Question about Manitowoc Kitchen Appliances - Others
Sd1492nmodel icemaker noi making ice, but just running water and over flowing water tray. fan and condenser cycle runs, but no ice builds up in tray to harvest.
After an hour of "making ice" mode, there is only minor buildup of ice on lower center tray. Water continues to overflow and no ice is harvested.
  • Lucas Murga
    Lucas Murga Mar 25, 2014
    Ice tray does not get cold enough to build ice
  • 4 Answers
SOURCE: U-LINE BCM95 NOT CYCLING
These units take a full cycle to get to the fill cycle, so you won't get ice on the first cyle unless you manually fill the tray when you first power it on. You may have some air in the water line and need to cycle a few times to fully bleed the air out. Also check the water inlet for debris in the filter screen using a small brass brush, then bleed out air -with water on- while tightening back hose connection avoiding need to bleed while cycling. Lyle
Posted on Nov 26, 2008
vanni7
  • 163 Answers
SOURCE: CME500 ICEMACHINE MAKES ON BOTTOM PART OF CUBER ONLY
Hi!!!Relax you just answer your question.If you went and advance the timer and it work but was stuck in the same position well its your bad timer.change timer and you will be fine..Good luck
Posted on Jan 05, 2009
  • 10 Answers
SOURCE: U Line CLR60 Ice Maker gets stuck in harvest mode & melts ice
have you got the equipment to change this solenoid valve? you will need a vacuum pump to evacuate the system once you have changed the valve, and the equipment to charge the system with refrigerant (gas).
Posted on Feb 04, 2009
SOURCE: Ice maker will not harvest
As crazy as this sounds, turn the temp control a little warmer (counter clockwise). On this model, this control needs to switch to harvest the ice. A warmer setting should fix this issue.
Dean
You can also go to:
www.u-lineservice.com
Posted on Jun 05, 2009
TheMobilian
  • 8220 Answers
SOURCE: My freezer will not go through the harvest cycle.
THE HARVEST CYCLE begins when the freeze algorithm (programmed into the electronic control board) has been satisfied and the sensor arm is out or fully extended. If the arm is in the “in” position when harvest is to begin, a delay of 3 minutes will be added once the arm is moved to the extended position to allow for drawer type ice buckets to be removed for this amount of time without starting a harvest cycle. This 3 minute delay will begin again if the arm goes back to the “in” position anytime during the delay period. This arm is spring loaded to go to the “out” position unless it is being held in the “in” position by an obstacle such as an ice cube.MORE
Posted on Jul 22, 2009
Not makeing ice
There could be over 50 things that will not let that machine make ice so help me out. when in freeze mode is compressor running, is condenser fan running, is water pump running, check condenser coil to make sure it's not full of dirt if so blow it out, cut machine off if water sump tray is full of water and you can still here water coming in at all check water flote to much water coming in all the time will not let water freeze. Fell evaporator plate while running if warm to touch could be hot gas valve letting hot gas in to plate in freeze cycle. you need to call a service company
Jan 08, 2014 | Scotsman Kitchen Appliances - Others
Uline under the counter icemaker not making ice. Fed from RO water and had filters replaced to help but didnt. All is running fine, but not making ice. Dups one tray every 12 hours then stops
Is the condenser fan running? Is the condenser clean? (condenser is the "radiator like" coil outside of the ice box. It cools the hot refrigerant.
Sep 07, 2012 | U-Line Icemaker
Fridge freezer, water inlet pipe keeps warming up
The home icemaker's predecessor was the plastic ice tray. It's fairly obvious how this device works: You pour water into a mold, leave it in the freezer until it turns to a solid and then extract the ice cubes. An icemaker does exactly the same thing, but the process of pouring water and extracting cubes is fully automated. A home icemaker is an ice-cube assembly line.
