Question about Garden
New coil and still no spark on my GC 160 Honda tiller
I have a Sears tille?er with the 5.0 Honda GC160 motor, it had no spark so I cleaned everything and still nothing, I purchased and installed a new coil to factory specs, still no spark, it only has the wire to coil shut off switch not the oil one. What can it b
  • 2 more comments
  • Wade Capps
    Wade Capps Mar 26, 2014
    I set the coil to factory specs, I installed a new spark plug and set the gap to factory specs, I tested the new coil with a tester and the readings show that it is good, still no spark? The spark tester used is good I tried it on my power washer and it showed positive.
  • Wade Capps
    The magnets on the flywheel are stronge, they will grab any metal that comes close including the coil base, both magnets. I disconnected the shut off wire before buying the new coil and after still nothing.Very frustrating.
  • cwradio73 Mar 26, 2014
    This is quite strange, unusual would be did you put flywheel back on correctly with key in place? Did you set gap on plug correctly, recheck your work an make sure that you are not grounding out somewhere. When you removed stop wire, take it from the coil side not off switch. This is very odd it seems that something is being overlooked. This covers about all there is to do. Start at flywheel I once saw a split key on crankshaft to flywheel that caused the same problem. I will think this over some more.
    Change out the plug with a working one just to be sure its possible from package it is bad as well.
  • 1,162 Answers
Did you check the gap between the magnet on the flywheel an mag? Unplug the stop wire an see how that works. Sometimes the switch is bad. Are the magnets on the flywheel, did you set the gap on the flywheel to mag correctly? Did you do the simple thing an change the plug they go bad more than anything else.
Posted on Mar 26, 2014
SOURCE: yard machine tiller won't stay started!
There is a small diaphram on the side of the carb that simply wears out. It's rubber coated mesh and the rubber coating breaks down and it stops pumping fuel into the carb. Sometimes you can run with the choke on partially, but it will burn 10 times the amount of fuel and cause more damage to the engine itself. I think it's about a $10.00 part.
Posted on Dec 08, 2008
SOURCE: Honda mini tiller stalls
Sounds to me like your main fuel jet is clogged if it will idle (different fuel supply) but not run with open throttle. When you open the throttle the engine gets more air and not enough fuel and quits.
Solution: Open (disassemble) the carburator and spray carburator cleaner through every orifice. Make sure you actually get cleaner THROUGH all holes. You've no doubt got fuel "varnish" in the jets from letting the equipment sit idle for long periods.
Prevention is the key: Always use a fuel stabilizer (Stabil) in your fuel. Mix as described on teh package for the "long term storage" concentration — generally double the dose of "normal" concentration and you'll minimize future problems.
Posted on Apr 09, 2009
iknowhow
  • 130 Answers
SOURCE: We just purchased a MTD
Nope.
Just here.
http://manuals.mtdproducts.com/mtd/Public.do
Posted on Jan 15, 2011
  • 5 Answers
SOURCE: fg 110 mini tiller by honda
I have had the same problem.
The first time the solution was to replace the rubber membrane underneath the primer bulb. Take off the bulb, then remove the plastic part underneath the bulb. There is a rubber membrane underneath that. The ethanol in the gasoline tends to deteriorate the membrane. The honda dealers sell them for about 14 dollars.
The second time the problem was caused by the gas cap, not properly venting. In this case the engine would start and run, but when I gave it full throttle, it would quit.
It got so bad that it wouldn't even run. I noticed when I loosened the gas cap it ran great.
So I took off the cap, removed the inner parts, and got a diaper in and pushed it though the holes in the plastic part underneath the cap, and through the rubber plug in the center. I did this a few times and check with my mouth to see if I could pull some air through the cap. When it breathed satisfactorily, I put the cap back on the gas tank and it ran great. Now it runs better than new.
Posted on Sep 11, 2011
Starting a small engine.
place it back up the right way
remove the spark plug
fill the sump to the correct level
pull the cord a few times to expel any excess oil out of the cylinder
remove air cleaner to remove any excess oil from the filter
clean the plug by washing in solvent to remove oil
install plug, prime or choke and it should go
will smoke for a while until the oil in the muffler burns out
Jun 24, 2016 | Honda GC160-QHA 3/4" Shaft Recoil Start 5...
Tiller will not start changed plug and cleaned gas and lines
check for a stop switch or wire from the switch being shorted out
Apr 17, 2016 | Yard Machines Garden
Honda gc 190 starts then floods and stops. Wont start again till plug is taken out and dried then repeats same thing
Float level or a sticking needle valve, check float level as if it is adjusted incorrectly it can cause the main jet to allow fuel to flood through, the needle valve can do the same.
Jul 28, 2014 | Honda Engine Gc160 Gc190 Gcv135 Gcv160...
How do you replace the honda gc190 decompression mechanism
This is a problem with GC-160 and GC-190 engines on pressure washers, tillers, etc. Once they get some hours on them and as things seat in-wear in, they get to a point you can not pull the start cord. If you remove the spark plug, the engine turns easily. The valves need adjusted. The valves are set .005" to .006" off the seat. This allows enough compression release but the engine runs. I find the valves need adjusted every 25 hours, not the 100 hours Honda states.
Mar 16, 2013 | Karcher 2500 PSI Pressure Washer
Honda GC190 can't pull starter cord
This is a problem with GC-160 and GC-190 engines on pressure washers, tillers, etc. Once they get some hours on them and as things seat in-wear in, they get to a point you can not pull the start cord. If you remove the spark plug, the engine turns easily then the valves need adjusted. The valves are set .005" to .006" off the seat. This allows enough compression release but the engine runs. I find the valves need adjusted every 25 hours, not the 100 hours Honda states.
Aug 29, 2012 | Honda Garden
Tiller engine won't turn over after the till was on its side to clean tines
remove the spark plug and pull it to force any fuel and oil from the cylinder hold a rag over the top of the spark plug hole as fuel and oil will spray out check the oil level before running the engine again
Apr 30, 2012 | Troy Bilt Bronco 208cc 4Cycle Gas Powered...
5.5 brigs and straton motor doesnt get any spark
try and spray starting fluid it might be carb related but if your sure its spark the coil is the only thing that controls spark
Apr 27, 2012 | Sears Craftsman 208cc* Front Tine Tiller...
I don't think my tiller is getting any juice to the sparkplug. I changed the sparkplug and air filter, checked the oil and gas, but it still won't start.
disconnect the kill wire on the motor and then see if you get spark. If so its your switch, if not it either points or electronic coil or regular coil or condenser problem did you gap the pints correctly and was there a problem b4 you changed the points.
May 03, 2011 | Troy-Bilt Pony Garden Tiller
Wat is de klepspeling van een honda gc160 en hoe weet ik waneer ik de in laat of uitlaat klep kan stellen en wat voor olie moet er in
I have installed d530 sff mother board & processor is 3.0GHZ 800mhz error is showing.
Microcode update Error. Missing or Invalid processor microcode update. Please contact HP company.
D 530 SFF is support to 3.0 GHZ processor ?
Mar 02, 2011 | Pramac EG2800 T Handle Generator With...
Garden Logo
124 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
