Question about Sharper Image The Wireless Headphones Shp921
SHP921 Sharper Image Wireless Headphones
I cannot get the headphones to work with the TV anymore like it did in the beginning. I only get music and rather poorly, too. I lost the manual so I cannot find out what I am doing wrong. Please help. Juliana Bradshaw
  • Juliana Bradshaw
    Juliana Bradshaw Mar 27, 2014
    There is nothing more that I can add other than what I have told you. These headphones do not work. All I get is static when trying to play anything. The radio or the TV. It worked in the beginning but than one night it just stopped. What is can be said? Do we need to purchase a new headphone? How can I get a manual for this headphone so that maybe I can fix it myself.
Noggin
  • 944 Answers
SOURCE: Sharper Image GT113 Beetle Clock radio
Sorry, no luck with a manual for the GT113, here is the link for the manual for it's replacement, the GT806; http://www.sharperimage.com/us/en/catalog/productdetails/sku__GT806 Check page 16 - hopefully the process is the same on your model for the alarm - other features are definitely different. Please ask again if this doesn't work. Hope this helps :)
Posted on Jul 15, 2007
SOURCE: I have a sharper Image mp3 player cant figure out
With music (or whatever)playing hold down V button (left hand side of control circle)til volume adjustment screen comes up-a blinking speaker. Press PRE or NEXT button (top and bottom arrows) to adjust volume.
Posted on Mar 22, 2009
  • 3 Answers
SOURCE: need a user manual for Sharper Image MP3 player
This is the direct link to the pdf of the manual http://www.mscustomercare.com/forms/MP3_Camera_IM.pdf
:D
Posted on Apr 06, 2009
SOURCE: The Sharper Image 2GB Mp3 (1612788) Is Not Copying Music Files
The Sharper image 2gb player will only allow 131 entries in the root directory. Create a new folder, just like on your computer, and then add music files to that folder. I have not tested if there is a file limit in a new folder.
Posted on Jul 01, 2009
SOURCE: the sharper image mp3 player
how do u turn the volume up
I can't get sound through my headphones on my Bravia kdl-52xbr5 tv. First time I have tried to hook up the headphones which are sharper image wireless
I take it the headphones are charged up and known to be in good working order? Are you using the 3.5mm headphone jack on the side of the TV or the white and red RCA jacks labeled AUDIO OUT (VAR/FIX)? If using the headphone jack the TV should shut off the internal speakers and output to the headphones. If using the mentioned RCA jacks you need to go into the audio options settings and set to Audio System. Also under audio settings, Audio Out, you can pick Fixed or Variable. If you opt for Fixed you will use the headphones to adjust the volume. If you opt for Variable you can control the headphone volume and muting using your TV remote control. Just make sure you have the headphone volume turned up adequately.
Dec 16, 2016 | Sony KDL-52XBR5 52 in. LCD HDTV
How do wireless headphones work
Wireless head phones works on principle of wireless technology.
The phone has a reciver and tv or Audio system has a transmitter ,.
WiFi/blue tooth are examples.
Feb 15, 2014 | Sony Audio Players & Recorders
Sylvania wireless headphones
Instructions
Set up the transmitter. Wireless headphones rely on a transmitter that sends audio via infrared or radio waves to your headset. Use the digital audio output (coaxial or optical), RCA outputs (red and white) or headphone jack on your TV to connect the transmitter. The connection will depend upon which outputs are available on your TV and/or the transmitter.
Use an RCA-to-headphone adapter. If you don't have a headphone jack on your TV and the transmitter includes only a headphone connection, connect an RCA-to-female headphone connector. This will allow you to plug the wireless transmitter into the female headphone end and then hook the RCA ends into your television's audio outputs. You may also need a 3.5 mm (mini jack)-to-1/4-inch adapter if the headphone plug on the transmitter doesn't match the television jack.
Read more : http://www.ehow.com/how_4883556_use-wireless-headphones-tv.html
Set the transmitter on top of, or next to, the television. For infrared transmitters, you'll need a direct path between the headphones and the transmitter. Placing the transmitter on or near the TV will allow you to take advantage of the clear path you already have.
Plug in the transmitter and turn it on. Charge the headphones if necessary.
5
Turn on the headphones. Adjust the volume and settings and you're ready to watch TV.
good luck
Nov 14, 2013 | Sylvania SYL-WH930GB Wireless Headphones
How do you connect the wires to the tv
you have to get adapter cables. Check with Best Buy, they'll be able to get you the right cables/adapters
Jan 09, 2011 | Sharper Image (CT411) Consumer Headphones
Left side of my sharper image ct411 doesn't work at all.
Check your cable and make sure there aren't any frayed or cut wires. If your cable looks good, then open up your headphones and make sure the connection to each speaker is correctly soldered. Sometimes when you expand/contract the size setting on these headphones it pulls the wire until it eventually disconnects. I hope this helps!
Aug 31, 2010 | Sharper Image (CT411) Consumer Headphones
Sharper Image CT411 head set batteries?
you peal off the soft part of the headphones that cover your ear you'll see the battery compartment from there
Feb 25, 2009 | Sharper Image (CT411) Consumer Headphones
Batteries
You need to remove the rubber on each side of the headset - and you will need to replace one "AAA" battery on each side - hope this helps
Aug 25, 2008 | Sharper Image (CT411) Consumer Headphones
Sharper Image The Wireless Headphones Shp921 Logo
53 people viewed this question
Top Sharper Image Audio Players & Recorders Experts
Tom Chichester
Yoav Shilon
Yoav Shilon
Are you a Sharper Image Audio Player and Recorder Expert? Answer questions, earn points and help others
