Question about EDGE Tech Corp DiskGO 80 GB USB 2.0 Hard Drive
When I plug my HD in, the blue light comes on, but the motor isnt running.
It isn't recognized by my computer.
  • EDGE Tech Corp Master
  • 3,320 Answers
Have you plugged in the AC power adapter? The blue light means it is connected to the computer but USB power is not enough to operate this drive.
Posted on Mar 25, 2014
My 500GB Elements external hard drive is not being recognized by my computer
check usb cable first might try another cable to be certain it's not communications
and afterwards, you might consider running this utility to optimize your ext drive
Jun 16, 2012 | Computers & Internet
2001 mercury sable will run but won't charge and no batttery indicator light in dash will not light
If it runs you have one of 2 issues. 1. The battery is bad and the alternator isn't able to keep it charged (you will have to jump start it every time the motor is shut off). 2. Your alternator is bad and the battery is running the car (when battery is drained car will stop running) which is my belief as the battery light only comes on when the alternator isnt charging. Have the charging system tested at your local AutoZone/Advanced Auto parts store they normally do it for free.
Nov 08, 2011 | 2001 Mercury Sable
I accidentally plugged my laptop cord (19v) into my Simpletech pininfarina 500gb external hard drive (12v). It was only plugged in for about 20 sec and the HD power light was slowly blinking. I...
Your hard drive is probably dead. However there are stillhopes for hard drive datarecovery.
Put the hard drive in a plastic bag to be compatible for the freezer. Freezingsometimes works to revive a dying hard drive, at least for a shorttime(Probable just about 20 minutes), but be sure that the bag is sealedtightly so that condensation and ice crystals don't form. Put it in yourfreezer for 24 hours that will do the trick. While it's still cold, plug itinto your computer. And you may be able to view it in 'my computer'. And youmay act quickly, because you may only have 20 minutes to recover your data offit and after that the hard drive is completely dead.
If it fails, you will have to go to a recovery office where supply datarecovery service but let's hope not because it will cost you a lot of money andwhether they can recover data is not guaranteed.
Here is a tutorial to guide you how torecover hard drive data.
Aug 31, 2011 | SimpleTech SimpleDrive Pininfarina 500GB...
Computer not recognizing external HD
1st try a different computers make sure its not your Hard drive!
2nd if that works then go to the hard drive maker and download a software driver for it that should fix the problem
Aug 10, 2009 | SmartDisk FireLite 40 GB Hard Drive
My xbox a adapter is plugged in but it isnt
if it isn`t lighting up then please try the adapter with some other computer and if it still doesn`t light up then it`s faulty.you need a new one.
Jul 12, 2009 | Microsoft Wireless Network Adapter Xbox...
Simpletech hard drive not working
I have that problem similiar to yours. My simple tech stopped working for like two years so i decided to open up my simple tech and removed my HD away from the old enclosure so I can try building my own external hard drive for the first time. I bought another new 3.5 enclosure, IDE/ATA for the old HD. I put it in the new enclosure and it worked!
It's the only solution you can have. No need to retrieve data or re-format your HD. You can leave it the way you like...if you wanna reformat it...up to you.
Jan 27, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
No recognized by any PC I try to plug in
Hi are u sure the hard disk was not complitly full if yes try to use anothe backup software such as easy recover pro or so and copy all the data from your hdd to another location but befor udo so please be sure
1. shut down your system shut down the hdd plug the power properly to your hdd and connect the usb or firewire then connect the medium to your system and start the hdd and then start your system ...if it detected its fine...
2. if still dosent detect check in disk management by right clicking on my computer icon go to manage and then disk management if u see the hdd over there and showing status a forigen just right click on the word and say import forigen disk .and should work
if the status shows unalocated right click on it and say intialize hdd ..
if shows helthy and be sure have a drive letter on if not then please right click on the hdd strap and say add or change drive letter and use any abailable drive letter
thanks
good luck
Aug 27, 2008 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Red Light/Blue Light I/O Error
My nx2 is working again after having the "red light/blue light/I/O Error" problem. I just:
1. turned off my computer
2.unplugged the HD,
3. took out the HD from the enclosure and plugged it back into the enclosure,
4.started up my computer without the HD being plugged in
5. after my computer had been on for a minute, I plugged the HD in and my computer recognized it and had the proper mixture of red and blue light coming from the HD, indicating it's working properly.
Aug 26, 2008 | NexxTech Portable Hi-Speed USB 2.0 Kit...
Maxtor OneTouch III Not Recognized by XP
sounds like the USb Port is burned out, might as well chuck it
Jan 09, 2008 | Maxtor OneTouch II external hard drive...
EDGE Tech Corp DiskGO  80 GB USB 2.0 Hard Drive Logo
62 people viewed this question
Top EDGE Tech Corp Computers & Internet Experts
David Payne
David Payne
Are you an EDGE Tech Corp Computer and Internet Expert? Answer questions, earn points and help others