Most icemakers use an electric motor, an electrically operated water valve and an electrical heating unit. To provide power to all these elements, you have to hook the icemaker up to the electrical circuit powering your refigerator. You also have to hook the icemaker up to the plumbing line in your house, to provide fresh water for the ice cubes. The power line and the water-intake tube both run through a hole in the back of the freezer.
When everything is hooked up, the icemaker begins its cycle. The cycle is usually controlled by a simple electrical circuit and a series of switches.
At the beginning of the cycle, a timed switch in the circuit briefly sends current to a solenoid water valve. In most designs, the water valve is actually positioned behind the refrigerator, but it is connected to the central circuit via electrical wires. When the circuit sends current down these wires, the charge moves a solenoid (a type of electromagnet), which opens the valve.
The valve is only open for about seven seconds; it lets in just enough water to fill the ice mold. The ice mold is a plastic well, with several connected cavities. Typically, these cavities have a curved, half-circle shape. Each of the cavity walls has a small notch in it so each ice cube will be attached to the cube next to it.
Once the mold is filled, the machine waits for the water in the mold to freeze. The cooling unit in the refrigerator does the actual work of freezing the water, not the icemaker itself. The icemaker has a built-in thermostat, which monitors the temperature level of the water in the molds. When the temperature dips to a particular level -- say, 9 degrees Fahrenheit (-13 degrees Celsius) -- the thermostat closes a switch in the electrical circuit.
Closing this switch lets electrical current flow through a heating coil underneath the icemaker. As the coil heats up, it warms the bottom of the ice mold, loosening the ice cubes from the mold surface.
The electrical circuit then activates the icemaker's motor. The motor spins a gear, which rotates another gear attached to a long plastic shaft. The shaft has a series of ejector blades extending out from it. As the blades revolve, they scoop the ice cubes up and out of the mold, pushing them to the front of the icemaker. Since the cubes are connected to one another, they move as a single unit.
At the front of the icemaker, there are plastic notches in the housing that match up with the ejector blades. The blades pass through these notches, and the cubes are pushed out to a collection bin underneath the icemaker.
The revolving shaft has a notched plastic cam at its base. Just before the cubes are pushed out of the icemaker, the cam catches hold of the shut-off arm, lifting it up. After the cubes are ejected, the arm falls down again. When the arm reaches its lowest resting position, it throws a switch in the circuit, which activates the water valve to begin another cycle. If the arm can't reach its lowest position, because there are stacked-up ice cubes in the way, the cycle is interrupted. This keeps the icemaker from filling your entire freezer with ice; it will only make more cubes when there is room in the collection bin.
This system is effective for making ice at home, but it doesn't produce enough ice for commercial purposes, such as restaurants and self-service hotel ice machines. In the next section, we'll look at a larger, more powerful icemaker design.
There are any number of ways to configure a large, free-standing icemaker -- all you need is a refrigeration system, a water supply and some way of collecting the ice that forms.
One of the simplest professional systems uses a large metal ice-cube tray, positioned vertically.
In this system, the metal ice tray is connected to a set of coiled heat-exchanging pipes like the ones on the back of your refrigerator. A compressor drives a stream of refrigerant fluid in a continuous cycle of condensation and expansion. Basically, the compressor forces refrigerant through a narrow tube (called the condenser) to condense it, and then releases it into a wider tube (called the evaporator), where it can expand.
Compressing the refrigerant raises its pressure, which increases its temperature. As the refrigerant passes through the narrow condenser coils, it loses heat to the cooler air outside, and it condenses into a liquid. When the compressed fluid passes through the expansion valve, it evaporates -- it expands to become a gas. This evaporation process draws in heat energy from the metal pipes and the air around the refrigerant. This cools the pipes and the attached metal ice tray.
The icemaker has a water pump, which draws water from a collection sump and pours it over the chilled ice tray. As the water flows over the tray, it gradually freezes, building up ice cubes in the well of the tray. When you freeze water layer by layer this way, it forms clear ice. When you freeze it all at once, as in the home icemaker, you get cloudy ice.
