Question about Garden
Cutting belt set up
How to install cutting belt
  • Garden Master
  • 2,478 Answers
Goggle it. owner's manual cth151
Posted on Mar 25, 2014
Cutting blades stay spinning when not engaged
Did you install a new belt? Is the a belt tension set correctly for the new belt. Loosen the tension and the problem should be resolved
Sep 07, 2015 | Garden
Tip
Setting Timing Without 3 So Called SPECIAL TOOLS Needed
1997-2000 Ford Contour 2.0L DOHC Camshaft Set up For timing Belt Replacement.most Instructions Call For 3 Different Special Tools No NeedFORD UPGRADED TIMING PULLEYS AND TENTIONERS In a UPGRADE KIT
Remove Valve Cover And TOP Timing Belt Cover CUT BELT OFF, Go to Rear of CAMSHAFTS (OppositeSPROCKETS) Look and you will see SLOTS at the end of Each CAM they are CUT ECCENTRICALLY . Use a Piece of Sturdy FLAT STOCK HARD STEAL (STRAIGHT) Turn CAMS one at a TIME Until they are EVEN With COVER GASKET SURFACE of Head, ALIGN BOTH Cams this Way Insert FLAT STOCK IN SLOTS So CAMS Don't Spring Back, And you Have VALVE TRAIN TIMED PERFECTLY, #1 Spark Plug OUT Bar Over to TDC WOODRUF KEY Should be Pointed Straight UP. This Is ALL there is to IT. Proceed with Timing Cover Removals and front Mount, REPLACE ALL PULLEYS AS A KIT (SOLD AS KIT) Install Timing Belt Set Tensioner According to KIT Instructions ans this will Illuminate All Special Tools SAID to be NEEDED for this Procedure, (( REMOVE FLAT STOCK AT CAMSHAFT ENDS AFTER BELT IS TIGHTENED.Install New Valve Cover Gasket #1 Spark Plug and Job is Done. Cuts 1 Hour 15 Minutes off Flat Rate
on Dec 31, 2009 | Ford Contour Cars & Trucks
Why does my mower deck belt on john deere 316 keeps breaking
There are a few causes for this and its not just this brand or model. First check that belt is installed correctly, check the part that keeps the belt on the belt rollers the belt should be between the garde and belt wheel, check for shine spots where belt is rubbing, Some times the mower deck is not set even or too low it can put the belt at too much of an angel causing the top of roller to cut it. So check the deck level there are adjustment devices on the mower to adjust, check for shine spots and for correct belt installment, and check roller wheel top for cuts or sharp spots, and check belt tension to see if it is to tight or too lose, also check that rollers spin free and there is not one stuck that could be heating the belt up too much, And last but not least make sure you are using the proper belt that is made for a mower fan belts don't last very long on a mower.
Jun 02, 2014 | John Deere 420,1020,2010,2020,2510,2520...
Timingbeltinstallation
If it has a belt, it can be changed without upsetting anything. Take a carpet knife and slice the belt in half along the length of it.Cut the front half and remove. Take new belt and fit over the front half of pulleys. Cut other half of old belt off. slide the new belt all the way on until in correct posistion.
Dec 12, 2011 | Hyundai Accent Cars & Trucks
I want to install a new motion drive belt on my Craftsman Model # 917.275684. (24hp, 42 cut) The belt part number is 140294. I removed the old belt by cutting it in two and now I can't get the new...
First thing is to check the new belt length against the old belt. Should be close, maybe old belt just a little longer. Then when you were trying to put the belt on did you set the brake like parking, that should take the tension off of it for you.
I hope this helps you out.
Aug 08, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I need a new garage door opener, but only have 121.5 inches from front wall to an annoying bulkhead. One installer said I needed 124 inches for a standard opener. He told me that my only solution is to...
CHECK OUT THE MODEL 3800 BY LIFTMASTER
VERY NICE UNIT - WE INSTALL THESE WITH GREAT SUCCESS
I WOULD NOT TRY TO CUT DOWN A BELT DRIVE
THE CHAIN DRIVE LIFTMASTER CAN BE CUT DOWN
HOWEVER I WOULD STILL GO WITH THE 3800 SERIES
Feb 07, 2011 | liftmaster Chamberlain Garage Door Opener...
How to install altnator belt without removing other belt
Can not be done, the belt or belt's have to be remove, to install alternator belt, no short cut's for this job.
Aug 26, 2010 | 2000 Mitsubishi Mirage
How to install a new set of belts no adouble cassetts deck
not easy to install belts for most tape...in so doing, usually has to detach assembly of the tape housing to have a better access...when replacing belt, one problem are the wire connections. because of frequent movement wire is cut from the welding point while fixing the belt in place. so be aware of the wire and dont be carried away. and usual problem is to to be able to put back exactly the way it was...every parts. one slightly wrong alteration most likely will affect or completely paralyzed the system.
you can buy tools for catching the belt. it is like crochet for yarn making...or get a wire and make a hook at end or two ends.
Apr 17, 2010 | Sony Audio Players & Recorders
Install belt on toro mower model 70041
For removing/replacing the deck belt, the general method is:
  1. turn off engine, remove key and set parking brake
  2. disengage blade by putting blade engage lever into off (disengaged) position
  3. lower the cutting deck to the lowest position (closest to the ground)
  4. relieve the belt tension (depending on the model, use a 3/8 inch ratchet set to tighten in the square hole of the idler bracket)
  5. remove and replace the belt
NOTE: it's not necessary to completely remove the cutting deck.
Useful diagrams for removing the cutting deck, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14794
For deck belt diagrams, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14796
If the transmission drive belt needs to be replaced, several components must be removed and special tools (i.e. air/impact wrench) used in order to change the tractor's transmission drive belt. See an Authorized Toro Service Dealer to have your drive belt replaced.
Sep 09, 2009 | Toro Lawn Mower With Toro Power Tools
Installing front drivers and passenger side seatbelts
When it comes to safety equipment in your car we are always supposed to refer you to a certified professional for installation.
If you are set on doing it yourself, I recommend you purchase a Haynes or Chilton manual at the local auto parts store for details and diagrams.
Thanks,
Jun 25, 2008 | 1999 Chevrolet Cavalier
Garden Logo
13 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
