Question about Jensen Phase Linear UV10
Opening the unit to replace the cable to the dispaly
You can remove all the outside screws to this unit but the darn thing will not open. So how does one open this device without some formal instructions? Thanks.
How do i install the darning foot?
Make sure that you have a darning foot that is compatible with your machine. I believe that the 7422 is a low shank foot; the appropriate daning foot is http://www.sewingpartsonline.com/darning-foot-singer-006016008.aspx . Lift the presser foot and remove the foot currently on the machine, including the ankle. (Loosen the screw on the left side of the ankle.)
Place the darning plate over the regular plate and feed dogs. The pins should lock into the spots on the machine.
Place the U-shaped opening of the darning foot over the screw that you loosened previously. Then tighten the screw to hold the foot on the machine.
Lower the presser foot onto your fabric. Set your stitch length. Lower the lever on the right side of the darning foot and hold onto your top thread (assuming the needle and bobbin thread are already threaded.) Now sew.
I hope this helps.
Aug 10, 2011 | Singer 7422
I recently purchased a 2001 Crown Victoria P-71. It came woth a bullet hole through the speedometer and windshield. I have had the windshield replaced, but need help replacing the speedometer. How do I...
open the screws of cover of speedometer and pull it and release the locks then open the screws of speedometer and ungrip the cables. simple thing do not b afraid of opening it nothing will happen.
Aug 01, 2010 | 1991 Ford LTD Crown Victoria
Door lock assembly
Toyota Corolla 1988-1997 Repair Guide Door Locks - REMOVAL & INSTALLATION
(see Figure 1)
  1. Disconnect the negative battery cable.
  2. Remove the door panel and watershield. Remove the service hole cover.
  3. Disconnect the door outside opening linkage. Remove the two mounting bolts and remove the door handle if in need of replacement.
Fig. 1: Power door lock control system component locations
  1. Disconnect the lock cylinder control linkage.
  2. Remove the lock knob and the child protector lock lever knob.
  3. Remove the lock assembly retaining screws and remove the door lock. If equipped with power locks, disconnect the electrical harness.
  4. To remove the lock cylinder, remove the lock cylinder retaining clip and pull the cylinder from the door.
To install:
  1. Coat all the door lock sliding surfaces with multi-purpose grease.
  2. Install the outside handle with the two retaining bolts, if removed.
  3. Install the door lock solenoid linkage to the door lock.
  4. Connect the link to the outside handle.
  5. Install the lock knob and the child protector lock lever knob.
  6. Install the door opening control link tighten the mounting bolts to 48 inch lbs. (5 Nm).
  7. Install the door lock cylinder control linkage.
  8. Install the door panel and watershield.
  9. Reconnect the negative battery cable.
Hope help with this; remember rated this post and thank you for using Fixya.
May 20, 2010 | 1991 Toyota Corolla
How to replace a window on a 2002 saturn sl2 with power windows. i cant get the door handle assembly off
As per the Haynes manual for your vehicle.
DOOR WINDOW GLASS-REMOVAL AND INSTALLATION:
1. Remove the door outer panal.
2. Lower the window glass.
3. remove the two nuts and one screw securing the glass.
4. Remove the glass by lifting it up carefully and rotating it inward.
5. Installation is reversal of removal.
DOOR OUTER PANAL-REMOVAL AND INSTALLATION:
1. Remove door trim panal.
2. Remove the outside mirror. Remove the foam block from the mirror opening.
3. Remove the outside door handle.
4. Open the door and pry thhe outer sealing strip out of the window glass opening.
5. remove the door panal screws.
6. Detach the front and rear of the outer panel, then lift it toward the rear to remove it.
7. Installation is the reverse of the removal procedure. Apply thread locking compound to the panel retaining screws.
OUTSIDE DOOR HANDLE-REMOVAL:
1. Pull handle out and puch the centers of the retaining pins through the pins, then remove them and detach handle. (These pins are located underneath the handle.
Hope this helps, let me know if you need any other help.
