Question about Danby Silhouette DWC512BL Wine Cooler
Unit is dead
No power. No cooling.
    Problem Solver:
  • 13 Answers
Probably a compressor failure following a gas leakage in the cooling coils, check any fuses to see if they have blown to protect the compressor assembly.
Posted on Apr 29, 2014
Ge refrigerator Wont cool and everything is running only 5years old
Cooling will only take place when the compressor is running. If not running check to see that unit is receiving power at power plug - then check to see if motor is receiving power at input terminals - if it is, make sure that the starter capacitor is working (that starts the compressor from a dead start).
If no power reaches the compressor make sure that the thermostat circuit is working properly and getting power to the motor windings. If the defrost timer is stuck in the open position, no power will reach the compressor and or associated fans.
U have a few areas to check - now go get to it!
Jul 02, 2015 | GE Refrigerators
Dometic rm7732 not cooling
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
  • Is the refrigerator completely dead? If so, see “It's stopped completely.”
  • Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Jun 17, 2008 | Dometic RM2652 Refrigerator
Reset button for a Bosch DLX drier location
Most dryers don't have a manual reset. they are usually an auto reset which will turn the power back on when they cool down. Check the filters etc for blockages. If its dead, unplug it for a while then plug back in and try again, if still dead, there may be a safety overheat sensor which has failed or perhaps a failed electronic board.
Mar 13, 2015 | Bosch Dryers
My refrigerator has a red light on indicating. Cooling off has been on for 8 hrs
could mean the compressor and or evap fans have stopped running..... try unplugging for 20 - 30 seconds, plug back up and see if unit restarts..... if its still dead ... and your sure u have power to unit, I would go to the main control board and start checking power................. good luck and I hope this helped.......... ken
Sep 30, 2014 | Refrigerators
Inconsistent power
If it's totally dead, the main fuse may have blown. However, since it was inconsistent before it went dead, it might lead me to think that you have a loose connection. Sometimes they heat, lose continuity, and then work again when they cool. A defective thermal protector might also cause this.
Dec 20, 2013 | Whirlpool WMH1163XVS Microwave Oven
Power failure and higt temp
Power Failure, is it dead? If so call a repair man. Make sure you check the fuse to the fridge, no power to the unit may be the problem too, the sides of most modern fridges get hot thats how they diperse the internal heat.
Nov 21, 2013 | Refrigerators
Dead Dirt Devil Featherlite
1. Power cord not firmly plugged into
outlet.
1. Plug unit in firmly.
2. Blown fuse or tripped breaker. 2. Check fuse or breaker in home. Replace fuse/
reset breaker.
3. Needs service. 3. Take to service center or call 1-800-321-1134.
4. Thermal Protector activated.
4. Unplug cleaner. Allow to cool for 30 minutes
Nov 03, 2012 | Dirt Devil Featherlite Bagless Vacuum...
Mac G4 Digital Audio Model. Unit is, suddenly, completely dead. Is a good backup battery (1/2AA 3v), needed for a power start? Is there a separate fuse anywhere in the unit, i.e. within the Power Supply...
Processors are liquid cooled on G4s check and see if there is fluid in the bottom of case . if there is go see ur Apple dealer, They replaced mine.
Oct 07, 2010 | Apple Power Mac G4 Desktop
Fujitsu siemens esprimo E3510 PC, screen goes dead at random intervals, PC power light still on, reboots ok sometimes (after pulling power cord)_, then goes dead again
Be sure all fans are working and blow out dust so system can cool properly. If clean, may be power supply or video card. Ensure cables inside are connected properly. Use caution when entering case. Voltages are present so make sure to unplug unit.
May 05, 2010 | Fujitsu Siemens SCENIC P300 PC Desktop
GE PTAC AZ38H09DABM2 WENT DEAD..POWER OK
Could be the main control board.
Could be that somebody has been messing with the dipswitches beneath the control board.
Dec 22, 2008 | GE Zoneline Deluxe Series Cooling &...
Danby Silhouette DWC512BL Wine Cooler Logo
133 people viewed this question
Top Danby Furniture Experts
Dan Webster
Dan Webster
Dennis Boxerman
jdthefixer
Are you a Danby Furniture Expert? Answer questions, earn points and help others
