Question about Kenmore 1 hp Food Waste Disposer
My kenmore disposal doesnt work it only hums
Disposal will not grind, it only hums when turned on. It is actually a 3/4 hp food waste disposer.
  • 957 Answers
It is jammed the way to fix it is to use wooden broom stick and place the handle side in disposal and let it engage on the side pull stick back and forth till you free up the cutting blades. Then test it to see if it works. This happens a lot with disposals.
Posted on Apr 15, 2014
Jammed Kenmore Food Waste Disposal
It's not very likely that you have destroyed it, those things are tough. It just has something in it that is to tough for it to grind. Remove it and retrieve your corn holder and everything should be fine.
Col. Dana Gillespie
Jun 27, 2014 | Kenmore 1 hp Food Waste Disposer
Kenmore 3/4 hp garbage disposer does not work, it only hums.
Do not turn on... humming sound will overheat motor
See if cutter disc located inside disposal can be moved and rotated using broom stick:
If disc rotates freely, then try motor again... if still hums, then replace disposal
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Gene h
Mar 25, 2014 | Kenmore 3/4 hp Food Waste Disposer
Our new kenmore garbage disposal shoots the water up rather than sucking it down
Check the drain is not clogged.
Does sink opening have splash guard?
Check that plumbing is vented as required by code:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html#slow
Gene h
Mar 23, 2014 | Kenmore 3/4 hp Food Waste Disposer
Replace garbage disposal shredder disc
Which direction does disposal blade turn?
For example when looking straight-on at the nut holding power saw blade, the blade rotates counterclockwise, so the nut is reverse thread.
Most disposals are not made for repairs
Add a comment and say where you are getting the parts and which model
May 25, 2013 | Kenmore 3/4 hp Food Waste Disposer
Kenmore 1 hp Food Waste Disposer Logo
401 people viewed this question
Top Kenmore Kitchen Appliances - Others Experts
Charles T Nevin
Charles T Nevin
Sal De
Are you a Kenmore Kitchen Appliances - Other Expert? Answer questions, earn points and help others
