Question about Sigma BC 12.12 STS Wireless Cycling Computer: Black
Setting sigma I bought a new sigma 12.12. sts. It doesn't start after pressing longer then 4 sec on the set button. (neither on the other buttons) New batteries didn't help. Suggestions?
4 Suggested Answers
SOURCE: Sigma 18 -200 lens with D40x
This lens is NOT compatible as the body doesn't have a motor . £200 wasted
Posted on Jun 09, 2008
  • 15 Answers
SOURCE: I was trying to reset
One of two things has happened to the unit, it's gone out for good or the button is messed up some how. If you look through any basic info on wiring you can realize that it's pretty simple to take something apart and put it back together. It's broken anyways so if it's not under waranty and you'd rather just fix it. Unscrew the screws holding the casing and look at where the switch is. it could have corroded due to rain or it could even just be stuck like an old cassette player.
Posted on Aug 07, 2010
dunnbiker
  • 8546 Answers
SOURCE: i have a sigma sport 800 bike computer which is
They print manualsto make up for our imperfect memories. Find yours here...
http://www.sigmasport.com/en/service_center/produkt_support/bikecomputer/?flash=1&typ=bikecomputer
Posted on May 07, 2011
Set time1440sports
Buttons are numbered as followed:
Start/Stop is button 1
Lap/Rst is button 2
Indiglo is button 3
Mode is button 4
a) Press 4 to select "TIME" mode
b) Press 2 and hold for 2 sec to select "SET" mode, second digits blink.
c) Press 1 to reset digits to 00.
d) Press 4. Minute digits blink
e) Press 1 to set minutes.
f) Press 4. Hour digits blink.
g) Press 1 to set hours.
h) Follow same patter to set day of month, month, etc...
i) Press 2 at any time to retain set values and exit procedure
Nov 16, 2011 | Watches
I have forgotten my alarm code for my motorhome Sigma S30 The keypads still work but I need the code to reprogramme a more rememberable number
Here are some important informationabout Sigma S30. Programming a New PIN Code:
The standard PIN code can be changed following thesequence below:
i) Type in to the keypad **
ii) Type in to the keypad the "existing PIN code" then *
iii) Type in to the keypad 92 * "new PIN code" * "new PINcode" #
Programming Remote Keys to the System:
Remote keys can be added or removed to/from the systemfollowing the sequence below:
iii) Type in to the keypad 91 * " the number of keys to beused" #
iv) Press the first remote key button until bleep sounds,release and press next key. Continue until all
keys have been taught to the system. Note the maximumnumber of keys is 4 and all keys required
to operate the system must be taught during this operation- any key not included will no longer
operate the system.
Full Programming, Diagnostics and Features
This section contains all the information that the dealersuse for programming and diagnosis of
the Sigma M30 alarm system, using the MK1 keypadprogrammer.. Programming can also be carried
out using a dealers CP1 programmer.
MK1 Keypad Programming Introduction
It is important the keypad buttons are not pressed tooquickly-
Each time a button is pressed the LED on the keypad willflash once as confirmation. The next button should
not be pressed before this confirmation.
It is important the keypad buttons are not pressed tooslowly-
When in programming mode, if a button is not pressed for aperiod of 10 seconds or more, the alarm will
automatically exit programming mode. This will be confirmedby repeated flashes from LED on the keypad.
You must wait until the LED stops flashing and then startagain.
All programming functions are entered after typing * andthen the programming PIN code. The programming
PIN code is 17856.
To enter the programming PIN code, the alarm system mustfirst be armed and then disarmed using a valid
remote key. (Or keypad using the PIN code)
* 17856 * must then be entered within 30 seconds ofdisarming the system. This is then followed by a 2
digit function code, then another * and then sometimesoptional parameters as shown in the following tables.
It is important to remember the * key is used to separatethe various parts of the code like this:
* programming PIN code * function code * parameter #. The# key is pressed at the end of all
sequences and is used like the "enter" key on a computer keyboard.
