Question about Freezers
Bad smell from fridge (not mouldy food)?
There is a horrible smell in our kitchen which seems to be worse when the fridge door is open The fridge is 13 years old. I have thoroughly checked and cleaned the fridge and there is definately no mouldly or sour food in fridge. Could there be a leak somewhere and is it dangerous?
  • 400 Answers
There is no danger if there is a leak, but the refrigerator will quit cooling. I suspect perhaps you have a dead something underneath or behind the refrigerator. I hope this helps... but I also suspect you have cleared the problem by now.
Posted on Mar 25, 2014
Testimonial: "Thanks for tip. I have searched under fridge and there is nothing dead or suspicious (thankfully!) I have'nt looked at back as it is a built in appliance. The fridge is working ok apart from some ice build ups in freezer and water leaks in fridge part from time to time, but it is old. Should I replace it?"
  • downhille Mar 25, 2014
    I, personally, would keep it as long as it does it's job. If is a frost free unit, it may have a defrost problem. If it is not frost free, ice buildup is normal. I'm not certain what the water leak might be, but that could be the source of your smell... if it's leaking from some cavity in the fridge box. Thank you for the testimonial. I really like to help, and I hope I have been of some.
    New Friend:
There could be a leak inside the fridge that may cause mold and thats the smell. Yes its dangerous when dealing with mold. Have a fridge repair man check it. Or if its a 13 year old fridge it may be best buying a new one. Or it could be a dead rat under the fridge. When u open the fridge door the air flow kicks up the smell straight to your nose. That's what happen to me years back. Thought it was the fridge but is was a dead rat.
  • Colette Cassidy
    Colette Cassidy Mar 25, 2014
    Thanks, feel faint at the thought of finding dead rat, but will replace fridge and hope for best! thanks again, C..
  • 449 Answers
SOURCE: Gassy smell in upright freezer
Is this a refrigerator in a household or an RV?
The reason I ask is that RV refrigerators use ammonia, which you can smell. If you read the article you probably read that Freon does not have an odor, in extreme cases you can smell burnt refrigeration oil when a system with a large leak has been left running, but by then the unit wouldn't be working.
If your refrigerator did in fact have a leak it wouldn’t be working, due to such a small amount of refrigerant present. ( typically about 5 ounces )
So, your gassy smell is likely from something else. I find this happens most often when potatoes or carrots are stored for long periods of time in the refrigerator, usually in the crispers. When starchy vegetables wilt ( get smaller with age ) they give off a gas. The smell eventually comes not from the starch, but from the bacteria that starts growing on it. All this happens on a microscopic level so you won't see anything. good luck
Posted on Dec 19, 2008
SOURCE: Ice build up in my frost free upright freezer
I looked at the BACK at the bottom underneath of my Sears Kenmore frost free upright freezer and what was causing the ice buildup was very simple. At the factory, the assembler looped the little hose too high and when the water went into the hose it could not get out due to being too high in one spot! An ice dam will form, blocking ALL water coming through
and freezing up any more water coming down giving you a HUGE wad of ice that is scary!!! I just removed the screw holding the loop that holds the hose and put a bit of warm water down the little hole on the INSIDE (Behind the grate) to melt the remaining ice in the tube.You need to take out 4 screws and remove the grate to see this. I could not believe that this was the problem! I haven't had any ice build up since.Now don't tear your freezer apart before you try this trying to fix the compressor, thermostat etc. It may be the only thing wrong with it!
Posted on Jul 21, 2008
bobotfel
  • 236 Answers
SOURCE: Noisey fridge freezer
Please check the fallowing:
-Loose flooring or floor not firm.
- Cabinet not level.
- Tubing in contact with cabinet, other tubing or other metal.
- Drip tray vibrating.
- Fan hitting another part or worn fan motor bearings. Unplug the unit and rotate fan manually by your finger.
- Compressor mounting grommets worn or missing; mounting hardware loose or missing.
- Free or loose parts causing or allowing noise during operation
- Check compressor it may contact with tubing or other parts.
- Check the body of your unit is not touching the wall or other object
Posted on Jan 26, 2008
aborcass
  • 2651 Answers
SOURCE: Bottom freezer door dripping water on kitchen floor
you can take a ook into the freezer sect its possible that the line has frozen, nad no longer is defrost water going into the drain but rather falling on to the floor of freezer and evnetually out the door
Posted on Jan 14, 2009
duby1990
  • 367 Answers
SOURCE: Smell from fridge freezer
Put Charcole brickets in the refrigerator. Charcole works better than baking soda and usually take care of the smell.
Posted on Feb 20, 2009
Used wrong water filter. Now that we replaced with correct filter, there is a horrible odor in the refrigerator.
Hello Mary;
My name is Peter. I am a retired field service refrigeration technician.
