Question about Lennox 7 Series MS7-HO-18P MS7-HI-18P Heat Pump Wall Mounted Mini Split Sy
Lennox elite heat pump throws cold air
Throws cold air and need to see filter placement on inside unit
  • Lennox Master
  • 1,253 Answers
The unit should give you an error code if something is wrong.
Here's the manual:
http://instalacionesindustriales.com.gt/pdf/Lennox_Minisplit_HE.pdf
Posted on Mar 31, 2014
I have a mr slim r410a air conditioner. I keep up with filter changes but I still get an inordinate amount of dust all over my house. Anyone know what the problem might be?
Does your air condition have switch or some kind slider that has inside air or outside air on the unit, cause if its on outside air intake then that's why you have dust coming thru your air con and throwing dust cool air around your unit or house, switch it back to inside air to forever keep out that dust....!!!!! Thank You
I’m happy to help further over the phone at https://www.6ya.com/expert/humphrey_5ffe09540b653dd0
Aug 13, 2015 | Filter Heating & Cooling
Air filter placement
i am looking at your picture of a condensor unit no filters. clean annually
Jun 10, 2014 | Amana GSC130301 Air Conditioner 13 SEER...
My intertherm ac unit is freezing up outside ,why? are there any recalls on these units
Few things cause this. Poor or no airflow inside the furnace, dirty filters, poor filter placement that will cause your indoor cooling coil to plug with dirt, or low freon pressure.
Jul 26, 2011 | Intertherm P3RA-048K Air Conditioner
Where can I find a manual for my coleman cam II central air conditioner for a mobile home? I recently purchased the mobile home and would like to know what steps to ntake to make it work at its best. ...
Check the website for Coleman/Intertherm for a manual, you will need the model and serial numbers of the unit. The filters for these typically sit on top of the unit, some come with frames, some lay directly on the coil. If you can't find a manual on the website or by contacting the company, check the yellow pages some towns have a mobile home supply house that would be able to help.
Aug 30, 2010 | Coleman Heating & Cooling
MY AIR CONDITIONER IS NO LONGER PRODUCING WATER FROM THE BACK
Check to make sure the filter is clean. If not, remove it, wash it and start it back up.
The water that you have seen comes from the machine cooling the air, the air conditioner literally squeezes the water out of the air. If it's not blowing cold ... no water.
If cleaning the filter doesn't work, you will probably have to have the unit looked at by a professional.
Jul 22, 2010 | Daewoo DWC-084R Air Conditioner
Air conditioner not blowing cold air & dispenser for water not recieving
UNIT NEEDS CHARGING WITH FREON AND CHECK TO MAKE
SURE THERMOSTAT IS ON AUTO AND COOL...CHECK OUTDOOR UNIT WITH POWER OFF FOR BAD CAPACITOR, LOOSE THERMOSTAT WIRES, BURNT WIRES AT CONTACTS AND COMPRESSOR, MAKE SURE OUTDOOR FAN MOTOR IS RUNNING
MAKE SURE ALL INDOOR BREAKERS ARE ON...MAKE SURE OUTDOOR UNIT IS GETTING CORRECT VOLTAGE...CHECK INDOOR FUSES AND WIRES FOR PROPER TERMINAL PLACEMENT ON THERMOSTAT AND AT BOARD...CHECK FILTER , PLENUM FOR BLOCKAGE...DO SIMPLEST THINGS 1ST..
Apr 05, 2010 | Heating & Cooling
Panasonic air con unit is not blowing cold air out.
This unit is use in motels etc. Check the ouside coil ( conderser) from the inside (discharge fan ) for dirt. Most of these units are floor level . This can cause a unit to short cycle ( cold air is at the floor) .
Jul 17, 2009 | Carrier 52PQ307 Wall/Window Air...
No longer blows cold air and the unit is only 15 months old
First please clean the air filter and ensure that there is no dust settled on the filter which could chock the circulation of air.
To throw cool air the unit got to **** the air from the room and in case the air filter is blocked with dust then there will be no cooling at all.
Please ensure the thermostat knob is turned to the desired cooling level and try running the unit.
Ensure there is no escape route for the cool breeze.
Minimize the frequency of the door or window opening in the area to retain cooling efficiency.
I am sure your unit will work on taking the above precautions before operating it.
Jul 08, 2009 | Haier CPRD12XH7 Air Conditioner
Ac not getting cold but everything working inside and outside
Remove your airfilter and clean it and refix it. Due to deposit of dust the filter would have totally blocked the intake of fresh air resulting in short circulation and throwing back warm air instad of cold air.
Jul 06, 2009 | Sanyo 18KS52 Air Conditioner
Lennox 7 Series MS7-HO-18P MS7-HI-18P Heat Pump Wall Mounted Mini Split Sy Logo
176 people viewed this question
Top Lennox Heating & Cooling Experts
Paul Carew
Tim Whalen
Are you a Lennox Heating and Cooling Expert? Answer questions, earn points and help others