Programming Features On or Off:
Programming
PIN
Function
Code
Switch Code
(where 0=off and 1=on)
Function Default
* 17856 * 00 * 0 or * 1 then # arm/disarm bleeps * 0 (off)
* 17856 * 01 * 0 or * 1 then # door open warning bleeps *0 (off)
* 17856 * 02 * 0 or * 1 then # auto-lock * 0 (off)
* 17856 * 03 * 0 or * 1 then # auto-arm * 0 (off)
* 17856 * 04 * 0 or * 1 then # auto-arm to include doorlocking * 0 (off)
* 17856 * 05 * 0 or * 1 then # auto-rearm * 0 (off)
* 17856 * 06 * 0 or * 1 then # engineer mode * 0 (off)
* 17856 * 07 * 0 or * 1 then # hold-down remote key button= -ve
output on wire 4
* 0 (off)
* 17856 * 08 * 0 or * 1 then #
hold-down remote key button =
extends lock pulse
* 0 (off)
* 17856 * 09 * 0 or * 1 then # after disarm -ve output onwire 4 * 0 (off)
Programming Timing Settings:
Programming
PIN
Function
Code
Variable(s) Function Default
* 17856 * 10 * 1 to * 30 then # stall to ignition on timein seconds 30 sec
* 17856 * 11 * 1 to * 99 then # unset to ignition on timein seconds 30 sec
* 17856 * 12 * 1 to * 99 then # panic time in seconds 05sec
* 17856 * 13 * 1 to * 51 then # lock time in seconds (51gives two
short pulses)
01 sec
* 17856 * 14 * 1 to * 51 then # unlock time in seconds (51gives
two short pulses)
01 sec
* 17856 * 15 * 1 to * 99 then # settle time in seconds 15sec
* 17856 * 16 * 1 to * 99 then # threshold setting time inseconds 15 sec
* 17856 * 17 * 1 to * 99 then # auto arm time in seconds60 sec
* 17856 * 18 * 1 to * 99 then # auto re-arm time and also-ve
output time after disarm , on wire 4
(green/red) in seconds
60 sec
Displaying System Diagnostics:
The dashboard LED displays the value of settings as anumber of flashes.
Programming
PIN
Function Code Function
* 17856 * 30 then # time elapsed since last trigger (inminutes)
* 17856 * 31 then # as * 30 above - but each flash = 256minutes
* 17856 * 33 then # wire 7 (orange) ignition trigger count
* 17856 * 34 then # wire 1 (blue) -ve door trigger count
* 17856 * 35 then # wire 2 (blue/red) -ve boot triggercount
* 17856 * 36 then # -ve bonnet switch trigger count (blacksingle wire on siren
plug)
* 17856 * 37 then # ultrasonic's trigger count
* 17856 * 38 then # last trigger register (see tablebelow)
* 17856 * 39 then # reset all above trigger counts to 0(zero)
Setting Up Pre-set Programs:
Keying in the following sequences on the keypad sets up afixed set of features, which can be used as a
starting point for further tailoring:
* 17856 * 80 # everything off, lock and unlock pulses 1second.
* 17856 * 81 # as for * 80 above, with auto-rearm on.
* 17856 * 82 # as for * 80 above, with auto-arm on.
* 17856 * 83 # as for * 80 above, with auto-rearm andauto-arm on.
* 17856 * 80 # Default setting configures the values shownin the previous tables 1, 2 and 3. Hope this will help you. Good Luck.
Aug 22, 2011 | GPS
How do I change time on a KADIO clock 3809
MODE (LONG PRESS-4 SEC) TO ENTER INTO SETTINGS;
UP/DOWN TO CHANGE THE PARAMETERS; \
*C/*F KEY TO TOGGLE BETWEEN TO TEMPERATURE FORMAT;
SNOOZE BUTTON TO SET SNOOZE IN ALARM-MULTIPLE SNOOZE CAN BE SET;
RESET KEY CAN BE USED TO RESET CLOCK TO DEFAULT;
DAY COUNTDOWN , AND TIME COUNTDOWN CAN BE ADJUSTED;
DETAILED INFORMATION TO SET THE CLOCK
INSERT CELLS;-SCREEN SHOWS DEFAULT VALUES-INITIAL MUSIC WILL RING;
LONG PRESS MODE BUTTON-KEEP IT PRESSED UNTIL 12 STARTS BLINKING;
USE UP /DOWN BUTTON TO ADJUST HOURS...
