Question about Hoover SE230 Front Load Washer
Drum not turning
Hi all have changed the brushes last year and has been working fine now the drum dose not turn and a burning smell have had the machine out and removed the back panel plugged it in and switched it on it did not move then pushed the fly with a screw driver and it did just trying to confirm the motor has had it before I buy a new one. Ta malcolm
If u have a burning smell, I'd check the belt and belt pulley. There is a switch at the pulley arm...if the belt hasn't pulled the pulley tight the switch won't make and motor won't run.
Posted on Mar 25, 2014
4 Suggested Answers
SOURCE: drum not turning
Problem sorted, motor is brushless and tested ok. Traced problem to statup capacitor, no circuit across terminals, will be relatively cheap fix
Posted on Jan 22, 2009
BIKER T
  • 909 Answers
SOURCE: Drums tries to turn but fails.
usually there is a board on the side of the wall of the machine. Check carefully for dry or burned tracks on the board. they either use a relay or possibly a triac etc, Current is fairly high and any bad soldering can create a dry joint. Look for any loose connections leading from the motor to the board. Check the tachometer which normally connects at the bottom end of the motor.Sometimes the magnet comes loose and gives an incorrect signal to the controller. let me know.
Posted on Nov 12, 2009
barkencoa
  • 3463 Answers
SOURCE: Hoover AM120 - Have replaced motor brushes - drum
I would recommend that you consider replacing the washer, as it certainly sounds like a faulty programme control, and they are expensive
The motor itself must be o/k, otherwise it would not function at all
Posted on Nov 28, 2010
My frig. agq600fs gas dryer drum will not turn.
Good bet it's the motor!
Disconnect electric plug.
Have to get access to back of the dryer, remove a few screws.
Look at motor and belt, motors sometimes over heat - Burn Up.
Motor could be replaced, depending on the age and how long you have had it!
Nov 29, 2013 | Frigidaire AGQ6000ES Gas Dryer
Our kenmore dryer is 6 years old , model# 110.63102101 at first the drum wouldn't turn,and we would get it to turn by using our hand , last week it smelled liked it was burning, so let it rest and then it...
In your case the motor probably has gone bad....you are looking at a 200-400.00 repair, so go from there...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 04, 2010 | Kenmore 62602 Electric Dryer
Kenmore 70 dryer smells burnt
There could be dust settled on the motor inside from the few years in storage. Unplug and remove back, with a hoover brush **** off all dust but do this lightly as to not disturb any connections.
Jan 04, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Drum dose not turn belt is ok no smell or dust
Fit new motor brush kit if well worn cost about £25 ...
Nov 13, 2009 | Washing Machines
Hello i have a hotpoint wma40 the machine will go
Hi, i have a wma40s had it for 7 ears now same thing happended would start a cycle but then stop halfway through make the noise but the drum would not spin etc. i bought some carbon brushes of ebay for 7 quid and it works better than its worked in years bit nosiey for first few washes but after it settles it is as good as new.
Jul 06, 2009 | Hotpoint WMA40 Front Load Washer
Burning Smell from Belt on Whirlpool Dryer
Hi, You need to check and see if the belt has slipped off of one of the pulleys. Was the idler the wheels style or a glide style?
Make sure the grooves in the belt are facing the drum and they are in the grooves of the motor pulley.
Please let me know if this helps and if I can assist you further.
Vic
Jun 01, 2009 | Whirlpool LER5636P Electric Dryer
Electrical Burning Smell from Henry HVR200 Vacuum Cleaner
Hi! Highly unlikely that you need a new motor.  Highly likely that you need new carbon brushes.  The smell is caused by excessive sparking between the worn brushes and the copper commutator segments.  Most carbon brushes (and from memory I suspect this includes Henry's) have a copper wire buried in their last few millimeters, and you really need to change them before that becomes exposed.   The longer you run it like this, the more likely you are to damage the commutator, so change them sooner rather than later.  When you change the brushes, you can smooth off the commutator with very fine abrasive paper (the objective is to smooth it, not scratch it!), and then blow all the dust away (or **** it away if you have another vac, of course).  Incidentally, you don't say if you are using a paper bag in your Henry. Some people, because the top-hat filter is so good, try to manage without a bag.  This is false economy!  You should always use a bag. I hope this helps! I value feedback, so please remember to rate this response.
Feb 28, 2009 | Numatic Henry Bagged Canister Vacuum
Drum not turning
Jan 21, 2009 | Hoover AAA160 Front Load Washer
Hoover SE230 Front Load Washer Logo
35 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
