortunately, so simple - although this simple solution does not appear in any manual. the solution: put your Sansa in the rear USB - and the PC immediately recognizes the MP3 or MP4. The USB soccket in the front of the PC does not have enogh power, and when using the rear USB port - it works!
Izi
izimann@lycos.com
Apr 04, 2008 | Audio Players & Recorders
Front Side USN dows not work in ASUS M2N MX SE
The front side port may be a "low power" USB port, it may be possible to "power" this if there is the capacity to connect a power cable to the front panel USB adapter, or there may be an aux power socket to plug into on the motherboard.
Nov 04, 2007 | ASUS M2N-MX Motherboard
Front side USB port is not working
On some computers the front usb ports are like a usb hub, they don't have enough power to power up a hard drive.
Systemax Venture C11R PC Desktop Logo
54 people viewed this question
Top Systemax Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Abhinandan  Patil
Abhinandan Patil
Mike
Are you a Systemax Computer and Internet Expert? Answer questions, earn points and help others