After a set amount of time, the icemaker triggers a solenoid valve connected to the heat-exchanging coils. Switching this valve changes the path of the refrigerant. The compressor stops forcing the heated gas from the compressor into the narrow condenser; instead, it forces the gas into a wide bypass tube. The hot gas is cycled back to the evaporator without condensing. When you force this hot gas through the evaporator pipes, the pipes and the ice tray heat up rapidly, which loosens the ice cubes.
Typically, the individual cube cavities are slanted so the loosened ice will slide out on their own, into a collection bin below. Some systems have a cylinder piston that gives the tray a little shove, knocking the cubes loose.
This sort of system is popular in restaurants and hotels because it makes ice cubes with a standard shape and size. Other businesses, such as grocery stores and scientific research firms, need smaller ice flakes for packing perishable items. We'll look at flake icemakers next.
In the last section, we looked at a standard cube icemaker design. Flake icemakers work on the same basic principle as cube icemakers, but they have an additional component: the ice crusher. You can see how a typical flake system works in the diagram below.
Like the cube icemaker design we examined in the last section, this machine uses a set of heat-exchanging coils and a stream of water to build up a layer of ice. But in this system, the coils are positioned inside a large metal cylinder. Water passes through the cylinder, as well as around its outer edges. The passing water gradually builds up a large column of ice surrounding the cylinder from the inside and outside.
As with a cube icemaker, a solenoid valve releases hot gas into the cooling pipes after a set length of time. This loosens the ice column so it falls into the ice crusher below. The ice crusher breaks the ice cylinder into small pieces, which pass on to a collection bin.
The size of the ice bits depends on the crusher mechanism. Some crushers grind the ice into fine flakes, while other crushers produce larger, irregularly shaped ice chunks.
There are many variations on these designs, but the basic idea in all of them is the same. A refrigeration system builds up a layer of ice, and a harvesting system ejects the ice into a collection bin. At the most basic level, this is all there is to any icemaker.
Mercedes Custom parts
Jun 05, 2012 | Kenmore Fridge Freezer Ice Pan Part...
Ice maker just stopped making ice. had no problem up to a complete stop
Hi and welcome to FixYa, I am Kelly
First off make sure the water in door still works. If it does not work suspect the door / light switch.
Next make sure the freezer temp is below 16 Deg F. The ice maker has a thermostat that starts the ice harvest / fill cycle and if the freezer is warming up because of automatic defrosting problems (Ice build up on the evaporator coils) the ice maker will never cycle. If you note an ice build up in the back of the freezer compartment or poor air flow from the evaporator fan you have an automatic defrosting problem. If the fan is not running at full speed the bearings or windings on the evaporator fan are failing and there is not enough air flow to get the freezer to @ or Below 16 F.
Check to make sure the evaporator fan in the freezer and the condenser fan in the rear bottom of the unit are running un-obstructed. (clean as necessary.... but if the front of the cabinet is hot to the touch then the condenser coils my be clogged with lint or... the condenser fan is not running full speed.
The ice maker may be cycling but it may not be filling with water. If it is cycling but your not getting any water.... at all the prime suspect is the solenoid on the inlet water valve. The water valve is not repairable.
Make sure that the rubber fill tube on the back of ice maker is not blocked with ice... squeeze the end of the tube. If it is frozen with ice... the inlet water valve is bypassing water off cycle and causing the tube to freeze up. The only remedy for this is to replace the inlet water valve.
Thanks for choosing FixYa,
Kelly
Apr 19, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Water leak on back wall of my freezer and a hell of noise from my icemaker when on
Water leak and noise are due to wrong temp setting or malfunction of defrost cycking.Keep temp setting between 3 and 5 degree centigrade. Due to over frosting, the freezer fan fan hits over the ice and working to cool fridge compartment.And also check defrost timer, and heaterworking properly to defrost in time. And if your ice maker is making sound, due to:
  • You will hear a buzzing sound when the water valve opens to fill the water reservoir for each cycle.
