Question about Panasonic Viera TH-42PX80U Plasma TV
Need to change the main board
My model is: TH 42PX80X (TNPH 0716) SERIE 0378
    Top Expert:
  • Panasonic Master
  • 74,887 Answers
Hi
After changing the main board, you should have to update its firmware. Without this, it won't work properly. Changing motherboard is an easy thing, but the firmware update is crucial. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Posted on Mar 25, 2014
Konka led TV, black screen, no back light. What's th problem? Please
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Nov 24, 2016 | Konka Televison & Video
Panasonic tv model Th-42pd60u turns on after awhile picture disappears but you can still hear the sound
Oct 01, 2016 | Panasonic Televison & Video
Problem with the main board
The "Main" board or Control Board has the input connectors on it with the interface connectors that go to the other high voltage panels. Bottom right hand side looking from the rear of the TV. Why would you want to change that panel? The YSUS board is the usual faulty panel. 6 - 8 flashing lights.
Mar 25, 2014 | Panasonic Viera TH-42PX80U Plasma TV
Are the tnph0716abs and the tnph0716ads A boards compatible?
no they two boards are slightly fifferent and will not interchange with each other. You should be able to get the proper board for your model from www.tvrepairworld.com
May 16, 2012 | Panasonic Televison & Video
My viera th42px77u changes colors - yellows to pink, all the skin tones very pink and greens where there should not be green.
Likely it is the "main" board that processes all signal although unlikely it could also be an issue with the power supply board.
If you GOOGLE the model number with "circuit boards" and or parts you will get an idea of what the parts cost may be but labor is another issue.
Mar 22, 2012 | Panasonic Televison & Video
I HAVE A PANASONIC TH-50PX75U TV THAT AFTER UNPLUGGING AND REPLUGGING THE SET IT WILL NOT TURN ON. THE RED LIGHT IN THE FRONT BLINKS, BUT NO PICTURE OR SOUND. I CHANGED THE BATTERIES IN THE REMOTE BUT IT...
The tv power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Try website like Ebay.com to buy a refurbish power supply board for the replacement.
Feb 05, 2011 | Panasonic TH-50PX75U Plasma HDTV
I HAVE A PANASONIC PLASMA WONT COME ON, ONLY SOLID RED, I REPLACE THE POWER SUPPLY NO LUCK MODEL:TH-42PD25 OCT,2004 DOES ANYBODY KNOWS WHATS WRONG WITH IT
Hi
If you have changed your power supply then there is only one thing this can really be down to and i would say that is the main AV board as this sends a signal back to the power supply to tell it to turn on.
You AV board is the one with the scarts etc... This board also causes other problems of your TV powering up but no picture and no functions will work.
Change this board and im sure your problem will be solved.
There are no other boards in this set that control the start up side,so if you have changed the poiwer supply then it will be this board that needs replacing.
Hope this helps
Feb 02, 2011 | Panasonic TH-42PD25U/P 42 in. Plasma EDTV
My panasonic television's power light is flashing. Model TH-42PZ8OU The television won't respond to controlers or power button. Please help
Power supply or main board would cause this problem. You will need to check the caps on the power supply and test the voltages. If power supply is good replace the main board.
Jul 11, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
Replace conversion board
Signal / Main PC board AKA the "A" board is send for repair only = PTS corp ....Part # TNPH 0370.....250.00 Approx.
OR
Replace IC7001 & 7002....STK392-110 and inspect resistors.
If you have good electronic repair skills,you might attempt to
DIY...otherwise, hire a senior tech,if possible...............T.
Feb 06, 2008 | Televison & Video
Panasonic Viera TH-42PX80U Plasma TV Logo
101 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
