Question about 2000 Mercedes-Benz C-Class - C230 Kompressor, without S/Lev - Pro-Spacers
DEAD BATTERY DON'T HAVE KEY
CAN'T GET IN AT ALL
  • 58 Answers
Break a window or call locksmith. Not much else for choices
Posted on Mar 26, 2014
When i put my key in the switch it wont turn on
Make sure its In park . Recharge battery first
Feb 13, 2015 | 2002 Jeep Grand Cherokee
The 'key in ignition' warning sound won't turn off and my battery went dead. How do I get it to turn off?
Pull the Battery Post off the Battery then the fuse If that don,t work Cut the Horn Wire To It
Mar 04, 2013 | 2004 Ford Windstar
How to open trunk without key WHEN BATTERY IS DEAD I TRIED THE CIGERTE LIGHTER JUMPER CABLES IT DID NOT WORK I HAVE A 04 LINCOLN LS
Read my other post to your other question
If the doors are open,drop the back right seat back,
& crawl into trunk & pull the yellow release tab
OBD2 Vehicles do not use the lighter for battery voltage,
that was obd 1 systems ,the power is in the diagnostic connecter
by your right knee,need adapter to use battery KAM memory
back -up
The seat may only be released from the trunk--.have to check my 2004 LS
Feb 07, 2013 | 2004 Lincoln LS
Had dead battery put new battery in and now the ac works but no air comes out of 4 dash vents. Checked fuse and relay. What next can I do?
When the battery was reconnected, the HVAC went through a recalibration, sometimes this caused the door actuators or the door gears to break or get stuck. Try the following; with the key ON, set all HVAC controls and switches to their OFF or CCW position, key OFF, disconnect battery and reconnect. Set key to ON (don't have to start vehicle) and don't touch any HVAC controls for about 2 minutes. Then try HVAC operation, if vents still don't work, you will need to have a mechanic look at it. Attached is a diagram of the actuator locations.
Aug 30, 2011 | 2004 GMC Envoy
I towed my car on a car carrier across country 6 mos ago. After loading the car and starting out the alarm went off. I shut it off using the key and no further problems. Shortly after arriving at my...
Disconnect the positive lead of the battery and hook a simple test light from that lead to the positive post of the battery. The light will come one for a second and go out. If it stays on you can start looking for the short by one by one pulling fuses going to circuits that don't need the keys to work. The frist thing befiore starting this test is to unplug the hood light if you have one. If the courtesy light isn't the problem, pull that fuse and you can do the rest of the testing with the doros open. Good luck.
Jul 09, 2011 | 2001 Mercedes-Benz C-Class
I left my trunk door open all night and my battery died. I thought the key I use for the ignition would be the same key to unlock the door if the battery died? How do I enter my 2006 Dodge stratus with the...
Thank you for contacting fixya.com.
The key lock/unlock for doors are powered by the batteries in the remote, while the ignition key draws its energy from the vehicle via induction. Since the battery is dead you are having this problem. You need to call assistance from the nearby auto shop or a locksmith. I guess you don't have any other option.
Jun 27, 2011 | 2006 Dodge Stratus
98 celica battery went dead replaced now it want crank
Try this: Unhook the battery. Reconnect the battery. When the horn starts to beep, cycle the ignition key in the ignition on-off 5 times. This resets the alarm; the cycling of the key. Please advise me if this works for you.
Oct 07, 2008 | 1998 Toyota Celica
2000 Mercedes-Benz C-Class - C230 Kompressor, without S/Lev - Pro-Spacers Logo
51 people viewed this question
Top Eibach Vehicle Parts & Accessories Experts
Timllfixit
 Mikey
Mikey
ray012965
Are you an Eibach Vehicle Part and Accessory Expert? Answer questions, earn points and help others
