SOURCE: 85 Toyota Celica GT Headlights problem
There is a knob beside the headlights under the hood, fairly good sized, looks like rubber and you can manually turn down your headlights. That happened to my 86 Supra last year and the sync was just off and once I turned them down they started working perfectly. Hope this helps
SOURCE: im trying to get the timing marks aligned and dont
with the timing belt on the vehicle install the botton piece of the timing cover with crank pulley. line up the notch on the crank pulley with 0 on the timing cover for top dead center on the crank. then there is a small sight hole in the spokes on the camshaft timing gear. with the belt off the timing gear line up that sight hole with a notch behind the gear on the cylinder head. you will only be able to see the notch through the sight hole with a mirror. once these are lined up slide the belt back on the timing gear and recheck afterward. this the procedure for all 5s-fe motors
SOURCE: car alarm keeps going off for no reason
so car alarms will go off when the battery is about to die as a warning. try turning it off with your key fob
SOURCE: How do you replace the rear shocks in an 01 Toyota Celica gt
YOU HAVE TO REMOVE REAR SEAT CUSHION TO GET TO STRUT TOWERS.
SOURCE: I have a 2006 toyota
I would investigate the steering componants ... I saw one that had disengaged the upper and lower ball joints ( connecting the wheel and spindle to the control arms) and had the same symptoms... loose feeling steering once in a while... clicking....
Have it inspected.... seriously !
apologies for the poor grammar
