Question about Sharper Image The Wireless Headphones Shp921
Headphones are not working properly
The headphones only plays music, rather poorly, whether I have it set on R or H. The box also says that it needs to run on 4 AAA batterries. There is only room for two. What can be done? julianabradshaw72@yahoo.com
Can't get headphones to work on this unit
Aux-in jack is used to play another device such as an Ipod or other sources through your Jensen player, using it as some sort of an amplifier. Look for another port on your Jensen player that says "audio out" or "Spkr" (means speakers) to plug in her headphones. If you can't find any of these ports then you might have purchased a n actual boom box, which does not have the capability to play through headphones, sorry about that.
Dec 28, 2013 | Jensen cd-472-bk am/fm cd boom box
My ipod nano has songs but no sounds
Step 1:
Since entering the marketplace and revolutionizing the way people experienced personal audio, Apple's iPod has become the unquestioned leader in MP3 players. Available in several different models and versions including the original iPod, iPhone, iPod Nano and iPod Touch the iPod allows people to listen to any number of songs with just the click of the button. However, as is the case with numerous electronics, certain iPod users encounter issues with their device, particularly sound issues. These issues range from buzzing sounds through the headphones to low volume quality to no sound at all. Fortunately, there are ways to attempt to remedy these sound issues.
Volume and Song Selection Oftentimes, those iPod users listening to heavier music (such as rock or hip-hop) will encounter a buzzing noise when playing their device at maximum or near-maximum volume. Try lowering the volume a bit, as this will most likely remedy your buzzing issues. Also, try playing a different song from a different artist at the same volume to ensure sound quality is optimal across the board. Check the Headphones Before attempting to diagnose an iPod's sound issues, ensure the iPod itself (and not the headphones) are the culprit for these sound issues. Do so by disconnecting headphones from the iPod and playing them on another device, such as another iPod, a PC or laptop. If the quality is still not optimal, the headphones (not the iPod) are likely the reason for low sound quality. Also try connecting an iPod to an iPod listening dock. If the sound quality is optimal, but not so when connected to headphones, that would also indicate headphones as the cause of low sound quality. b> Reset the iPod Sometimes, simply resetting an electronic device such as an iPod, digital cable box or video game system will remedy the solution, as it gives the device a chance to reboot. Try resetting the iPod to remedy whatever sound problem you may be encountering, whether it's no sound or less-than-optimal sound. Not all iPods are reset the same way, so consult the user manual (either paper form or through Apple.com support) to learn how to reset a particular type of iPod. Adjust Sound Settings If sound quality is less than optimal, including too much bass, not enough bass, poor acoustics or any number of other issues, try altering an iPod's system settings to correct the issue. Do so by going to the "Settings" key on the main iPod menu, then going to "EQ." From there, test certain settings to see if they may correct the iPod's issue. EQ settings allow users to set their music to a certain type of genre (in terms of how the music is delivered), as well as lowering bass, increasing bass and altering acoustics. b> Make Sure Headphones Are Fully Connected As simple as it sounds, sometimes the reason iPods have no sound at all is because their headphones become somewhat detached from the device. Such is the case with physical activities such as exercising or doing yard work. If no sound comes through the iPod, make sure the headphones are plugged in all the way to ensure the lack of sound is not a simple oversight. Consult Apple Support Whatever the sound issue, if iPod users have tried everything possible to remedy the problem with no results, they can call Apple support or visit an Apple retailer to help further diagnose the issue. The issue could be a simple fix or might be so severe that purchasing a new iPod is the best course to travel.
Feb 09, 2013 | Apple iPod nano 3rd Generation
There is no sound coming out of wave 3 music system, while playing CD , FM, AUX in. How to fix the issue ?
I have a similar as gift, big size remote, you havent mentioned that whether ur using an adapter 110volts or else it still would have worked but would short circuit after some use.
Oct 10, 2012 | Bose Wave Music System III - Graphite Gray
Sound works for radio not for music volume is up music is playing no sound from any headphones
Did you try plugging in a different set of headphones? If other headphones work, maybe you need new headphones.
Try playing music from your Sansa through the computer, while it is tethered. If you can do this, it may mean that the audio amplifier part of the Sansa is broken-- Usually this means, 'get another Sansa.'
Also, try gently wiggling the headphone plug to the left and right, while it is plugged in. If you get music on and off, its possible that the headphone connector on your Sansa has a broken connection. This is a VERY difficult problem to fix (without breaking or melting something else inside the case) and also usually means it is time to get another MP3 player.
Nov 07, 2011 | SanDisk Sansa Clip MP3 Player
Everytime i plug my headphones into the phone to listen to music it plays through the speaker not the headphones
check whether headphone is plugged correctly - clean the contacts of the headphone jack and the jack base of the phone.
Mar 03, 2011 | Cell Phones
No music playing in headphones
Hello.
Try to adjust the headphone.
Check if it is connected properly.
If it still doesn't work, try to check the headphone on other devices.
If the headphone is working on other devices, your MP3 headphone jack has some problem.
But if the headphone is not working on other devices, you should get new headphone or you can try other headphone (besides your current one) on your MP3.
hope it helps.
Jun 09, 2010 | Coby MP-610 MP3 Player
How do you make your music go through the headphones instead of the phone speaker on a Nokia 5310?
in music window select option then scroll down till you reach headphones select and the music will be played through headphones, BUT make sure that the headphones are inserted properly
Oct 25, 2009 | Nokia 5130 Cellular Phone
Music from my dare only plays out of one headphone
To reset it just reverse what you did before it went out, example, headphones plug in and it comes out real quick now theres no sound, turn off the phone and plug the headphones back in and turn on phone with headset in 3.5mm jack then unplug after phone has fully rebooted and ready for use.Trust this works cause i ve done it a many of time since i hooked it up to my car to listen to music. ps did you know you can change the sound effects under the menu while the music is playing to different types of bass levels.
Jun 11, 2009 | LG Dare VX9700 Cell Phone
Only playing music on the right speaker
Its the headphones, It happened to me a new set of headphones worked.
Feb 23, 2009 | RCA M4208 MP3 Player
Sharper Image The Wireless Headphones Shp921 Logo
Top Sharper Image Audio Players & Recorders Experts
woodzowl307
Tom Chichester
Are you a Sharper Image Audio Player and Recorder Expert? Answer questions, earn points and help others
