Question about SanDisk 2GB microSD Memory Card
How do I add SecureAccess into Sandisk mini sd card
SecureAccess software came in my Sandisk USB flash drive, but not my Sandisk mini sd card, How do I add SecureAccess into my Sandisk mini sd card?
2gb memory card show only 121mb
Posted on May 09, 2014
5 Suggested Answers
randy320sgi
  • 121 Answers
SOURCE: SanDisk Cruzer stuck in USB drive
wayne_mcc,
So it is physically stuck in the port? If it has been in there for a long time it may have been bumped or jarred so it has lodged in , slight bend or angle would verify that that is the case. It is not rusted or that there is corrosion causing it to stick. Those drives are inexpensive and unless you have some pretty imprtant photos on it I wouldn't worry about gripping it with some small pliers and extracting it straight back, it may crush the mini but you will get it out. The TV is worth more than the cruzer so keep in mind the port can be replaced. You can get an adapter wtih a cable extension that allows you to plug in different USB devices or card readers that way it's "remote" from the TV itself that would make it easy to pop it out and change to something else.
randy320sgi
Posted on Jan 29, 2009
SOURCE: pc not recognizing sandisk micro sd
The Card Reader you are using is probably not compatible with SDHC Memory Cards (High Capacity SD). You may need to get an SCHC compatible reader or check the website for your product to see if the is a driver update. You can get a new reader for about $20 bones if needed. I had the same issue.
Posted on Jan 05, 2009
Dr_Joseph
  • 86 Answers
SOURCE: no private folder
those are the correct folders for the card.
your images are stored in DCIM folder
Posted on Jan 26, 2009
Geekman
  • 32281 Answers
SOURCE: Using a SanDisk Micro in a SanDisk adapter in a
Most SD memory cards have a tiny slide switch on the edge of the card. Move this slide switch from Read to Write to turn off the write protection.
Posted on Nov 12, 2010
How to remove write protection on my sandisk cruzer flash drive
I think the sandisk cruzer flash drive does not have a write protect switch. Please give more details about the product, model number etc. It could be possible that the "SanDisk SecureAccess software" provided with the flash drive could be protecting your drive. Open the associated application for findign out how to turn off write protection.
For more details check http://www.sandisk.in/products/usb/drives/
Sep 15, 2013 | SanDisk Computers & Internet
I want to reformat my sandisk micro mini sd card using my verizon lg
You can't, fdisk on Android phones has had that ability removed. Buy an usb to micro mini card adapter and format it on a computer. Much easier.
Dec 12, 2012 | Electronics - Others
How do i repair sandisk micro sd card
Hi....
If you lost your data from sandisk memory card then you can use one of the sandisk memory card recovery software that is available online in order to recover files from sandisk memory card.
Dec 06, 2012 | Samsung 8gb Micro Sd Memory Card 4 Galaxy...
How to remove write protect on my usb flash drive
Did the files come from another PC / user. If so, Win 7might require you take ownership. Right click > Security. Also some Micro SD cards attach to a regular SD adapter and that has a write protect small dip switch. Try that.
Aug 27, 2012 | SanDisk Cruzer Fit 8gb Usb Flash Pen Drive...
Data and bad sector Recovery software for 8 GB SAndisk
you can try some data recovery software. You can see
Recover data from memory card
It tells the steps how to perform data recovery.
If above does not work, you may have to format the memory card (use quick format), and then use above mentioned software to scan again the memory card and recover your files.
Jan 27, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Where can I insert my mini sandisk memorycard into my toshiba laptop? I see no slots for it.
If you have no SD slot on your laptop, you will have to buy an external USB SD reader. They typically cost $5-$10, and are readily available online (e.g. http://www.buy.com/prod/micro-sd-sdhc-card-usb-reader-for-1gb-2gb-4gb-8gb/q/sellerid/23962916/loc/101/213271933.html) or in almost any store with a good selection of electronics.
Dec 06, 2010 | SanDisk 2GB microSD Memory Card
Hi,ive just bought a t-flash usb 2.0 for downloding nintendo ds games,not sure if it is what i put on what product is it about, but how do i install it on my computer? i cant actually find where it is on...
Once you plug the mini sd card into the usb device and plug the usb device into your computer it should show up as a hard drive in your My Computer area. If not you may have to initialize the hard drive.
Good Luck,
NOLA Tech
Apr 07, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How do I remove write protection from micro scan disk chip?
if you will look into the side of your SD CARD. theres a small toggle switch there. just slide it to the other side inorder to disable the write protection
Apr 03, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I have a T-Mobile G1 with a micro sd card; trying to sync??
most mini sd cards come with a full-sized sd card adapter that the mini slips into. You can then slip that in your computer if you have an sd slot or sd reader.
You can also buy very inexpensively, a usb port mini sd reader that you can plug directly into your usb port on your computer. Then after you'v dragged and dropped the files, you can put the mini sd back in your phone.
Jun 16, 2009 | SanDisk 2GB microSD Memory Card
Softwear to install mini memory card reader
software comes with the card reader. if not contact vendor for supply of software
Nov 18, 2008 | SanDisk 2GB microSD Memory Card
SanDisk 2GB microSD Memory Card Logo
64 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
