Question about Goodman Heating & Cooling
5 ton goodman package unit not coming on
AC running fine. one day t-stat was blank but still lit. Turned everything off and replaced with honeywell t-stat. Got everything hooked up and date, temp was on all it. but still nothing comes on. this is a programmable honeywell RTH2300/RTH221. not sure if this works for a heat pump or not. Someone was saying to leave the blue wire (common) off of the thermostat.
  • 24 Answers
If you look on the install manual. It says it will work for a heat pump without backup heat. No heat strips.........If you do not have strips the guide says as follows
"PLACE A JUMPER (PIECE OF WIRE) BETWEEN Y AND W IF YOU ARE USING A HEAT PUMP WITHOUT AUXILIARY/BACKUP HEAT." if this dosnt work check the fuse in the air handler you may have blown it if you did not turn the unit off before installing.
Posted on May 15, 2014
  • 20 Answers
SOURCE: No heat new thermostat
you have a short in the wireing.disconnect at air handler and hook-up short t-stat wire to t-stat,ifok chk wire to condenser
Posted on Jan 10, 2009
mastatech
  • 478 Answers
SOURCE: Amana 1 ton Residential AC / Outside unit comes on for a sec
open the service panel to check for control voltage of 24volts when tstat calling, The contactor should be pulled in, if contactor is down,and contacts appear to be clean, and the unit is still not running, it is a bad compressor. to test this unplug the black wire from the compressoror at contactor,w/ power off! Turn on power if fan works normally it's a bad compressor. However if you see a swollen split cap(5 wires to a soup can looking w/ the terminal C,F,and Comp), switch it first and start at square one.
You also need to consider the high pressure switch if its cycling on off on off.
Posted on Mar 12, 2009
james3751
  • 614 Answers
SOURCE: i bought a new honeywell digital t stat, now i
Tou may ahve a two transformer system. On the sub base of the tstat there is tterminals rh and rc they come with a jumper wire between them. Remove jumper. Hook the two wires from your heat to rh and w. Hook the rest of the wires Red rc yellow to y green to g and blue or black to c. Thats it . Keep in touch and I will walk you thru this. Rus
Posted on Dec 16, 2009
  • 415 Answers
SOURCE: Goodman AC Unit with Heat Pump - Works great
Because the outdoor unit works in cooling, it sounds as though the contactor and other components outside are working correctly. The problem sounds as though it might be somewhere in your thermostat. Has the thermostat been replaced recently? If so, make sure it was wired correctly. If not, check all of the connections and contact points in your thermostat. In order for your outdoor unit to run, you must have 24vac at your "C" Common and "Y" connections. You must have this in COOL mode. Now it has to be determined why you don't have it in HEAT mode. Definitely a thermostat issue.
Hope this helps and good luck! :-)
Posted on Mar 07, 2010
james3751
  • 614 Answers
SOURCE: I am replacing a White
Yes you did correct. Tape of f blue wire. On your thermostat you should have el/gas turn top el and fan should work Russ
Posted on Mar 23, 2010
Goodman gph1348m41ac unit is blowing cool air in heat mode with mid 30s ambient outdoor temp. I turn it off then on and will usually blow warm air but this cycle is becoming more repetitive. any expert...
A heat pump on the optimal heating day (about 50 degrees ambient) will only deliver approximately 85 degree air as compared to 125 degree air from a fossil fueled furnace. The colder the outdoor air is the less heat there is available to be transferred to the living space. At 30 degrees, the heat transfer capability is getting close to negligible meaning the run cycles will be approaching continuous and eventually as the heat pump along cannot maintain setpoint, the outdoor stat or stats will bring on auxilliary heat in the air handler.
If your ambient temp is below the 'balance point' of the heat pump, the house temp will drop a little lower and most times energize the heat strips through the outdoor t-stat. Your outdoor stat could be set too low for the heat pump to carry the structure all the way down to the balance point so when you turn it off and back on, the lower indoor temp automatically brings on the heat pump plus a heat strip or two, thus the warmer air. Second stage on the stat satisfies due to the heat strip, drops them out of the circuit and the heat pump is left running on first stage heat delivering the perceived cold air.
Your outdoor stat could also be not functioning correctly and not allowing the heaters to come on until the system is turned back on reestablishing the two stage call for heat.
Tons of possibilities and not enough room to list....
Jan 01, 2015 | Goodman Manufacturing Goodman GPH1348M41 4...
I guess this is a heat pump unit, check the change over valve in the gas circuit, sounds like the solenoid on the valve is burnt out
Mar 24, 2014 | Heating & Cooling
Blower on heat pump blowing with no demand
There is a contact in the blower control card that can stick on. There is also a possibility that the green wire which starts the blower motor could be shorting out with the red wire somewhere inside the thermostat wire. If that is the problem, either pull new thermostat wire, (the rest of the insulation is probably breaking down) or there is some new red link controllers from Honeywell that will completely eliminate wire because the controls are all wireless.
Feb 05, 2014 | Goodman Manufacturing Goodman GPH1348H41...
I installed my new unit this summer and the ac worked fine, now the heater does not work
frist check that the thermostat and the mood is in right positions then check that thermostat give signal to Htr.if Htr is right ohms
Nov 11, 2013 | Goodman Manufacturing Goodman...
I have a 6 year old Goodman "GPG10481151A" single
try turning the t-stat all the way down then kill electricity to unit wait ten min and turn everything back on, see if this helps. let me know.
Mar 02, 2011 | Amana Heating & Cooling
AC unit is running, but the house doesn't get cooler.
a/c is either on or off,there no in between.check air filters make sure they are clean.also keep in mind a/c will only bring temp down about 15 degrees from outdoor temp
Jun 23, 2009 | Honeywell Electronic Programmable...
On ac side blower not starting, all the time and system freezes
Most motors have a thermal cut out that is internal. If the motor overheats, it will shut down. If the unit is freezing up, that would indicate that there isn't enough airflow over the coils or the unit is low on refrigerant. I had a unit that did this same exact thing and after replacing the blower motor and a sequencer, in the end it was the t-stat. You are describing the same exact symptoms and every time I would go out, the unit would work fine. I would suggest replacing the t-stat and then watch the unit. But make sure that the coils are clean and you are not restricting airflow over the coils. Hopefully one of the techs actually looked at the coils to determine if they needed to be pulled and cleaned. Hopefully this answers your question.
Apr 01, 2009 | Goodman Heating & Cooling
Gas Package Unit Keeps Running with all T- stat wires unpluged at the unit?
does that unit run heating or just the fan run? if just the fan you may have a bad fan thermostat
Oct 21, 2008 | Goodman CLQ36AR49 Air Conditioner
Will a th6220d1002 honeywell t-stat operate a 15ton rooftop unit?
The Honeywell pro6000 runs on 24 volt control voltage and can control a 15 ton rtu that uses the same ac voltage in its controls.
Jul 07, 2008 | Honeywell Heating & Cooling
Heating & Cooling Logo
132 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
