Question about AOC Monitor
Not displaying anything
When i plug my computer into the monitor the monitor doesnt display anything!...so i check he settings and everything was fine, i then tried it with my xbox and still nothing being displayed
  • AOC Master
  • 3,320 Answers
Sounds like the monitor is dead. Replace it.
Posted on Apr 02, 2014
Benimur
  • 6966 Answers
SOURCE: no display on monitor only orange light
Normally the orange light should turn green when everything is a go. Often the problem of orange light is not really the monitor but the PC. There is not video output from the video card and the monitor in sensing this assumes that the cable is unplug and thus does not switch on (green).
The sure way of determining which is at fault is to try and use a different monitor to your PC (as well as the cable). Should problem persist, then it is the PC that would need to be checked. On the other hand, if the PC works with another monitor, then you have just verified that indeed the monitor is defective.
Should you have verified that it is the PC, suspect would either be the video card and/or the memory sticks. In some instances cleaning with a pencil eraser the little gold pins of either the video card and/or the memory sticks helps.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 26, 2008
  • 13433 Answers
SOURCE: Display menu virus? :(
try disconnecting your network cable and adjust the settings again, if you cant, enter safe mode by pressing f8 in the startup and select safemode then adjust the contrast there.
Or is this in the CRT monitor? inside the monitor? there are no viruses ever made for monitors. So its most likely a hardware fault in the crt. Maybe its time to buy a new one. LCD preferably easyer on your eyes.
Posted on Apr 28, 2008
SOURCE: Input not supported
1. Restart the computer.
2. When the computer begins to reboot, press the F8 key repeatedly in one second intervals until the "Windows Advanced Options" appears.
3. Select "Enable VGA Mode" and press ENTER.
4. Select your operating system from the list and press ENTER
5. Follow your normal log on procedure.
6. RIGHT CLICK with mouse anywhere on your desktop.
7. Select PROPERTIES.
8. Select SETTINGS then select ADVANCED.
9. Select ADAPTER then select LIST ALL MODES.
10. Refer to your monitor user's manual or Quick Start Guide for the recommended resolution or mode for your monitor.
11. Select OK then APPLY then OK.
12. Depending on your computer setting, you may need to re-start the computer for the changes above to take effect.
Hope its useful!
Posted on Aug 20, 2008
Democritus
  • 120 Answers
SOURCE: hi...my AOC 17" CRT monitor
Change to the lowest settings you can on the other monitor, then connect the 17" CRT. If you can see anything, go to display settings and slowly bring the settings up. If you lose the display, press "n" (there is a dialog box asking if you want to keep the settings, y or n). Most likely it is a refresh rate that is set to high. Try setting this to 60 Hz for starters.
Hope this helps.
Posted on Dec 12, 2008
  • 86 Answers
SOURCE: On Screen Display (menu) is Locked
Hi there - I read in another forum to use the left button instead of menu. Give it a try - power off and hold left button while powering on.
I'll cross my fingers for you :)
Posted on Aug 29, 2009
E machine model T3626 turns on display doesnt work and doesnt power off???
Sounds like either the Monitor is bad or the Video Card is bad. Try plugging another monitor on the computer and if it can't show a display then more than likely the Video Card is bad. If it shows on the monitor you just plugged in, then the original monitor is bad.
May 01, 2012 | Computers & Internet
My Dell Latitude D630 has a blank screen.
Check your hardware light on the exterior of your computer and see if it is lit and blinking. If it is, you have an operating system, but just can't see it. That tells me it may be several things:
1. The LCD cutoff switch is in the off position
2. Toggle (Fn) the display to the internal settings of the LCD panel. It may be set to display an external monitor only
3. Plug in an external monitor. If it doesn't display on the external, after pressing the Fn key you have a failed video adapter. If it does display on the external it is most likely a back light or inverter failure.
Apr 05, 2012 | Dell Latitude D630 Notebook
No monitor display... Sounds like its booting up just fine.. But no display??
It could be the video card or the monitor.
If the video card, then sometimes checking everything in the system settings can identify the problem. Otherwise, update the drivers for it.
It could also be time to get a new monitor.
Feb 14, 2012 | Computers & Internet
How to fix No Display on LCD Display Panel at all?
Good day, For you lcd issue you may try doing these steps:
1. Check if the the power cable of properly plugged in.
2. Check the cable connecting your monitor to the tower or CPU
3. If there's no power at all you can try to change the power cord and also the monitor to cpu cable.
4. You can also plug it on another outlet to make sure that its not your power outlet that's causing this problem
If everything above doesnt work for you, you might consider having it check by a technician or just purchase a new one. Hope this information help you a bit. Have a great day.
May 24, 2011 | CTX Panoview 510 (White) 15.1 in. Flat...
My computer
Install proper display driver
Jul 07, 2009 | HP w2207 Monitor
Monitor does not work, computer starts up, dell prompts load, windows prompts load then screen goes black. i can hear everything loading but no display.
connect an external monitor on your machine and check if display is ok on the external monitor. if yes, try to re-install your video driver and check if display is ok on your laptop.
if both doesnt have display (external monitor and laptop's display) i suspected your lcd display is faulty.
Jun 30, 2009 | Dell Inspiron 6400 Notebook
Syncmaster 203B LCD not working with Vista 64
I would first recommend reseting the bios, if the monitor still is black then it may be a problem with the graphics card
Dec 16, 2008 | Samsung SyncMaster 203B LCD Monitor
Am using compaq presario cq50 the device display doesnt show anything but other than than display screen everything is working.. properly...
Your laptop is probably working with an external display.
Try to change the setting, by pressing the function key (usually on the bottom left of your keyboard) and the Fx key with a monitor (I don't know exactly which key it is but usually is F4 / F5 or F6).
Nov 28, 2008 | Compaq Computers & Internet
Monitor display problem
Your resolution or refresh rate has somehow gotten altered in the display settings. Reboot the computer in safe mode and correct the display settings to fix.
Aug 02, 2008 | HP Pavilion MX70 17" CRT Monitor
Fan, HDD... everything is working but no display.
You have no display, and cant even get to the bios screen.
OK, does anything at all show on the monitor when starting?
Logo,etc?
If that is the case, look to your video card or monitor.
I cant tell you how many times I have seen pins that are bent or proken on the VGA cable. or even plugged in.
Please check these things and let me know what you find
Nov 18, 2007 | Intel Desktop Board D845WN Motherboard
Computers & Internet Logo
78 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
