Question about Kenwood Car Audio & Video
2005 jeep grand cherokee
Hi, when I hooked up all the wires on the wiring harness to the stereo wires, I matched all of them up. But the stereo does not power up at all. Nothing happens. Any advice? Thanks so much
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 65 Answers
Check the fuses under the hood and by the kick panel and the fuse on the radio too. sounds like you popped a fuse some were. Did it never power up or did it just stop working.
Posted on May 19, 2014
SOURCE: need to hook up a 200 pioneer stereo with wire harness from 96 honda accord to the wiring on a 64 impala
there is only one power wire i cant remember the color use a test light to figure it out...then you need to make a wire off the fuse box that turns on when the ignition is on
Posted on Jul 29, 2008
ginko
  • 19396 Answers
SOURCE: no sound.
The first thing you need to do is doublechecking all the new wirings, it sounds like a contact.
Posted on Oct 24, 2008
  • 110 Answers
SOURCE: replacing a stereo into a 2005 Saturn Ion
not sure if your still looking for a solution or not but here you go. that orange and white wire is normally the wire that controls the dimmer within the stereo. when you dim the dash light the factory radio lights dim and that wire is suppose to make the new radio do that also. in my past i have found that only about 30 percent of the aftermarket radios actually do that when hooked up. give this a try and let me know. good luck
Posted on Feb 28, 2009
jaa278
  • 65 Answers
SOURCE: Kenwood KDC-135 remote wire
should be a solid blue wire
Posted on Jul 24, 2009
  • 32 Answers
SOURCE: Installing Jvc KD-R610 into 02 Nissan Frontier,
well it sound like your ground wire is not connected the properly way this wire is black make sure
the other 3 are connect right are Yellow is constant power ,Red is acc.ingnition,Blue is the remote.
that would complite your conection done.
Posted on Dec 27, 2010
Jeep cherokee not grand. where is the tcm
The transmission control module on the 45RFE can be found on the passenger side engine compartment, mounted to the inner fender near the firewall.
Nov 11, 2013 | Cherokee Jeep Grand 2005-2007...
Hi, I need the radio code for a 1998 Jeep crand cherokee, thanks
When you disconnect your battery and then reconnect itagain, it disables the radio. This is an anti-theft protection for your carradio.
The enable your radio the activation code is in your vehicle owner's manual. Ifyou do not have this code you need to go to your vehicle manufacturer's servicecentre and get them to enter this code for you.
Jul 31, 2012 | Cherokee Jeep Grand 2005-2007...
How do i install a blower motor in my 2007 jeep grand cherokee
Are you sure it's bad run jumper wires from battery and try it
  1. Disconnect and isolate the negative battery cable.
  2. Remove the instrument panel silencer from the passenger side of the instrument panel.
  3. Remove the glove box from the instrument panel.
  4. Disconnect the blower motor wire harness connector from the blower motor power module or resistor , depending on how equipped.
  5. Remove the three screws that secure the blower motor to the HVAC housing.
  6. Remove the blower motor from the HVAC housing
Dec 29, 2011 | Cherokee Jeep Grand 2005-2007...
I bought a cd player for my 94 grand cherokee and bought a wiring harness for the speakers. And. I want to kno which colors are the speaker wires
1994 Jeep Grand Cherokee Car Radio Stereo Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Violet/White
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Orange/Black
Car Stereo Dimmer Wire: Green/Red
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Blue
Right Rear Speaker Positive Wire (+): Blue/White
Right Rear Speaker Negative Wire (-): Blue/Orange
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
Dec 11, 2010 | Cherokee Jeep Grand 1994-1995 Radio...
I tried to install an aftermarket stereo in my 2005 jeep grand cherokee but it didnt work because i had the wrong wiring harness. but when i tried to put the factory stereo back in it wouldnt work either....
Check that the yellow and the red wires have power while accessories is on, using a test light or multimeter. If they both have power, check earth connection.
Aug 19, 2009 | 2005 Jeep Grand Cherokee
Installing an aftermarket CD player.
Go to a stereo sales & installation shop, or even auto parts places usually have them now too, and get an adapter harness for your particular vehicle. They plug directly in to your existing harness, then you simply wire your new stereo to it,via directions. Few bucks now, will save hours of aggravation later,.and if you decide to sell vehicle later, and put old one back in, it's all there to plug back in, nice & clean.
Mar 27, 2009 | 2005 Jeep Grand Cherokee
Car Audio & Video Logo
37 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
