Question about Durabrand CD Player with Cassette Recorder, CD-2036 (Silver) Boombox
Cd says "no"
Cd is in and spinning and display says "no"
Why does my CD player display "no disc"?
I had a similar problem with my DVD player. Cleaning the laser eye helped fix my problem. You can clean it manually if you are not afraid to remove the cover of the unit or you can try a cleaning disc. The eye can collect dust and prevent it from reading the ID sector of the music CD.
Jul 07, 2014 | Audio Players & Recorders
Why does my CD player say no disc?
IS IT A RECORED ONE, OR STORE BOUGHT, SOME HOME MADE ONES WILL NOT WORK.
CD player JWIM JX-CD589 spins a disk, no display, faint sound
Unless this is an expensive machine replace it. There will most definately be an internal problem. It will most likely cost you most just to have the machine taken apart and inspected then it would cost to replace. Sorry...
Jul 11, 2009 | Jwin JX-CD589 Personal CD Player
Stopped reading cd's
its means that your CD player cannot read data. actually the problem is in your lens. try to clean frist by cd cleaner disc with liguid and try. same problem change CD OPTICAL LENS.
Jun 07, 2009 | Audio Players & Recorders
Cd player on boombox not spinning properly.
Might be the laser but try lubbing the spindle motor 1st!
Mar 02, 2009 | Coby CX-CD248 Radio/Cassette/CD Boombox
No play
Sounds like the drive belt that spins the disk is slipping or broken. You have only one actual cd reader so no matter what slot the disc is in it has to go to the same cd reader drive.
Hope this helps...
Dec 27, 2007 | Technics SL-MC7 110-Disc CD Changer
CD Player
Thank you for your reply.
BeoSound 2000 - The CD won't even spin now. The cover closes, the Number 1 for the track appears in the display, then the cover immediately reopens showing what looks to be something like this [ ] in the display.
Nov 14, 2007 | Bang and Olufsen Beosound 2000 Shelf...
Check disc
Change your DVD player
May 23, 2007 | LG DE9523P DVD Player
CD Player
Have you tryed cleaning the laser lens with a lens cleaner?? The fact that it spins tells us that the unit is focusing but not reading the proper data. Good Luck
Jun 12, 2006 | Bose Wave Music System CD Shelf System
Top Durabrand Audio Players & Recorders Experts
Jonathon summesfield
Lyle Siemens
Lyle Siemens
Carlos L. Burgos
Carlos L. Burgos
Are you a Durabrand Audio Player and Recorder Expert? Answer questions, earn points and help others
