Question about Ford 8n,9n,2n, Tractor Starter With Drive
My truck won't start
Won't start I've replaced the starter and ignition coil still won't start only makes clicking noise
  • Ford Master
  • 2,478 Answers
Click means loose or dirty connection. Use a ohm meter, when turning ignition to starting. Should read atleast 12v Read voltage at big termial on starter. If no or low voltage. Check solenoid, both sides to proper voltage.
Posted on Mar 25, 2014
My car runs fine for days then i'll park somewhere and go to turn it back on and it won't start at all. It won't turn over or anything.
CHECK BATTERY CONNECTIONS, STARTER CONNECTIONS, WHAT DO YOU DO WHEN IT DOESN'T START, TO GET IT GOING AGAIN, DO YOU GET A JUMP START IF SO CHECK CONNECTIONS.
Jun 09, 2013 | Cars & Trucks
1995 Isuzu Rodeo won't start all of a sudden.
Check connection battery,could be starter.
Jun 05, 2013 | Cars & Trucks
2001 Lexus GS300 won't start (makes a continuous
A mechanic would check for voltage at the battery, the starter, the neutral safety switch, and the key switch.
Aug 04, 2012 | Cars & Trucks
Won't start but can hear starter make a click noise when trying to start with key
will it start with a jump ? if it does replace the battery and have the charging system tested, if it will not start with a jump then most likely you will need to replace the starter.
Dec 07, 2011 | 1999 Chrysler 300M
My lights, windows, and radio all work fine. But it won't start it makes a click noise but nothing. Then we thought it was the battery so we jumped it and now it won't even make no click noise at...
The "click" sound condition make us guess that could be a bad ignition switch or starter.
It turned out to be the starter. I first took the battery to have it tested and it was fine. Next, I took the starter apart and took it to Autozone to have it tested? and it was bad. It is not easy access to remove the starter. The intake manifold and exhaust system are in the way and need to be taken apart first. See instructions below:
- Take off Intake
- Take off Starter
Hope this helps (remember to rating this answer and leave some comment).
Sep 28, 2011 | 2003 Honda Element
My 2007 corolla won't start. When I turn the key in the ignition the starter makes a rapid clicking noise. I?ve tried putting the car in neutral and starting it that way, but had no luck. I?ve also tried...
1st check the main cable to the starter make sure it is clean and tight, disconnect battery first, after that there should be a small wire going to the starter jump that small connector to the main battery cable on the starter (IGNITION OFF) if it cranks you have a wiring or ignition switch problem if not Starter time just make sure you get a very good quality starter some cheap and even lifetime starters are so poorly made that even after you replace them you still have a problem only a bad noise coming from the new starter you just put in.
Oct 14, 2010 | Toyota Corolla Cars & Trucks
Ford 8n,9n,2n,  Tractor Starter With Drive Logo
48 people viewed this question
Top Ford Garden Experts
Dennis Key
Dennis Key
fordexpert
donald boissonneault
Are you a Ford Garden Expert? Answer questions, earn points and help others
