Question about Garden
I need to set up the dellorto carb on the 35s suffolk punch
Does anyone know how to set up the carb on the suffolk punch 35s...it will only run on full choke
The Main Jet needs to be wound out by 1.5 turns from the fully closed position. To do this:
firstly drain the float bowl
then once you've taken the bowl off use the correct screwdriver to unscrew the main jet from off the hard closed stop.
It's a brass plug that channel running up the middle of the float chamber.
I got a 2nd hand one with the jet screwed all the way in. It wouldn't run off choke. Once you've done this put fresh fuel in her, close up the bowl and relight it with throttle.
Warm it up and then use the side screw on the left side of the carb to set the idle until it runs smoothly off choke.
Posted on Mar 17, 2015
  • Garden Master
  • 2,478 Answers
Running only with full choke is a fuel problem. Unhook fuel line from carb. it should run good. If not go back the line. Check the fuel cap vent.
Posted on Mar 25, 2014
2 Suggested Answers
john49890
SOURCE: pull start mech complete for
Try http://www.agriengineering.co.uk/en/store/secure_viewItem.asp?idProduct=29748
Posted on May 07, 2012
I need a carburettor to fit my qualcast Suffolk punch 35S 004928A
hi rebecca.
i have had a look on the internet but can not find out where you would get one,you could try phoning the main dealers or try ebay.
Nov 17, 2017 | Garden
How much oil in a Suffolk punch 35s
Geoff, Check the attached links, manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.oldlawnmowerclub.co.uk/sites/default/files/opmanual/Suffolk%20Punch.pdf
Suffolk Punch OWNERS MANUAL
Small engine repair How to drain and change the oil in small petrol engine
Jul 02, 2016 | Garden
Suffolk Punch 35s not starting
carburetor have a setting level for its fuel , check the floating control adjust fuel level , also check spark plug current is there,just by rotating engine and keeping spark plug out of cylinder , just keeping it with engine body.
Apr 12, 2014 | Garden
I have a Suffolk Punch 35s mower and the petrol cap leaks badly and won't stay on whilst mowing, do I need just a new cap to fix it?
Yes, that's all you need. At some time yours was cross-threaded, That means that it was forced on wrongly, and broke the thread.
Mar 24, 2011 | Garden
Qualcast Suffolk Punch 35s lawnmower running problems
There is a small idling mixture screw on the side of the carburettor.
As the engine is not well suited to the carb. it mainly runs on the idle setting!
As long as you are not leaving the choke on. This is a little tab on the top of the carb. You start with it set on C then soon set it on the middle position, and after about 3 mins turn it off.
Jul 12, 2010 | York Yankees Bedding MLB Comforter
I cannot start my Suffolk punch 43s petrol mower, can anyone tell me how the choke should be set?Or where can I download a free instruction manual.
As far as I can tell, there are no downloads available. I eventually gave up and bought a copy from a mower museum. You will need to know the approximate age, as several diferrent engines have been fitted.
If you have the old red engine, the choke lever should be at right angles to the line of the carb IE pointing straight back.
The newer green engines are usually marked, but of not, remove the air filter and look into the carb throat. When the choke flap is CLOSED, the choke is ON IE cold start position.
As soon as the engie starts, move the choke to approx 50%, then fully open after 30 seconds or so.
If in good order, these engines are a 1-pull start. Fit a new plug, then spray WD-40 or similar into the OPEN carb thoat. If there is no sign of life at all, you have a coil failure (or possibly a points problem if it's ancient).
Sep 18, 2009 | Garden
Garden Logo
341 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
