Question about Ovens
Thermador hot wire relay 00414589
Ned part
Thermador oven runs but no heat
check the relay board for a bad solder connection on the underside below one of the relays. repair or replace as needed.
Sep 28, 2014 | Thermador SMW272 Electric Double Oven
F21 error codes
shorted cancel key. replace touch panel and relay board.
Jan 30, 2014 | Thermador C302U Electric Double Oven
Thermador CM302 f63 error code
overheat situation. check oven sensor and soldered pin points for sensor wires at relay board. Resolder if needed.
Feb 10, 2013 | Thermador C301U Electric Single Oven
Recently installed our thermador double oven model med302es 07and 220 is hot at wall plus the wires going into the unit, but the electronic panel on front never came on. Curious if were missing any extra...
Sorry to read about your problem, I hope this helps you out.
sounds like your 220 is not wired the correct way
i suggest you call a service company.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | Thermador C302U Electric Double Oven
I have a thermador oven m#SCD302TP reading F2 F5 // HELP
F2 -Oven temperature too hot
Replace relay board if faulty. Check and replace oven temperature sensor (RTD). If failure repeats, replace ERC (electronic range control or clock).
Thank You
Sep 03, 2010 | Ovens
I have a Thermador SC301 wall oven and the display has faded out. Thermador says I need to replace the whole control unit ($500 for the part!) Any cheaper fix?
I have just repaired two SC301 ovens myself, but it is alot of work. You can get the oven's LED lights reconditioned at a company called CGI industries. Look them up on the web and click on the link for thermador. Removing the led panel and oven relay board is an involved job, but easier if you do it the correct way. First, turn off the power to the oven. Then pull the oven out of the wall socket about 1 quarter of the way. Remove the top cover of the oven with a phillips screw driver. This reveals the oven relay board. Take a digital picture of the board to remember the wire positions, or alternatively write them down. You also need to remove the touch panel (two screws underneath) and gain access to the LED. Remove the LED panel and wires. ship both to CGI (boards only) and you will have them back in less than a week. Costs about $170 before shipping. Reinstall and turn power on. All is good.
Feb 08, 2010 | Thermador Ovens
Thermador over/microwave/heating drawer model SMW272YP Bake bottom element will not heat up. I have replaced the element. The display pannel has been replaced in the past, but still keep having the same...
I just found out my baking oven doesn't work and I hear the fan for the convection roast, but no heat. I had the appliance man out and he said that I need a relay board! Big bucks and they don't make this model anymore. Moreover, the microwave and warming drawer work fine. This is ridiculous!
Mar 07, 2009 | Thermador C302U Electric Double Oven
Ovens Logo
216 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