  • Rattling noises may come from the flow of the refrigerant or water line. Items stored on top of the ice maker can also make noises.
  • The high-efficiency compressor may make a pulsating or high-pitched sound.
  • Water running over the evaporator plate may make a splashing sound.
  • Water running from the evaporator plate to the water reservoir may make a splashing sound.
  • As each cycle ends, you may hear a gurgling sound due to the refrigerant flowing in your ice maker.
  • You may hear air being forced over the condenser by the condenser fan.
  • During the harvest cycle, you may hear a "thud" when the ice sheet slides from the evaporator onto the cutter grid.
  • When you first start the ice maker, you may hear water running continuously. The ice maker is programmed to run a rinse cycle before it begins to make ice.
Hope, it's helpful>
Feb 05, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
The freezer side every 2 to 3 days the fan makes a noise and the ice begins to melt. It drips from the ice dispenser. The following day every thing is frozen again. The refrigerator stays cold.
This may sound a bit harsh but turn off the water to your icemaker for several days. What your describing sounds like the icemaker water valve is leaking water by the diaphram and is leaking into your freezer. This is a common symptom of failing ice maker water valves. I just went through this on my own personal refrigerator where ice was building up. After changing the icemaker water valve all the ice build up ceased.
So turn off the icemaker water supply for a few days.. break out the ice trays if need be and see if the ice build up stops. If it does then the ice maker water valve will need to be replaced. Fyi they run $38 to 55.00 on average and you can change it yourself. Should the need arise here is a link to a replacement water valve source: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=113933&diagram_id=337176#d337176
Close up view: http://www.appliancepartspros.com/part_details.aspx?part_id=4298908
Thanks for choosing FixYa.
Kelly
Aug 30, 2010 | Frigidaire FRS26R4A Side by Side...
My icemaker went on the blink, found water all over kitchen floor now it will not make ice but the freezer functions great. Model number ED2FHAXB04
Sometimes the water inlet are of an ice maker for no reason will freeze up preventing water from reaching the tray and making a mess. What will happen is the ice maker fill tube on the back of the cabinet also freezes up. As a result the icemaker tries to cycle pressure then builds up in the plastic feed line to the fill tube. This pressure build up in a very "low pressure" plastic line causes that plastic line to push itself out of the press to fit connections (fittings) at the back of the unit or under the unit. Hence the next cycle it just ports water to the now open line causing water to go to the floor instead of the icemaker.
You can locate the source of the leak by simply following the plastic fill tube and re-insert it into the fitting. You still need to find the ice build up that caused the initial leak and melt that ice buildup with a hair dryer or a fan until it is clear. Once you clear the ice blockage (near the rear of the icemaker) it should work normally again.
Feb 04, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water puddling under the frigerator
I had the same problem. The problem was the drain tube from inside the freezer to the drain pan was partially plugged so ice was building up inside, then when the freezer went thru its defrost cycle large amounts of ice were melting. I fixed it by removing valve in the end of the drain hose, all ice inside freezer and ice in drain hose (pour hot tap water thru it).
Hopefully this helps.
Jan 22, 2009 | Refrigerators
Nov 11, 2008 | U-Line Icemaker
No water to ice maker
  • The water line that's attached to the back of the refrigerator. Make sure you have good water flow. If the flow is poor, repair, clean, or replace the tubing or the shut-off valve that supplies the water.
  • The water-inlet valve. Replace it if it has failed.
  • Jun 26, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
    Kitchen Appliances - Others Logo
    62 people viewed this question
    Top Manitowoc Kitchen Appliances - Others Experts
    John Tripp
    John Tripp
    mike cooper
    Dan Webster
    Dan Webster
    Are you a Manitowoc Kitchen Appliances - Other Expert? Answer questions, earn points and help others
