Question about Jabra CRUISER2 Bluetooth Speakerphone
Samsung s3 wont connect to jensen car stereo (vm9214bt)
Samsung wont recognize Jensen stereo
Can you give me the code for a samsung dvd, my remote control is a Jensen JER321, Thanksss!!!!
Hello
Check with [0573]. This is the only code given by Jensen with Samsung DVD. OK
Aug 14, 2011 | Jensen 143307 Remote Control
I need to know where the ground wire goes in the pinout connector for jensen mp5610
All car stereo's are internaly grounded, so just connect the ground wire to the stereo chasis.
Jul 12, 2011 | Jensen MP5610 CD Player
I have a jensen uv10 and how do i connect my bluetooth when the picture under the soure is not lite and wont let me click on it
You actually have to purchase the bluetooth module seperate, its just a box that clips to you're visor and has a microphone and a connect button on it. It has one cable which is ran to the back of your stereo. The one made for the uv10 is called the btm10. However I have found that the btm15 works much better and has 2 microphones in it (one for calling and one for voice searching). You can find these on amazon and also jensen.com the price range runs from $40.00-$80.00......... Hope this helps you out...
Dec 16, 2010 | Jensen VM9510 Car DVD Player
Jensen car stereo VM9022 has a password Need to bypass it
call Jensen at 1800-323-4815 they will give you the code
Mar 14, 2010 | Jensen Car Audio & Video
Jensen vm9412 and ipod classic
The newer generation iPods don't always work with the iPod connection kits in a lot of the car stereos. Some of the problem is due to the fact that the new generation iPods have been changed and the stereos were manufactured before the players were released so they are not compatible.
I bought my girlfriend a Pioneer car stereo with an iPod control cable, and it works fine with her Nano (not the new generation Nano) and it works with my iPod Photo 60 GB but it does not work with my iPhone 2G and I read that it is not compatible with the new Nanos or the Classics. Check with Jensen to see if the model you have is compatible with the Classic and see if there is a solution to the issue. It may not be compatible with the new video portion of the Classic firmware.
Cheers
Aug 20, 2008 | Jensen VM9510 Car DVD Player
Wont turn on
check your fuses and all connections, make sure you have a good ground to the stereo and make sure the yellow and red positive wires are not loose!
Jul 19, 2008 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Jensen 9412
how can I restar a stereo car jensen vm9412
May 29, 2008 | Jensen VM9510 Car DVD Player
Jabra CRUISER2 Bluetooth Speakerphone Logo
Top Jabra Home Security Experts
Lawrence Oravetz
Are you a Jabra Home Security Expert? Answer questions, earn points and help others
