Question about Cosmi Video Game Consoles & Games
Cyber chess wont play on window 7 64bit
I tried to open the disc and it wont open
If a piece is a king, can he jump his own man?
Hi, Karen the answer is "NO" for more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
How to Play Chess
How to Play Chess Rules and Basics Chess com
How to play Chess for beginners Part1
https://www.chesscademy.com/welcome
Chess Wikipedia
Apr 29, 2017 | Games
Can cyber chess download to windows 10?
Hi , do you mean that the subject program will not install using Windows 10 operating system ?
If so , try running the app's setup program located on the install disk media in compatibility mode for an earlier Windows version such as XP sp3
Compatibility mode enables a late version native Windows to run a program as per a user designated earlier version Windows and so extend support for obsolete apps that may not run using default settings
Navigate to the install disk's file directory using Windows Explorer (not the browser) , click on the folder to open and scroll down to the setup ( application) file . Right click to open the context menu and select properties > compatibility : check : run this program in compatibility mode and select from drop down list XP sp3 (my guess) or latest published supported Windows version for the subject app.
Check under privilege level : run this program as an administrator
click apply > ok then close and double click app's setup file to launch installation
Hopefully will now install and app will subsequently launch and process correctly.
Jan 28, 2016 | Computers & Internet
CODE 43 WHEN CONNECTED
This is usually because the disc control board in the External drive has failed, Try it in a different portable case.
Sep 14, 2012 | Toshiba HDDR500E04XL 500 GB USB Hard Drive
Hi friends, Here i m troubled again i m trying to play my windows(Windows Vista) games like Mahajong Titans,Chess Titans,Minesweeper etc. But nothing is working.When i tried out to play by right...
you should only have to click or double on the game/s specified click to open and play if you right click select open or play
hope this helps
Jul 26, 2011 | Computers & Internet
Bluray does play discs acer 6920g
You will have to update cyber link power DVD for playing Blueray discs.
To update the Cyberlink PowerDVD software:
  1. Connect to the Internet.
  2. Open the Cyberlink Power DVD application.
  3. Click the arrow in the upper left hand corner of the window next to Cyberlink PowerDVD.
  4. Click on Update Now
  5. Follow the prompts to install the update.
Dec 05, 2010 | Acer Aspire 6920 Notebook PC
I put the disc in and click try again it still say please insert disk. My system is Windows XP SP3.
The current link for the fix is available from Focus Multimedia Limited. www.focusmm.co.uk/public/updates/lego/chess/chessfix.exe. Download this patch and install it. You need to be logged in as administator to install it. From then on you don't need the disk, however, I found that the introductory animation is missing, it goes straight to the page where you insert the name of the player. All animations work in the main game, but with the storybook game, I seem to remember it had animations when you went from one location to another when winning games, these also are missing. Mine played perfectly in my old xp computer, new xp computer wouldn't recognize the disk. Now fixed with the patch with the above limitations. Anyway, all other links for the fix were dead, this one works. Contact Multimedia by email if you have any problems, that is what I did. Their email address...welcome@focusmm.co.uk. Good luck to all LEGO CHESS fans.
Aug 29, 2010 | LEGO interactive LEGO Chess for Windows
Wont read the Lego Chess disk
This could be down to ur laser in ur cd-drive.. Could be many of things like Disc data corrupted etc etc. Sometimes if this happens i use a cd cleaner disc tht cleans the laser. These are very cheap.. But down to last resourt... Buy another version of the game. But if tht dosnt work then its your cd drive.
May 09, 2010 | LEGO interactive LEGO Chess for Windows
I want activation code for war chess
i realy want to play the full version but i dont want to pay some one please send their activation code pleasse
Feb 24, 2009 | Warrior 34100 Chinese Chess Set
LEGO Chess
Selectsoft has a patch for this. Download at http://support.selectsoft.com/products/L/LNLEGCHESJ.htm
Works for me.
Marc
Jan 27, 2009 | LEGO interactive LEGO Chess for Windows
Video Game Consoles & Games Logo
24 people viewed this question
Top Cosmi Video Game Consoles & Games Experts
Michael Vincent Cruz
Carlos L. Burgos
Carlos L. Burgos
Are you a Cosmi Video Game Console and Game Expert? Answer questions, earn points and help others