Putting in the wrong water filter will not effect the smell in your refrigerator. At times the granules in a water filter will break down and get into your water dispenser and ice cube tray. This should not create a bad smell, just cloudy water.
Your plastic liner in your refrigerator has pores and holds odor. You have something in your fresh food section or freezer that is spoiled. Your fresh food section receives cooling air from your freezer. If you have a spoiled product in your freezer you will not smell it because it is frozen. But, as the cooling air goes into your fresh food section and cools down you will smell it.
Find the bad product in your freezer and discard.
With a 50% solution of white vinegar and water wash the plastic liner.
Now you can put a tray of baking soda in your unit, until you purchase deodorizers based on temperature requirements, one especially designed for the freezer section and one for fresh food section. These deodorizer are about $12.00 each.
Try Lowe's and Home depot.
May 11, 2015 | Samsung RF31FMEDBSR Stainless Steel 31 cu....
Very bad smell coming from my Samsung refrigerator
most refrigerators have a small drainage hole leading from the inside rear of the compartment to an overflow container behind the unit, pull the unit away from the wall and check if the liquid in the container has become stagnant, if so simply clean it out and run a small amount of bleach down the hole to disinfect the tube.
hope this helps.
Nov 11, 2013 | Samsung RS261MDWP - 26 cu. ft. Side by...
My freezer drawers are very warm All food defrosted smells horrible even after cleaning. Should I clean condensor, temp is not cooling?
It is likely the condenser fan is not functioning, or the condenser is dirty. You may need to open the compressor access panel to check. If you can hear the compressor running, and the condenser feels warm, the fan should be running. If it isn't, it probably needs to be replaced. Another symptom is the area around the doors feels warm.
Jan 01, 2013 | Sub-Zero 700 Refrigerator Freezer...
We have an older model freezer. The door was left open and we had cleaned up the mess. Now we have a horriable smell around the exterior of the freezer. The interior does not smell. Do all freezers...
Have it clean and use a appliance cleaner that has fragrance to smell it good again.
You must eliminate the source of horrible smell.
Then apply the cleaner on rags, wipe it around the freezer exterior.
Some freezer do have pan and some don't have, so you should look for it carefully.
Good luck.
Jun 26, 2011 | Frigidaire 14.1 cu. ft. Upright Freezer...
Our chest freezer isn't keeping food on top frozen although the bottom is still frozen solid?
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Hope this help in solving the problem....
Jan 11, 2011 | Freezers
There is a horrible foul smelling fish like odor coming from the freezer. It has been cleaned inside and out and we found a dead mouse under the freezer but removed it and then cleaned again. There has...
This is just an idea. the sounds may just be age.. some systems are louder than others and some that are noisy become quiet. But the smell concerns me. It may be that there is something in the cooling fins that is producing the smell. The air from the outside does not directly go into the freezer so I don't think the mouse is the issue. Problems like this usually end up coming from the insulation inside the walls of the freezer. But since you have no history of the freezer loosing power and fish going bad I can suggest anything...If you have any easy access to the inside of the freezer try and take a look. One way to possible clean the smell is to put a bunch of charcoal briquettes on some cookie sheets and put those inside the freezer for a day or two. then switch them out... also you can put a pan of armor hammer backing powder down inside and change that every other day. good luck
Sep 17, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Frosting up badly despite having just been defrosted
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for cold control and air deflector As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control.
Hope this helpout.....
Aug 08, 2010 | Hotpoint 4.87 cu. ft. / 138 liter Upright...
Chemical odor in freezer
can you verify the odor. Does the odor smell like burnt wire insulation or of that of burnt meat?
Jul 05, 2009 | Kenmore Freezers
Servis fridge freezer
Hi ,
ngafm at your service,
If its cold and frozen it may be that the door switch that activates this light in the case that the door is ajar, is faulty.
Or it may be that the temperature is dropping to slowly for you to see it by eye!
The whole purpose of the, "door ajar" light is to protect you food from spoilage and to warn you before it gets to warm!
Door ajar or not!!!
My advice is to fix the problem now no matter if it is only the switch causing a false alarm.
Or the worst case scenario !
You need hands on service!
Bless You ,
ngafm,
please give me a good rating before you sign off.
Thank you.
Sep 07, 2008 | Freezers
I have an unexplained smelly zanussi fridge/freezer model Model zx99/5si? I have a zanussi frost free fridge/freezer model Model zx99/5si which is just 4 years old and it is now giving off a revolting...
Hi - we had this problem, and it was in fact where some blood from a defrosting pice of meat drained into the compressor condensation tank and began to decay!
I agree the smell is terrible, so a good clean up is needed but this solves the problem immediately!
Kind regards,
Mike
Aug 14, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Freezers Logo
279 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
