Question about Philips LaserMFD 6050 (LFF6050)
Toner cartridge Purchased the Toner cartridge, for this Printer,from Amazon but when printing there are heavy,light lines all across the pages.How do I rectify please?
  • 56 Answers
It's probably s non original or a re manufactured toner ,make sure you get an original manufacturers toner and problem should go away ,if you still have a problem you may have donebothercservice issue and need a qualified service person to look at it
Posted on Nov 25, 2014
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
Why is there black line printed across the page in 3 different areas when something is printed. I changed the toner catridge.
This is nearly always the fault of the toner cartridge. The previous cartridge may have left toner on the transfer roller and this may have contaminated the new toner cartridge. Take the toner cartridge out and inside the printer under where the toner cartridge goes you will see a felt roller that goes across the printer and has a gear at one end. Wipe this roller with a dry clean lint free cloth, rotating it to make sure it is completly clean.
Check the blue coloured drum on the toner cartridge to see if there is a black line going across it. If so clean it with the same dry clean cloth.
If this does not work then I suggest you buy a genuine toner cartridge and try that.
Jun 10, 2011 | Samsung ML-2510 Laser Printer
Hi, I have this type of printer and there has been no problems..except.. i'm the new secretary and the golden drum light is on..never noticed if it was or has been always on..and the printing every 1 1/2...
Means toner cartridge is nearly to end. Just shake a little bit to distribute evenly the toner powder and be ready to purchase new toner cartridge. And is it nothing to do with the drum. Drum problem will create black shadow lines when printing.
Dec 07, 2010 | Brother HL 1440 Laser Printer
The Toner light flashes, it will not print .
Have you replaced the toner? By your post, it doesn't sound like it. Toner only lasts so long, it does run out, and then it's time to replace the cartridge. You can probably buy one from where ever you bought the printer, otherwise, Amazon.com is always a good place to buy things.
LINK to toners on Amazon.com
Dec 18, 2009 | Brother HL 1240 Printer
Faint vertical lines on Samsung ML-2010
Was the toner remanufactured/ compatible?
Sounds to me like the doctor blade in the cartridge is 'gummed' up and not allowing the toner to flow evenly across the Developer roller......try another cartridge
Apr 10, 2009 | Samsung ML 2010 Laser Printer
Horizontal black lines across page.
Horizontal lines usually indicate a toner cartridge that is not cleaning properly.
A. If the distance between defects is 38 mm (1.5 inches), 47 mm (1.85 inches), or 94 mm (3.7 inches), the print cartridge might need to be replaced.
B. Clean the printer.
1. Clean the inside of the printer and run a cleaning page to clean the fuser.
Over time, particles of toner and paper accumulate inside the printer. This can cause print-quality problems during printing. Cleaning the printer eliminates or reduces these problems.
To clean the inside of the printer
1. Turn the printer off and unplug the power cord.
2. Open the top cover.
3. Remove the print cartridge.
4. With a dry, lint-free cloth, wipe any residue from the paper path area and the print cartridge
cavity.
5. Reinstall the print cartridge and close the top cover.
6. Plug in the power cable and turn the printer on.
Cleaning the fuser:
Run the printer cleaning page to keep the fuser free of toner and paper particles that can sometimes accumulate. Accumulation of toner and particles can cause specks to appear on the front or back side of your print jobs. To ensure optimum print quality, HP recommends that you use the cleaning page every time that you
replace the print cartridge or on an automatic interval that you can set up. The cleaning procedure takes about 2.5 minutes to complete. A CLEANING message appears on the printer control panel display while the cleaning is taking place.
To run the cleaning page:
In order for the cleaning page to work correctly, print the page on copier-grade paper (not bond, heavy, or rough paper).
1. If your printer model includes a duplexer, open the rear output bin.
2. Press Menu to open the menus.
3. Use (Up button) or (Down button) to scroll to CONFIGURE DEVICE, and then press (Select button).
4. Use (Up button) or (Down button) to scroll to PRINT QUALITY, and then press (Select button).
5. Use (Up button) or (Down button) to scroll to CREATE CLEANING PAGE, and then press (Select button).
6. Follow the instructions on the cleaning page to complete the cleaning process.
7. If your printer model includes a duplexer, close the rear output bin.
If this helps resolve the problem, please post a reply. Binary Bob
Sep 11, 2008 | HP LaserJet 2420 Printer
Printer Problem - Konica Minolta 7450
If the print is a dismal gray rather than a sharp black, you are probably almost out of toner. This can manifest itself evenly across the entire page or in splotches or stripes, depending on the printer.
Sometimes you can wring a little bit more out of a toner cartridge by taking it out and gently shaking it from side to side (never up and down, as toner can spill out). You can also try turning up the printer’s contrast adjustment, if it has such a knob (usually on the back side if it exists). Faded print can also result from a dirty corona wire, because a dirty wire inhibits a full electrical charge from being passed.
If the printouts are consistently varied in density, and you have to frequently remove the toner cartridge and shake it to redistribute the toner inside it, make sure the printer is sitting on an even, flat surface.
Horizontal lines
A horizontal line on the printout is probably the result of a dirty or damaged roller. There are lots of rollers in the printer, and you can use the space between the lines on the page to determine which roller is causing the problem. Measure the distance between the errant lines on the page and then use Table A to determine which part might be causing the problem. Table A
Distance between lines
Faulty part
0.5”
Registration assembly
1.5”
Upper registration roller
1.75”
Lower registration roller
2.0”
Toner cartridge developer roller
2.56”
Lower fusing assembly roller
3.16”
Upper fusing assembly roller
3.75”
Toner cartridge photo drum
Regularly spaced splotches
If there are evenly spaced black spots but they don’t extend all the way across the page, the problem is probably a scratch or flaw in the drum or a build-up of toner on the fusing roller. If the spots are less than three inches apart vertically, it’s probably the drum, because the drum has a larger diameter than the fusing roller.
Vertical line on edge of page
This can indicate an almost empty or faulty toner cartridge or (less frequently) some spilled toner inside the printer.
Sep 03, 2008 | Konica Minolta DiMAGE Z10 Digital Camera
Unwanted Horizontal lines across the printed page
Problem is either Laser, Toner cartridge or transfer roller.
Feb 15, 2008 | HP LaserJet 4000 Printer
Consistent, faded and streaking vertical lines across entire page, from top to bottom.
Toner issue getting to drum - use gen toner cart.
or Drum blade stuffed (lines are down page fro top to bottom- replace drum assy
Drum has been exposed to light faint or blank across copies repeated 4 times down page - replace drum assy
or upper fuser roller stuffed, down page, smudgy print -  replace fuser
LSU(laser) or boards rarely cause issues
Oct 25, 2007 | Samsung ML 2010 Laser Printer
Philips LaserMFD 6050 (LFF6050) Logo
42 people viewed this question
Top Philips Office Equipment & Supplies Experts
jasbo
jasbo
matt martin
matt martin
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
