Question about Hobart Convection Oven Countertop Electric Model Cn 85
I have a Hobart Convection oven Electrial Model CN85, It does not stay at correct temp and doesnt produce a lot of heat even at 450, can stick hand. Is the element most likely to go or is the tempatur
Fuses are good, amps are in range, keypad at bottom of unit is broken. The cooks say it works when it wants to. thanks.
  • 109 Answers
SOURCE: lx30h hobart dw. booster will not turn on. element
The booster heat control circuit is controlled by the relay board. Visually check for loose or burnt relay contacts...
You will see the booster LED light when it calls for heat. Some newer machines have a second high limit on the right hand side of the booster tank.
It may be your control board is configured for low temp with no booster. When you power up, the display should say LX30H. If not
Pull open the upper drawer, place a magnet over the door interlock switch.
CAUTION, 220 volt power is present. be carefull what you touch.
on control board, short J5-1 and J5-2, then power up. You are in factory setup. press select on the control board to see each option on the front panel., press up arrow on control board to step up through options for each step. when done, press the off button on front panel. remove short and start up normally. With the magnet in place, AND THE DOOR CLOSED, run the machine and observe the relay board status lights.
If you want to adjust the temp set points, with the machine off, press and hold the hidden key behind the front panel logo, and press select on the control board.. Or on power up, hold the wask key..Same to adjust options as above. Press off to exit.
Posted on Aug 08, 2009
  • 55 Answers
SOURCE: Hobart dishwasher
bad thermostat or contactor
Posted on Sep 27, 2009
  • 110 Answers
SOURCE: My covection oven does not heat up once food is put in
on the gas valve there is an adj. for the pilot size, maybe too small , would try increasing the pilot and see what happens.also the thermocouple might be on the way out ,you might want to replace that and try oper. go with thermocouple first, then try pilot size dont forget to vote tks. monomoy
Posted on Jan 11, 2010
  • 110 Answers
SOURCE: hobart deep fryer, light pilot heats to temp then all goes out?
it probibly a millivolt system, would reccomend replacing thermocouple, that should take care of the problem
Posted on Jan 13, 2010
SOURCE: hobart electric convection oven model #cn90 ser. # 07-007-968-nj
Have you tried shutting down all power to your oven at the electrical panel, waiting 10 minutes and then returning power to the unit? Procedure could reset the defaults. Best of luck.
Posted on Apr 09, 2010
Thermastate isnt reading right how to recalibrate
If your oven is 150 degrees out of calibration you need to replace the thermostat. More than 50 degrees and you are wasting your time trying to calibrate it, it will just drift right back out.
Feb 17, 2015 | Hobart Cn85 Half Size Electric Convection...
Installed new lamps in hobart convection oven, none of the (4)
The lamps are wired in series, if one lamp is bad, none will work.
Apr 19, 2014 | Hobart Convection Oven Countertop Electric...
Convection oven shuts off after a minute when trying to bake. Does this during Compubake also.. Does not preheat
Possibly a bad oven temp sensor. If the uinit doesnt read a temperature it will shut down to prevent a fire or over heating. The temp sensor is a thermister A temperature variable resistor that changes value as the temp changes. so If the main board doesnt get a response within a vertain resistance range it shuts things down. Sometimes since those parts are in the actual cooking area and subject to the heat and steam from cooking they can rust and break, or just get old and break. Or slam the door and break, you get the idea!!
Oct 19, 2017 | Sharp R-1874 Convection/Microwave Oven
I have a hobart comercial convection oven. The oven will light 3 times but does not stay lit. there is no thermolcouple
The oven has a 3 try electronic spark control. It sounds like the flame sensor is not sensing the flame correctly and is locking out. I don't know if your model senses flame through the high voltage spark wire or if it has a separate flame sensor wire.
Sep 07, 2013 | Hobart Kitchen Ranges
What size circuit is used for a hobart flash bake oven
That information -should- be on the model label. It would be listed as MCA or Max circuit size. If it's listed as merely Amps, you need to add 20% to that amount to select the correct breaker size.
Apr 17, 2013 | Hobart Used Hfb12 Flash Bake Electric...
When set to bake eg: 350 degrees the audio alarm will indicate it's reached temp but the oven is 50- 75 degrees lower. Must wait another 15 min for it to reach the proper temp. Have tried to adjust the off...
If you are monitoring the oven temperature with an analog style thermometer you may actually be ok, but seeing the thermometers slow reaction time.
Some newer ovens actually do pre-heat beep prior to reaching temp in an effort to conserve eelectricity.
A good home test is to try your oven at several different temps to see if there is any variation in internal temperature. Try it one day on 300, the next at 375 and another day at 450. Give your analog style thermometer time to catch up (usually just about 15 min) and leave it on for a half an hour to see if the temp maintains.
Also Beware of aluminum foil AND THE NEW OVEN LINER MATS as they can alter oven performance bay absorbing and blocking the ovens natural heat radiation and convection air flow currents that happen in all ovens, not just convection models.
Another interesting fact is that older ovens used a thermostat in them that operated much like your thermometer and was very slow to react making the oven typically about 100 degrees hotter than where the customer set it. This was just a fact of life before the advent of electronic temperature management and became noticeable when people began trying to bake older "hand me down" recipes in the newer ovens with less than stellar results.
You can mimic the older oven performance by preheating the oven about a hundred degrees higher than called for and after it reaches temp, re-set it to the correct temperature and put the items in right away.
If you find your temperatures fluctuating ask your servicer to replace first the temp sensor and as a last resort the control board as this part is usually pretty expensive.
Good Luck with this!
Jun 14, 2010 | Ovens
Hi. I have a ge convection oven(JCTP17) that has been working great until recently. I bought a Taylor oven thermometer model number (503) To check othe oven temps to see how accurate the oven is. I do a...
The Taylor oven thermometer you bought is decent at best. It is most likely the sensor inside the oven. Has your clock displayed any fault codes? F, followed by a number? Changing the sensor will probably correct the problem.
Aug 19, 2009 | Ovens
Wont heat items in the micro or convection
MODEL NUMBER NEEDED
Apparently this is not actually an R-510HK since that model does not have convection mode. Can you reply back with the correct model number? We may have the service manual for you.
A PRELIMINARY OPINION
It sounds like you have loose door switch mounts or possibly loose door hinges.
If the door won't open via the door open button, then the outer cover will have to be removed.
BEFORE YOU RATE THIS
This is a preliminary post, asking for further information (model). Please withhold your rating until we actually offer the solution.
Dec 06, 2007 | Sharp R-510HW Microwave Oven
Dacor Oven - convection fan stays on while on "bake" setting
Question: does the unit appear to hold the correct temperature? Most convection units only turn the heating elements on and off...not the fan. If the unit is reporting operating temp and then taking other direction...and it is cooking right...you're done.
Nov 14, 2007 | Dacor ECS127 Epicure Stainless Steel...
Hobart Convection Oven Countertop Electric Model Cn 85 Logo
Top Hobart Kitchen Ranges Experts
Andrew Taylor
Andrew Taylor
ka4iup
ka4iup
Are you a Hobart Kitchen Range Expert? Answer questions, earn points and help others
