Question about Electrical Supplies
My coleman powermate5500 mod 0525500.01 leaks oil between motor and gen. how to fix
It didn't leak the first day i sold it they ran it interm. within a few days it drips oil between the motor and gen.used almost new cond.
    Sergeant:
  • 415 Answers
The crank shaft seal is bad on the motor. You will need to seperate the motor from the generator to replace the seal. Depending on the seal design, you will have to open the crankcase on the output shaft side to remove the seal.
Posted on Jun 24, 2014
JSEhandyman
  • 368 Answers
SOURCE: Manual Coleman PM 6560
Hi wolfin13,
From my response to your earlier message: If you haven't already done so, check out
http://www.powermate.com/contact.php
Generators / Presure Washers / Home Standby: Customer Service: 1-888-977-2622 Technical Service: 1-800-445-1805 Email: generatorservices@powermate.com
As part of my research, came across this entry from another FixYa expert with some additional info.
http://www.fixya.com/support/t1008210-coleman_powermate_6250_generator
Sounds like Coleman is having issues, if you know what I mean.
Ihope this gets you what you need. If I can be of further assistance,let me know. If this solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Posted on Jan 04, 2009
mamicheddy
  • 79 Answers
SOURCE: Oil Leak
Need model and serial number off this unit in order to proceed.
However, if it is a KY model, with an about 2" cover underneath. That cover is blocking the oil drain plug. It is possible that the oil drain plug is leaking. Remove and drain oil into pan. Clean the plug and add plumbers tape to the plug and install. Then fill the unit back up with oil.
Posted on May 10, 2009
  • 7 Answers
SOURCE: coleman powermate 5000 watt generator leaking oil
CHECK OIL LEVEL. MAY HAVE TOO MUCH OIL IN CASE.
Posted on Oct 15, 2009
  • 5603 Answers
SOURCE: I have a Coleman 5500 with Tecumseh motor and it
Look for a crack in the crankcase... possibly near a mounting boss. Also oil filler plugs sometime leak if overfilled.
Suggestion: Use some "gunk" engine degreaser to make it sparkle so you can spot where the leak originates. You probably need to put it up on a bench OR use an inspection mirror.
Posted on May 01, 2010
  • 142 Answers
SOURCE: Coleman 6250 PoweLeaking gas at bottom of motor housing. Can not
The gas is leaking from carb but in the motor not out.
You should check and repair the carb flow valve. The floating unit may be full and bent down.
Posted on Jun 20, 2010
I have a oil leak on a coleman generator
Most likely at the output shaft of the motor. If you are handy, you might be able to replace the crankshaft seal yourself, but this will probably require you to seperate the generator from the motor, and remove the cover holding the seal. If the leak is small, it may be best to just keep adding oil. If you have to take it to be repaired, it may be more expensive than the unit is worth.
Mar 26, 2014 | Coleman Powermate Powermate 5000W...
Jun 20, 2010 | Coleman Powermate Powermate 5000W...
I have a Coleman 5500 with Tecumseh motor and it has a really, really slow oil leak when it when it is sitting in the shop not running. I can't tell where the oil is coming from. Any suggestions?
Apr 29, 2010 | Coleman Powermate Premium Plus 6250W...
How many miles does an 1997 Buick Lesabre usually last?
Gm says a 3800 engine should last ove 400,000 miles with normal service. This engine for 97 will probably need a new plastic intake manifold one day. They will leak coolant into the combustion chamber and some un-educated mechanics will tell you that it needs head gaskets as they don't have a head gasket problem. The oil pan may leak on this car too, replace it with a fel-pro perma dry gasket and it will stop it. Mine has 297,000+ miles on it.
Apr 10, 2010 | 1997 Buick LeSabre
Oil leak when ran hard fills cab with smoke
Are you sure you don't have an oil leak? And have you had the oil changed or using the right type of oil?
Mar 18, 2010 | Chevrolet Chevy Cars & Trucks
I have a 2000 ford f250 super duty and my engine turns but wont start. It ran fine the other day then i let it sit for a day then try to start it and now it wont start this is the second time it happen to...
possibly the fuel pump check the fuel pressure with a gauge on the fuel rail if its a gas motor, is it diesel if so your in luck cause im a diesel mechanic
Oct 02, 2009 | 2000 Ford F250 Super Duty Crew Cabs
My 2004 dodge durango is leaking oil what should I do? Just bought the car 2 days ago from a used car dealer.
Hurry back !! Tell them right away.. Tell them you did not see this the day you got it.. Tell them you want it fixed right away..
In some states you can return the car within 3 days..
Check what your state laws are on auto purchas..
Jul 08, 2009 | 2004 Dodge Durango
Motor labouring - electric breaker kicking out
The problem that you describe could be casued by several problems that you can check yourself. I usually begin by checking the in-tank check valve for leaking air back to the pump. Follow the air discharge hose to the tank and you will find the brass checkvalve. With about 80psi in the tank, unplug the unit from the wall and loosen the smaller fitting (or larger whichever is easier ) at the checkvalve and listen for air leak. If leaking replace with generic valve available at www.grainger.com. Just pay attention to pipe sizes. If no leaks at check valve, remove capacitors from the motor (mark the leads) and test with meter. Repair shops usually test for free if you do not have a meter that can test capacitors. The caps should test within 95% of rating printed on side. Replace with generic to save money just watch size so that they will fit under cover (also available at grainger). If no problems so far, remove the belt and check bearings on motor and compressor for noise (should be relative silent as your turn it by hand). Worn bearings on the motor will cause the motor to overheat. Worn bearings on compressor will just make noise but usually not cause your problem. If all good, then problem could be valves in pump leaking causing the pump to become very hot. This is a visual inspection by removing the head. Finally the electric motor uses sealed bearings and cannot be lubed, only replaced due to age. Good luck
Mar 24, 2009 | Coleman Air Tools & Compressors
Rav4 mystery oil leak 96 rav 112k miles, timing belt went while I was going fast, it quit and a bunch of coolant came pouring out. Within a week after this was fixed, it was completely out of oil. I...
time for a new car.  You single handedly ruined this motor.  Don't waste anymore money on this car,  buy another car and do the prescribed maintenance as required. Think of this as an expensive lesson.
Mar 15, 2009 | 2006 Toyota RAV4
Electrical Supplies Logo
91 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