Feb 06, 2010 | 2002 Saturn L-Series
Popping harman kardon subwoofer
Mine did the same thing all of a sudden. The problem is a AC mains detection circuit that seems to affect many previous HK sub models. The solution that worked for me was to replace capacitor C112 on the main pcb of the subwoofer amplifier. You need to remove it from the circuit board with a soldering gun and replace it with a higher rated capacitor. I used a 2u2 40v and the subwoofer is working perfectly again! :)
Dec 23, 2009 | Harman Kardon HKTS 12 System
Disc tray keeps opening/closing on DVD recorder
my dvd player sony cinema entertainment system dav-dz111 the tray is opening again after closing
Sep 22, 2009 | Televison & Video
How do I remove the left side mirrer on my 2000 ford explorer?
Mirror — Outside Rear View Removal
NOTE: Do not remove the exterior mirror assembly when repairing an individual part. Individual components can be installed without removing the exterior mirror.
  1. Disconnect the battery ground cable (14301).
  1. Remove the front door trim panel; refer to Section 501-05.
  1. Remove the speaker.
    1. Remove the screws.
    1. Disconnect the electrical connector.
  1. Remove the outside rear view mirror (17682).
    1. Disconnect the power mirror wiring clips.
    1. Remove the outside rear view mirror nuts.
    1. Remove the outside rear view mirror.
      • Feed the power mirror wiring through the opening in the front door (20124).
Installation
  1. NOTE: When the battery (10655) is disconnected and reconnected, some abnormal drive symptoms may occur while the vehicle relearns its adaptive strategy. The vehicle may need to be driven 16 km (10 mi) or more to relearn the strategy.
    To install, reverse the removal procedure.
May 29, 2009 | 2000 Ford Explorer
Changing the headlamp in a 1998 firebird
You have to take off the bumper to get access to head light
Jan 23, 2009 | 1998 Pontiac Firebird
2004 A4 Tail Light replacement.
If you are still looking for the resolution, it's really pretty simple. It is highly recommended that you remove one light assembly at a time, thus allowing you to have a good guide when repositioning the assembly back on the vehicle body. Yes, the only way to get to the burned out bulb in the taillight is to remove the whole darn thing! The bulb burns out every 4-5 months, so I have become good at it...Here goes:
1. Open trunk. Look for small (3" diameter) cutouts in the fabric panel in the trunk liner. They are identical and appear next to the taillight assemblies, on the side, not behind the taillight.
2. Gently use a flat blade screwdriver and pry them open. These cutouts are attached to the inner trunk liner fabric, so be gentle.
3. Notice the phillips head screw inside the opening. Unscrew it slowly, making sure it doesn't drop between the chassis and the trunk liner. Remove the screw.
4. Place soft towel on the outside of the car under the taillight assembly, to prevent scratching the car bumper.
5. Gently grab both sides of the taillight assembly from the outside and pull away from the car (rear direction. Be careful not to pull too hard, or the wiring harness behind the assembly may break.
6. You can now access all lamp in the taillight assembly. Change the bulbs as needed. Also, if you can vacuum or clean the dirt on the chassis as well as on the back side of the taillight assembly, you'll feel better later :-)
7. Placing the taillight assembly back in its place is a bit tricky. It seems to go back easily, but the rubber lining nearest to the trunk opening and where the phillips head screw is, must be placed exactly right or water will leak behind the assembly.
8. Screw in the phillips head screw, but don't overtighten it. You will need to open it every 4-5 months to replace another bulb (its an Audi-VW plan to sell more bulbs).
9. Snap the trunk liner caps back in place and voila, you have done it.
Aug 13, 2008 | 2004 Audi A4
I ordered a new bellow for my whirpool duet front loader washer. where can i find out how to replace the part. when the part came from the internet, there weren't any instructions. i want to replace the...
ok karl remove front spring around front outside of bellows pull bellows away from inlet tube on upper right corner is a screw 7 mm i believe although 9/32 will work losen screw and remove band through front opening remove boot reinstall in reverse ..have fun getting bellows around drum opening takes a little patience and putting outside spring back on can break a nail
Jun 18, 2008 | Washing Machines
Jensen Phase Linear UV10 Logo
43 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
