Cant connect to dish
Tuner access code not valid cant connect to dish channels only go to 49 need 70 or 63
3 Suggested Answers
SOURCE: auto tuner provides different results at different times
Hi there you need a gold star arial or your signal (Azimuth window) is blocked (Trees, Building, arial has moved)
Posted on Nov 13, 2008
  • 1738 Answers
SOURCE: Need help hooking TV back
It is so hard to explain by over a few words. The best solution I have for you is remember this. What goes out from a device must goes into a device. A in device would be (television)
Posted on Nov 23, 2009
Emerson EWF2006 TV access code
if your tv doesnt have a digital tuner, you cant, unless you have a digital to analog tuner converter (can be purchased in walmart, or other stores that carry tv s, electronics) you tune your tv to 3 or 4, use the converter box to scan for channels, and for changing channels instead of your tv tuner
Mar 21, 2013 | Emerson EWF2004 20" TV
My tv is now saying "no signal" i was out of otwn for a few weeks and this is what had happened while I was gone. The dish network says it is not their issue that we are unable to get to cable...
If the TV needs to be on channel 73 [TV tuner] for the dish to work then do a channel serch in the tv's menu.
If you had a power outage when you were gone the TV will need this scan done.
Most sattelites use the inputs not the tuner. make sure your on the right input channel,
Jul 22, 2011 | RCA Televison & Video
Have new E370VL hooked up to Dish Network via coax. The picture jumps/blips? Connections are tight. Help.
This can happen when there is radio interference near the coaxial cables. Sometimes the interference is behind walls. The solution is to try a different combination of modulation and channel than what the DISH receiver is current set.
The DISH menu screen for this setting is Menu-6-1-5. With dual-tuner receivers, typically "TV 1 Out" is the TV that is connected in the same room as the receiver is located. "TV 2 Out" is the tuner that is fed to the remote TV via backfed coaxial signal.
All that needs to be done is to change the channel and mode going to the effected TV to something different. If your channel/mode is currently set to Air/60, try changing it to Cable/73. When you change the mode/channel in the DISH receiver, you need to set the remote TV to the same mode and channel.
Keep in mind that with some TV companies like VIZIO, they call their "Air" mode "Antenna". With VIZIO's the TV must be set on TV input and then go into the Menu to the Settings, Tuner Settings. Change mode type to match what you are trying on the DISH receiver, exit the VIZIO menu and manually enter the channel number.
Eventually with trial and error, you will find a mode/channel combination that isn't effected by your particular environmental interference.
Jan 03, 2011 | Televison & Video
No picture! The Dish TV guy programmed the tv on channel 60 but there is no picture. He said its a tuner problem in the tv. Any ideas on what could be wrong? Can the tuner be replaced or is it some other...
Wewould be happy to help get that fixed right away. The first thing we want toensure is that all connected equipment is on. You mentioned that your TV is on channel 60, to confirm this turn off the TV then turn is back on and note the channel or inputthat appears on screen when the TV is powered on, if the TV is not on channel60 or 73, tune to 60 or 73. Then Access "Modulator Setup" from TV1 by pressing"Menu", 6 for "System Setup", 1 for"Installation", then 5 for "Modulator Setup". Tune TV2 tothe channel that appears under "TV2Out" on screen. If still no picture and the mode for TV2 isset to "Cable", change it to "Air" and change the channel on yourTV2 to 60, if it is already set to "Air" then change it to"Cable" and change TV2 to channel 73. If the issue is only on one receiver, unplug the DISH receiverfor 10 seconds and plug back in. The next thing we want to check is theconnection on the back of your receiver labeled "Home Distribution",this cable carries the picture all the way to your TV2. Start by removing theconnection and screwing it back in, make sure all the connections going to yourTV2 are hand tight. These steps should get your TV2 up and running.
We want to thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Dec 02, 2010 | Toshiba 27A43 27" TV
Get dish network to work with hp SR5505F COMPAQ PRESARIO COMPUTER
You can not change channels on Satellite with your TV tuner card. The satellite box decodes the sat signal (it is sent encrypted) you can run S-Video/RCA/HDMI depending on the video card input, but you will be required to change the channel on the Dish box. The TV card can only change channels on broadcast (over the air) channels, you can attach an antenna and it will use the NTSC tuner to change analog channels (if they are still available) and the ATSC tuner to change digital/HD broadcast channels. This card (from your description can ONLY deal with broadcast TV, You will need a TV card with a QAM tuner for unscrambled digital cable. There is no solution for directly interfacing with Satellite on a PC or Mac (DirectTV or Dish) the signal from the satellite is encrypted and requires (at least for DirectTV, a fairly complicated decryption setup to function, this is handled by the tuner box/card combination. Sorry your setup will not support changing the channel on the PC, you may be able to find some kind of software that can utilize an IR transmitter to change the channels on your satellite box, similar to the way a Tivo or other DVR can talk to cable boxes, but that is the best you will be able to do as far as channel changing.
Jan 09, 2010 | HP Computers & Internet
Satellite dish icon unavailable so cant retune
Switch over to analogue and press menu, the Sat dish icon should be there, if its not there then the tuner board/video board may have gone faulty.
Sat icon is not available in DTV mode anyway...!
Thanks
Oct 01, 2009 | Televison & Video
No antenna tv signal
Your dish remote should be set to the code for your TV. Then you will be able to control the channel number, not just up/down, as well as volume and maybe even the input. But do try to get a real remote for your TV so you can get to its menus.
Meanwhile, use menu+menu to see the channel being output by the Dish receiver. (Must be a 622/722... based on the 60 you listed.) Try to find an unused UHF channel number that your set does have in its up/down list. Match Air/Cable setting of Dish and TV. The Dish output is analog (NTSC) although the tuner(s) only accept digital (ATSC).
-Ken
Jul 26, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Cnannel scan detects no channels
Kingscott,
Make sure the cable connection from the dish to the tv is
connected to the antenna/cable input and not the digital
input. Turn on the satellite receiver then auto program the
set with the receiver still on. If this fails to lock in channel
3 your suspicion regarding a faulty tuner could be correct.
A good way to check the tuner operation would be to hook
up another product such as a VCR with the rear switch set
for channel 3 and see if you can receive a picture from this
device. If it works the tuner is OK.
You can bypass the tuner by connecting an S-Video cable
and (or) a set of A/V (yellow,red & white) cables from the
output of the satellite receiver to the video 1 input on the tv.
You'll then have to switch the tv source mode to video 1.
Hope this of some help,
Caseybee
Mar 13, 2008 | LG 42LC2D 42 in. LCD HDTV
Television stays on one channel
You likely have bad solder connections in the tuner.
Jul 12, 2007 | Sony KV-35V75 35" TV
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Electro Med Services...
