Question about Electrolux Dishwashers
Esl 43020 Electrolux dishwasher pump keeps running
  • Electrolux
    Electrolux Mar 27, 2014
    Hi Howard White, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? I'm not familiar with that particular model number. Are there any other numbers on the dishwasher that look like a model number?
3 Suggested Answers
SOURCE: electrolux esl 6251 built in dishwasher 2 years old
PROGRAM WONT RESPOND MACHINE NOT STARTING
Posted on Apr 11, 2009
  • 44 Answers
SOURCE: Water is not draining away
Best off to call a certified repair company such as Sears.
Posted on Oct 16, 2010
Ei24id30qs Electrolux dishwasher, drain pump won't shut off until it times out. tech manual refers to a level switch but schematic does not show it. Is it integral to the drain pump?
Not sure if this is same as my (older) dishwasher, but mine has a float switch ( a piece of styrofoam which triggers a microswitch) which sits in the bottom pan. As soon as any water accumulates here, the pump keeps running. I then get error code 30.
Nov 15, 2016 | Electrolux 24" Stainless Steel Built-In...
Hi wont start. just making a loud whiring noise.
According to your description of the fault, something was blocking drain turbine of main motor. Dishwashers always first start drain water because calibration of water level inside dishwasher (empty). In your case, the main motor is same motor for washing and draining. Runing in one direction means washing, runing to oposite side means draining.
The solution is to open a turbine pump and remove all obstacles and visual check turbine impeller,ceramic seal and plastic sleeve on the motor shaft.
Dado
Mar 26, 2015 | Electrolux Dishwashers
Electrolux dishwasher esl 6114 door does not lock
Hi Peter Gumbrell - Often when the dishwasher door does not lock, it is because the of door lock assembly. The door lock or latch may either be faulty or damaged. If I was in your position, I would personally recommend consulting a professional to accurately diagnose the dishwasher to determine the root cause to reduce the risk of unnecessary parts.
Mar 20, 2013 | Electrolux Dishwashers
What does the shower and bar smybol mean on my ESL 63010 Dishwasher please?
I've been dealing w/electrolux for over 2 years on a dishwasher problem. Technician have tried all that they know & the dishes still come out dirtier than when they go in. I've been using it as a drying rack. Kinda exspesive drying rack. Electrolux won't stand behind their product either.They are offering me a 60% discount on a new Elextrolux dishwasher! Are they kidding?
Apr 01, 2011 | Electrolux Dishwashers
Hi, I have an Electrolux ESL 4115. It seems to be stuck on 50 degrees but wont start as usual when I close the door, the on/off button works and lights functioning as normal but that's all. Thanks
I had a similar problem - seemingly stuck or locked with a solid light showing (in my case on the 65 degree wash). Nothing seemed to unlock it. But when I closed it and went away to think about what to do next - some 5 minutes later - it made its end-of-cycle peeps. It now works fine. All I can think of is that I must have interrupted the previous wash cycle l was using before it had ended, and had left the door ajar. all it needed was the door closing for the cycle to finish. Does that help?
Sep 22, 2010 | Electrolux 24 in. ESI6220X Free-standing...
It fills with water and then continues to wash but the water does not heat up.the program does not progress.electrolux esl 6114.
Problem is either a bad controller board or bad heating element.
You will need to know how to diagnostic service work using a volt-ohm meter, and be mechanically handy if you want to diagnose and repair.
Dec 11, 2009 | Electrolux Dishwashers
Dishwasher not working properly
I have trouble with only the top not cleaning properly and have found blockages in the spinning jets at the top, may be worth checking
Mar 02, 2008 | Electrolux 23 in. ESL624 Built-in...
Dishwashers Logo
102 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Garth Jackson
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
