How to dilute a solution
How to dilute a 69% solution to a 10 % sloution
  • Office Equip... Master
  • 8,016 Answers
C_1*V_1=C_2*V_2
V_2=(C_1*V_1)/C_2=V_1*(0.69/.1)=6.9*(V_1)
Start with a volume V_1, add water to the original solution until the total volume is equal to 6.9* V_1
Since the initial volume is included in V_2, you must add an amount of water equal to (6.9-1)*V_1
For an initial volume of 1 L, add 5.9 Liters of solvent.
Posted on Mar 26, 2014
What is Dilution In Accounts Receivable Financing?
Dilution is the difference between the cost of the gross receivables and the cash accrued on the receivables. It's expressed as a percentage and is particularly important as it helps the lender decide the advance rate.
Sep 06, 2016 | The Computers & Internet
Why does it always shut down when I come to a stop?
Sloution 1. Check your Idle Air Control Valve, clean it with carb cleaner.
Solution 2. Check the Mass Air Flow sensor if its dirt, if so clean it with Mass Air Flow cleaner not carb cleaner.
Sloution 3. Clean your throttle.
These 3 steps are likely to solve your problem, if not then the problem is bigger it maybe the Cam sensor.
Feb 13, 2016 | 2006 Opel Corsa 1.4
When making soup for 100 at church, the black pepper spilled. It is quite spicey. Short of diluting it, any recommendations?
Hi
The only suggestion that I can give you that does not involve dilution and therefore loss of flavour, is to make another batch of the soup - completely without black pepper but with everything else, and blend the two together until the taste is about right. I think I would gradually add the spicier one to the later batch to get the required pepperiness.
At least doing it this way, you don't dilute any of the other characteristics, even if you find you've got double quantities !!
Hopefully your church goers will be hungry !
Good Luck.
Mar 06, 2015 | Crock Pots & Slow Cookers
How do I dilute a 2%solution to a 1.5% solution?
is a 2 porcent os 1.5 porcent of what
Sep 24, 2014 | Cars & Trucks
Mix one part solution with four parts water.
Apr 05, 2014 | Office Equipment & Supplies
Radiator capasity
When I'm doing a radiator I buy two gallons-you then follow instructions on bottle for diluting with water-some come pre-diluted- Denny
Nov 27, 2013 | 1997 Mercury Mountaineer
Can I dilute Scotts Miracle Grow for use in my Ortho dial spray bottle?
Yes, you can use Miracle-Gro Water Soluable Plant Food in the Ortho Dial N Spray hose-end sprayer. Simply set the dial on the Dial N Spray to 4 ounces. The label rate for Miracle-Gro All Purpose Plant Food is 1 tablespoon per gallon of water. To make 8 gallons of finished spray, measure 8 rounded tablespoons of plant food into the Dial N Spray jar and fill the jar with water. Mix thoroughly. Set the dial at 4 ounces. When you have sprayed until jar is empty, you will have applied 8 gallons of properly diluted spray. Hilary@Scotts
Jul 23, 2011 | Garden
Where can i get undiluted white vinegar?
I think the answer is just to use straight vinegar and not dilute it. If the manual is asking you to use undiluted white vinegar,just use plain white vinegar and don't dilute it.
Feb 28, 2011 | Keurig B100 Coffee Maker
2005 avalange engine misfires random cylinders
check the piston rings and carbonize the top of the piston rings.check engine valve for valve clearance use filler guage .14 .and check for gas and water dilution or oil and water dilution.
Jan 21, 2009 | 2004 Chevrolet Avalanche
63 people viewed this question
k24674
jasbo
jasbo
