Question about Hotpoint Dishwashers
Hotpoint bfz 700x
Have just fitted a new door lock and dishwasher is showing dON but cannot programme it for cycles but other buttons work. Can you help
  • 400 Answers
Perhaps you disturbed the interlock for the door lock. Recheck that. Another possible solution is to reset the "computer". Unplug or turn off circuit breaker for a minute or so, and then retry. I hope this helps, but I suspect you've already solved the problem.
Posted on Mar 25, 2014
  • 833 Answers
SOURCE: Hotpoint dishwasher full of water after cycle complete
If the motor is running, the diverter solenoid valve is probably not functioning. It is attached to the pump. With the power off, take the solenoid apart and remove whatever is jamming it. Toothpicks are a favorite as are any large food particle. It may also be bad. Not the problem...you may have a defective timer or your outlet hose is clogged or kinked.
Posted on Feb 10, 2008
Illeagle
  • 525 Answers
SOURCE: Hotpoint BCI450 Programme cycles
I attempted to locate an answer to resolve the issue for you, but you have not provided me with enough information to access my service database. Please observe the TIP below, and post me back and I will be happy to assist you further. Should you require more extensive consultation to help resolve your complaint(s), you may contact me through our premium chat service.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information. From this link you can identify your issue and order parts to repair your unit.
http://www.repairclinic.com/0088_9_1.asp
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 23, 2008
amgm
  • 32 Answers
SOURCE: door lock assembly Hotpoint dishwasher
Hello.
First switch off the power.
Get the cabinet door off, start by removing the side screws that hold the door (please have someone to help you, holding the door, because this doors are heavy.)
After you removed the door, remove the screws holding the fascia (about 2 on each side + 2 holding the door lock).
Remove the fascia and you wil get acess to the door lock, disconnect the wiring from the micro switch, connect the new par and reverse the process.
Cheers
Posted on Feb 19, 2009
vickygomar
  • 460 Answers
SOURCE: Hotpoint BF1620 Integrated dishwasher not working
Lets try the following hope this works
1.- unplug the appliance, isolate it from the electric supply.
2.- Remove the kitchen unit plinth and check inside the inspection panels below the door to see if there is water in the base.
If there is, sponge it out and then try the machine again.
Was this helpful?
Posted on May 15, 2009
SOURCE: dishwasher not working. Start button works ok as
It sounds as though the Anti-flood device has kicked in,could be due to a leak under the dishwasher,it will need to be pulled out and investigated.
I would also check that there is water at the hose to the machine.
Hope this helps.
Posted on May 21, 2010
Hotpoint wma48 shuts down anywhere during cycle
which suggests possible the faulty door lock has been fitted with another faulty door lock. this has happened to me on two or three occasions in different situations.
May 23, 2016 | Hotpoint Washing Machines
My hotpoint diswasher is showing F as a fault in the door
can you send more information please like make model brand serial number
Sep 02, 2014 | Hotpoint 24 in. BF72 Built-in Dishwasher
Electrolux dishwasher
Hello - The issue may lie with the door latch; a door switch is used to start and stop your dishwasher. It's a safety feature that won't allow water to flow with the door open. With a faulty door switch, there is a chance your dishwasher won't start at all. Dishwasher door switches are about an inch long. They are usually black but can be red. There are metal prongs on the body of the switch called terminals. Some door switches have two terminals and some have three. If your door switch is OK, check the timer assembly. This controls when and how long power is sent to other controls on your dishwasher. If these controls don't receive power, they won't work. The timer assembly contains a motor. Check this motor as well. It is often cheaper just to replace the timer motor rather than the complete assembly. My last suggestion is to check the cycle selector switches. These switches indicate cycles for washing, drying, and setting the temperature of the water. If one of your switches is the problem your dishwasher may not start. Dishwasher cycle selector switches tell the timer which cycle to run by opening and closing electrical circuits. Most selector switches are six to eight inches long. They are usually black and have terminals. By testing each one of these parts with an ohmmeter you should be able to determine why your dishwasher is not working. It is possible for other parts to fail but these are the most common parts to check. If any proves to be ineffective, I strongly suggest contacting a professional to move forward accurately.
Nov 05, 2012 | Electrolux 24 in. ESL4125 Dishwasher
I have a Hotpoint Super Plus dishwasher 7820. It worked well for a long time. Towards the end of the cycle it leaks a lot of water from the underside of the door, so it seems. I have fitted a new door...
The door seal has to be in a proper position completely around the door (including the bottom area of the door). If not, it will leak. Also, there are two black corner baffles/seals (located in each front corner inside the tub area) that may also be the culprit. Additionally, there may be an issue with the float switch assembly that shuts off the water supply prior to the wash cycle. If the float switch assembly is allowing an extra amount of water in the tub, it will cause a leak.
Feb 26, 2010 | Hotpoint Dishwashers
Was this helpful?
May 07, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Hotpoint BWD129 1200 spin - unwanted drying cycles
This is more a workaround than a solution. When you choose the washing programme (say "D") and push the on/off button, two lights will flash, the "door locked" and the "drying" one. Now turn the "drying programme" button until the "drying" light stops flashing (in my case, this is true when I set the drying programme to 40°C). Then start the washing mashine.
Seems like the function of the drying programme button has shifted against the settings written on the button...don't ask me why! Of course, no guarantee but works for me. Please let me know if it does for you.
Oct 13, 2008 | QuietLine WD-9900 Front Load Washer /...
It's Leaking Water!
Most common reason is that the lower spray arm splits on the seem and sprays water under the door, to proove if it is this remove lower spray arm and run through program if no leak fit new arm. Regards Advisor
Aug 30, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Selecting cycle and starting
I'm assuming the programs are all selected electronically...then your pc board is on its way out. In this case you would have to replace the board...most electronic boards have "service programs" which you can check functions, but I'm not familiar with Hotpoint.... Oshie
Jun 22, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Dishwashers Logo
46 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