THEN SIMPLY PRESS MODE AGAIN, NOW MINUTES 00 IS DEFAULT WILL START BLINKING;
USE UP/DOWN BUTTON TO ADJUST MINUTES;
AGAIN PRESS MODE, SCREEN WILL SHOW YEAR 2002 DEFAULT BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW MONTH BLINKING, USE UP/DOWN KEY TO ADJUST CURRENT MONTH;
AGAIN PRESS MODE, SCREEN WILL SHOW DATE BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW 12:00 BLINKING WITH ALARM SIGN (FOR ALARM SET);USE UP/DOWN KEYS TO SET ALARM, FIRST HOURS AND THEN MINUTES FOR ALARM; THEN ON PRESSING YOU CAN SELECT SNOOZE MINUTES;
AFTER SNOOZE ON PRESSING MODE AGAIN YOU CAN SELECT DAY COUNTDOWN TO SELECT 999 DAYS COUNTDOWN FROM CURRENT DATE;
when watch displays time and everything .....
each and every buttons has some function;(shortcuts)
press down to toggle between 12hr/24hr format;
press up to enter contdown timer;
press snooze to set snooze in alarm;
press c/f to toggle between two temperature formats;
press mode to toggle between alarm time and current time;
Nov 08, 2010 | Watches
How to set the clock of sigma bc 1009 sts
hold the left bottom button untill the blinking caption "settings/ open" disappears. Then there are some options: language, distance counter, wheel size and clock. Swich between them with right bottom button, and when clock appears push the left bottom and change hour with top buttons, swich to minutes with the right bottom and finish by pushing the left bottom button. Then hold it longer to exit settings. Done. Damn, I could find no online manual and had to discover that myself.
Nov 01, 2010 | Cycling
AEG single oven - clock runs for 12 hrs , buzzes and goes back to 12 o'clock - if set timer and check time remaining, it buzzes and jumps to clock setting loosing time remaining. Buzzer sounds ''hoarse''.
you must setting the count down timer instead of time of day. to set time of day. press centre button 4 times lamp flashes in bottom righthand of display. use + and - to get correct time after 10 secs time will lock in. to check you have not set count down press centre button 3 times lamp flashes top right corner of display if not at 0000 use - button to get to 0000 leave 10 secs then should revert to time of day. also check you have not entered cooking time. press centre 1x this also should read 0000. hope this helps
Jul 17, 2010 | AEG B2100-4 Electric Single Oven
How do I get the "change oil" message off my 2008 f 450 superduty?
Message center cluster
#1 press and release setup button until mess. cntr. displays"press reset to begin system check"
#2press and release reset button until cntr. displays"hold reset if new oil"
#3press and hold reset button for 2 sec. and release oil life should read 100%
#4 center displays"setup menu hold reset"
base cluster
#1 press and release trip/reset button until mess. cntr. displays"setup menu hold reset"
#2press and hold trip/reset button 2 sec. until mess cntr. displays"reset for system check"
#3 press and hold trip/reset button 2sec. until mess. cntr. displays"oil life XX% reset if new"
#4 press and release trip/reset button until mess.cntr.displays"hold reset if new oil"
#5 press and hold trip/reset button for 2 sec.and release to reset to 100%
#6 mess. cntr. breifly displays oil change set to 100%.
HOPE THIS HELPS
Feb 10, 2010 | 2008 Ford F 250 Super Duty 4WD
I HAVE A NEW SONY BDP-360 SONY BLU-RAY PLAYER AND I HAVE A DVD FROM AMERICA I CAN'T PLAY AS WE ARE IN REGION 2 AND IT IS REGION 1. ANY WAY OF DE CODING THIS SO IT CAN PLAY ALL REGION CODES. THANKS.
