Question about E-Machines emachines (emachinees) CD-ROM Drive
Have an emachine suddenly both cdrom are missing. tried reloading from a clean machine, still unable to see any cdroms. now I cannot even boot up on any OS windows ME
    Problem Solver:
  • 13 Answers
You have to check if the setup of both cd if they are Master or slave or cable , and check the cable that connect to cd before you load windows
Posted on Jul 07, 2009
How do i get missing ntldr back
you are missing a key boot file for windows that is special to XP.
Load your installation disk.
restart your computer and when the F2 setup appears in right bottom corner (right after starting) press the F8 key (couple of times) and choose CDrom drive. (if you miss, try CTRL ALT DELETE--to reboot and try again.
(if that does not work, you will have to go into F2 setup and tell the computer to boot from the CDROM--you will find it by looking on each tab for a list of CDROM, Hard Drive, and listing of boot disk priority. Save you change by exiting BIOS set with F10.
At this point you can choose R for repair.
windows should repair itself. Once done, PC will reboot and you should be good.
** if other files are suddenly missing or other weird things, I would recommend a new install of windows. You should have up to date files for antivirus and malware.
Jul 14, 2014 | Dell Latitude D 600/610
Emachine cd tray stuck closed
Hi beverlylu328,
It seems like your cd tray has already a defective mechanism.
If a cd was stuck in your cdrom, use the safety eject pin included in the cdrom package.
You can use this even your PC is turned off.
I strongly suggest to replace your cdrom with new one.
Hope this helps you a lot.
Thank you for using FixYa!
Oct 31, 2011 | E-Machines emachines (emachinees) CD-ROM...
We had windows vista changed it to windows 7 and now it wont go passed the screen that says systen recovery options. what can i do
Hi ,
Ok , the first thing you need to do is reload win 7 , so put in a bootable cd in your cdrom and let the computer boot from it , if you dont have the disk and dowloaded win7 , then you'll need to get a bootable disk even if you have vista bootable disk , use that then redownload win7 , if you need more help , let me know and i will advise futher ...............Good Luck Roy
Aug 29, 2011 | E-Machines eMachines Desktop PC
Can I boot my e-machine M6810 from a usb cdrom drive? My build in cdrom fell apart and my usb cdrom works when the computer is on, but I can't seem to boot from the new cdrom I have tried changing the...
in short - yes! any e-machine, or indeed any computer build in last 5 years can be boot-up from usb port.
you need to enter bios and setu-up as first boot-up device "other", "boot from another devices", i do not remember which one is actually in this particular bios
plug in your external usb cd-rom, or indeed bootable usb-memory or bootable hdd and they should boot and work as they are on the computer.
another issue, internal cd-rom cannot be really disabled as only mechanical, external part stop working, it' logic part is still there and cmoputer therefore "see" it. you can disable it by downloading newest bios which have bit more power and tweaks than old one.
Jul 26, 2010 | E-Machines M6810 Notebook
I am unable to bot windows7. sudden failure
hi,
change the boot order so the CDROM is bootable first,
Insert your Win7 disk and boot off that , you will now seethe repair options.
Regards
GeWiz.
Dec 10, 2009 | HP Computers & Internet
Can't boot with Cd-Rom unable to install windows XP
Well, maybe I can try, thus in your bios setting you can boot using usb cdrom? Or maybe its time to change your cdrom drive already. If you can borrow a good spare cdrom. Take this in for the meantime in exchange for your installed cdrom. Maybe your cdrom drive is faulty. Then if this is ok, it is now easy for you to get on.
Second option, you can take out your harddrive prime it, then have a partition (say d:\) with a copy of full copy of xp installer, and other important installer just have it foldered. Then I assume you can boot using a floppy drive with win98 rescue disk. After booting goto harddrive partition with xp installer. then click setup and set it up in c:\ . Then your go other software, installed it manually.
I do this coz it much faster to installed using harddrive and also it is only in xp.
Hope this helps. comments if I miss something.
May 05, 2009 | Microsoft Windows XP Home Edition
Only getting EMachines/Windows XP Logo when boot up T3882
you have not set the cdrom as first boot device in the bios (press F2 or Del on boot up to get in bios), choose cd as first boot device, save settings and restart the pc with your cd in the drive and then when prompted press enter
Aug 18, 2008 | E-Machines eMachines Desktop PC
I am unable to boot my system through cdrom drive
Is the bios set to Boot to the cdrom? Enter the bios, go to Boot. Move cdrom to number 1. Save & exit.
Jan 17, 2008 | EliteGroup ECS 755-A2 Motherboard
I am not able to boot from cdrom of my system
Enter pc bios. can you see your cdrom listed in the MAIN menue? Goto Boot. Set your cdrom to first boot device.
Make sure you have a bootable CD in the cdrom. Still can't boot to the cdrom? Think about swapping it out or getting a new one.
Jan 17, 2008 | MSI KM4M-L Motherboard
Start up mode
I'd just do a factory disk reload for all your drivers and programs. Sounds like ddl are missing. Good luck.
Ed
NC Electronic
Mills, Wyoming
Jan 05, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
139 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
