Question about KitchenAid Dishwashers
Dish washer stuck in one cycle
Dish washer model KUDS01ILBS2 starts normally then in wash cycle the control panel makes a buzzing noise and will not progress out of the wash cycle. Canceled and used 2 minute cycle to empty dish washer. Ran diagnostics everything was normal until test interval 2 and 1 when the Sensing/soaking LED came on. If I am reading the diagnostic chart correctly that means a bad Pressure Switch if it comes on in interval 3 but what does it mean in interval 1 & 2? What are likely causes of the buzzing control panel - this is not a normal noise? Thanks for your help.
  • 3422 Answers
SOURCE: stuck in two minute drain cycle
It is possible that the unit has leaked.
I want you to please check THIS link it will solve your problem.
Don't forget to do the banging test mentioned there.
Posted on Feb 25, 2008
  • 6487 Answers
SOURCE: MDB 8750 Dish Washer Doesn't start the Wash Cycle.
Yes this can be a touch pad failure that may need to be replace again , because with this type of device usually the touch pad is easy to get bad...
Good luck........
Posted on Aug 19, 2008
  • 750 Answers
SOURCE: My bosch dish washer won't
Welcome to fixya.
You said, Your Bosch dish washer won't work. A number 1 is displayed on the electronic panel.
If it is displaying"01" then that means the extra dry setting is being applied!
Did you try to use the extra Dry setting?
Did the dishwasher work before this or is it brand new?
What is the model number and year?
Let me know ! I'm waiting for your response
Below is and example of the usage of 01 or 00 in a Bosch Dishwasher!
Extra Dry Heat
With this option you can raise the temperature of the rinse water and increase the drying
time which will result in improved drying.
To activate :
Press and hold the left cancel drain button ,
Then press and hold the on/off button when the LED display shows a, "00" or a "01"
To enable the additional drying heat,press the left cancel drain button until the LED display shows a "01"
To disable the additional drying heat,press the left cancel drain button until the LED display shows a "00"
press the on/off button to save the settings.
Posted on Oct 02, 2008
SOURCE: Kenmore Ultrawash Quiet Guard 5 making buzzing/grinding noise
I have a very similar dishwasher, with a very similar problem. I fixed it by removing debris from the water evacuator pump located towards the front of the bottom of the machine (the last motor before the drain hose. In my case, grape stems had clogged it up. Once emptied, it purrs once again. NOTE: don't disassemble the motor, just flush it out, there is an o-ring gasket that is a bear to re-install.
Posted on Sep 04, 2009
Stuck in wash cycle
More than likely the control panel is the problem, about $200 for the part on average. For more help and parts contact this website. Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Jun 29, 2017 | KitchenAid Washing Machines
Frigidaire dishwasher noticeably louder - circulation motor?
Try to position the machine, so that you can run the cycle and watch the dish washer. Remove the back panel and hear the sound of origination. Take suitable action as per your convenience. You can clean & replace the bearings if they are worn or replace as a whole unit.
Jul 06, 2010 | Frigidaire Dishwashers
My GLTF 2940 makes a buzzing sound like a relay not pulling in all the way, during the rinse cycle. If you shut off the washer, and restart it on the rinse only cycle, it goes away.
its probably your cold water rinse only valves solenoid thats loose on the structure or the coil itself is loose,you may not hear it all the time especially during the initial wash start fill,try this, set the washer for cold water fill only on the washer,but turn off the water valves that supply water and start your machine to a wash cycle as normal,try this and see if it dry buzzes(without water),then try the same on the hot side,then with the water still off open up the machine and you can localize the buzzing noise
Mar 12, 2010 | Frigidaire GLTF2940ES Front Load Washer
Makes buzzing noise and won't spin or drain
Sounds like something is stuck in the drain pump.  If nothing is stuck in the pump replace the pump.  It won't spin until it drains, so fixing the drain problem will fix the spin.  You can get at the drain pump by taking off the bottom panel.
Dec 19, 2009 | Frigidaire GLTF2940ES Front Load Washer
Nd error essage
nd= no drain. loud buzzing noise sounds like something stuck in pump assy.remove the door(2screws) adn other 2 screws oppisite side, and hte front panel comes off giving you acess to the drain pump, pull the hoses and look for the obstruction
Mar 14, 2008 | Maytag Neptune MAH5500B Front Load Washer
My washer is making a buzzing noise and stopping the process.
Yes sounds like the drain pump or sump area is clogged. Axcess throug lower service panel if the model you has selected is accurate..
Jan 12, 2008 | Frigidaire GLTF2940ES Front Load Washer
Dishwashers Logo
35 people viewed this question
Top KitchenAid Dishwashers Experts
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