Yes there is a hack to make the DVD region free, as far as I know there is not one for the Blu-Ray as yet.
You will need your original remote and a 7040 OneforAll remote to enable region free playback of DVD’s on the Sony BDP-S350.
Programming the 7040 OneforAll remote.
1. Press DVD
2. Hold the magic button until the DVD button flashes twice.
3. Press 0533
4. Hold the magic button until the DVD button flashes twice.
5. Press 994
6. Press Magic Key (don't hold)
7. Press 1891 (this sets key 1 – the DVD button flashes twice)
8. Hold the magic button until the DVD button flashes twice.
9. Press 994
10. Press Magic Key (don't hold)
11. Press 2552 (this sets key 2 – the DVD button flashes twice)
12. Hold the magic button until the DVD button flashes twice.
13. Press 994
14. Press Magic Key (don't hold)
15. Press 0953 (this sets key 3 – the DVD button flashes twice)
16. Hold the magic button until the DVD button flashes twice.
17. Press 994
18. Press Magic Key (don't hold)
19. Press 2214 (this sets key 4 – the DVD button flashes twice)
20. Hold the magic button until the DVD button flashes twice. .
21. Press 994
22. Press Magic Key (don't hold)
23. Press 0795 (this sets key 5 – the DVD button flashes twice)
Done - the remote is now programmed and ready to use
1. Now to make your player region free use the Sony remote that came with the player to bring it out of standby and wait while HOME is displayed
2. Make sure there isn't a disc in the machine.
3. Now on the OneforAll remote press 1, 2, 3, 4, 5 (The blue 24p light on the player will start flashing)
4. Put the player back into standby with the Sony remote
5. That’s it, the next time you turn on the player it will be region free for DVD playback
If the blue 24p light doesn’t flash then it hasn’t worked, try a new set of batteries and start a fresh
Good luck.
Jan 23, 2010 | Sony BDP-S360 DVD Player
Setting the clock on a Denon UD-M30 CD-R
1. press the menu/set button on component to select display mode
2. use the +/- button to set the time mode (AM 12:00 blinks)
3. press the menu/set button for at least 2 seconds (the hour will start blinking)
4. Use the +/- button to set the hour, must roll the hour to change am/pm
5. press the menu/set button to switch to minutes
6. use the +/- button to set minutes
7. press the menu/set button to finish setting the time
Dec 15, 2008 | Denon CDR-M30 CD Recorder
Scpt960- i am not able to open the disc
Try cold start.
Power off main set manually by press power button on main set.
Unplug power cord from main set.
Wait for about 5 sec.
[Without plug in power cord] Press and hold "Power" button without release it.
Plug in power cord (must have power) to main set by using another hand [while another hand still press on main set power button]
Keep holding until u see ------ on main set FL display.
Then release you hand which just now pressed on main set.
Power on main set again by manual press power button on main set.
Result should be OK (unlocked)
May 25, 2008 | Panasonic Home Theater System System
Mean (x-bar), variance (s^2) and standard deviation (s)
Enter 1 then press the (SIGMA)+ button (SIGMA) looks like a sideways capital M ....its a Greek letter.
Then enter 2 and press the (SIGMA)+ button
Then enter the next value and press the (SIGMA)+ button
After you press the (SIGMA)+ button the calculator displays the number of numbers you have entered
Once all numbers of your sample have been entered press 2nd and the button corresponding to x-bar
sample st. dev is the (sigma)n-1 button (need to use 2nd button)
variance is (std. dev.)^2
population st. dev is the (sigma)n-1 button (need to use 2nd button)
Jan 18, 2008 | Texas Instruments TI-30XA Calculator
Sigma BC 12.12 STS Wireless Cycling Computer: Black Logo
111 people viewed this question
Top Sigma Cycling Experts
Bill Boyd
Donald Ayers-Marsh
Are you a Sigma Cycling Expert? Answer questions, earn points and help others
