Question about LG Computers & Internet
LG Flatron W2253v backlight blinking.
Turning the monitor on, after a few seconds the backlight(at least that's what I think it is) starts blinking for a few seconds and then stops, after a while comes back again. I've tried changing supply cable, changed the wall socket, only thing I need to further test is with a a different DVI cable or try using HDMI but I don't think it's from the cables, cause the monitor is doing some strange low "zzz" noise in the back, right side, which is what I think, from watching some videos, the lamps position. I wanted to know some different opinions before I start disassemble the monitor. In my naive opinion I think it's a "unpplugged" cable somewhere near the lamps, or, I hope not, it's the supply board that is "wrecked". NOTES: -The monitor is ~ 2 years old; - The "blinking" is not "black and white", it's like if you are pressing softly in a switch plug and the light kinda "blinks" fast; - Monitor never turns off by itself; - Randomly the "zzz" noise stops, and comes back again; - The noise doesn't coincide with the "blinking"; but oddly enough when it stops the monitor seems fine. - The noise looks like a "warning message" that the monitor is going to start the blinking fest. Would like to know your opinions. Thanks
  • 56 Answers
The powering off and on the back light is due to bad capacitors. Go ahead and explore the internal power supply. This is a very common issue on LCD I have fixed about 8 of these ranging from 1 yr of use to 9 yrs of use. I own 4 LCDs and have fixed 3 of them. 2-X2Gen, 1 Samsung and one Viewsonic. The latter one is running with out an issue and the one I use the most.
Once you open your lcd look for plunged capacitors. Replace as necessary. The fix should cost you less than 20 bucks
Check this pics for power supply removal, bad caps and new caps.
Well, pictures are over 4mb let me know if you are interested in seeing more pictures relating to this fix.
Posted on Mar 25, 2014
Testimonial: "Ok, this definately is an iternal problem. The monitor now goes black despite being turned on and after turning it back on again, it stays on for 2 seconds and goes black again. So yes, this should be what you're describing. Would appreciate those pictures if possible, cause i have no idea what i am about to do. Another question is, where can i get those capacitors and what kind of material would i need to replace\fix it. Thanks"
  • 1 more comment
  • Hugo Palha
    Hugo Palha Mar 27, 2014
  • Alex Hernandez Mar 29, 2014
    send me an email
    alekshernandez@gmail.com
SOURCE: black screen with message about no input signal
might be something wrong with your monitor's data cable
Posted on May 21, 2009
  • 745 Answers
SOURCE: LG Flatron L1550S power light blinks green.
shorted components on the circuit. send it to a repair shop if you don't have experience on electronic troubleshooting!!!
Posted on Nov 27, 2007
SOURCE: Acer Al 1714. LED light is blinking (orange not green).Monitor black.
Well, suddenly it worked again. But I waited the whole day >.>
Posted on Aug 22, 2008
  • 11 Answers
SOURCE: My LG Flatron L1717S wen I power up it flashes good for 2 sec
are you getting a check signal cable message? any on screen instructions?
try the cable, if it works on another monitor, then sorry to say but your monitor is fried
Posted on Sep 01, 2009
  • 1684 Answers
SOURCE: lg monitor. Turns on but screen is white
This is a common problem on LCD monitors after a few years of use. Because of heat buildup in the monitor case parts called capacitors have started to blow out. When they blow they cause the power supply to fail and not provide the correct voltages the unit needs. If you go to our site at :
www.ccl-la.com we have pictures of what the blown capacitors look like. Open the back of your monitor and look for the blown ones. If you can solder then you can do the repair yourself. Unsolder the bad ones and install new ones. You will need Qty 2 1000uf 16volt and qty 3 1000uf 25 volt capacitors.We have a parts kit for $12.00 I will post a step by step repair guide for you on 11/29/09. If you don't want to do the repair yourself we do offer a repair service for $35 plus return shipping. If you have any questions please contact me at below address.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Posted on Nov 29, 2009
Lg flatron L1919S is blinking when I connected it as a second monitor
If it works as your first monitor, then it is either the cable/connection issue or the graphics software is not seeing it correctly or the second graphics card is not in correct or a combination somewhere.
You will need to do a bit of fault analysis to determine what is causing the issue.
Dec 30, 2013 | LG Flatron 915FT 19" CRT Monitor
My LG Flatron W2253V-pf is being temperamental when finding my computer if you have any suggestions i would very much like to here them. also cant find a manual however i have not looked particularly hard...
1. Check if your video cable is OK and fitted tight
2. RESET the monitor by setting to factory settings.
3. If not OK, try another video connector and/or other video cable.
The manual you can find here or here.
Sep 04, 2011 | LG W2253TQ-PF Monitor
W2242T's backlight not working...
You can buy backlight fluorescent bulbs on eBay.
Jul 04, 2009 | LG W2242TQ-BF 22 inch Monitor
LG L1940HR screen blinks for 1 min. when turning monitor on
some monitors blinks when you have a start up. this usually happens on an outdated video cards. so if it works fine then its ok then. but try checking if you have the latest update for your video card. this happens on an outdated nvidia geforce 7300 go on a laptop runing on windows vista 32 bit. once i updated the videocard, it doesnt blink anymore at start ups.
Feb 06, 2009 | LG FLATRON L1970HR LCD Monitor
LG Monitor Problem
What I did?
are you interested?
nothing is opened on my monitor,
it's just sort of reconfiguring with the tool i downloaded from LG website.
If you're interested email me at xerrose@yahoo.com OR
just buy a new monitor and throw the defective(you think).
Sep 01, 2008 | LG Flatron F700B 17" CRT Monitor
Monitor won't light up. Only just for a second or two.
Hi
this issue is made by defective torch or lamp at the back of LCD...
Thanks!
Aug 05, 2008 | LG Flatron L1515S 15" LCD Monitor
Monitor turns off
If the picture is Reddish either at top or bottom It could be the backlight failing.If you are technically able you maybe able to Replace the CCFL backlight.
Samir
Feb 21, 2008 | LG Flatron L1710B 17" LCD Monitor
Computers & Internet Logo
113 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
