Question about Singer Featherweight 132Q Mechanical Sewing Machine
Needle will not pick up the bobbin thread.
I have the bobbin in correctly. I have checked the upper tension and that the thread is positioned. The bobbin is not wound tightly. I have adjusted the bobbin tension. I can't think of anything else. Can you help please?
  • 72 Answers
Could the needle be inserted incorrectly? Typically, the flat of the needle shank goes to the back of the machine. Are the needles the correct type for your machine?
Posted on Mar 28, 2014
SOURCE: Upper thread wraps around bobbin mechanism, while sewing
IT PROBABLY IS THREADED INCORRECTLY. GO SLOWLY BY THE DIAPHRAGM AND MAKE SURE IT IS THREADED CORRECTLY. ALSO MAKE SURE SPOOL PIN HOLDERS ARE IN PLACE THAT HELPS TO GUIDE THE THREAD CORRECTLY.
Posted on Sep 22, 2008
  • 4 Answers
SOURCE: singer quantum sewing machine won't pick up bobbin thread
Try changing your needle
Posted on Dec 13, 2008
  • 6 Answers
SOURCE: Singer CG 550 Top thread keeps wraping around the bobbin and jam
Have you checked the top thread is correctly placed in the spring of the bobbin case?
Posted on Feb 21, 2009
  • 1116 Answers
SOURCE: The bobbin thread is sewing loose stitches and
Always have the presser foot up when you thead any sewing machine.
Make sure the flat side of the needle shaft is facing to the back of the machine.
Don't do anything to the bobbin tension. Set the top thread tension to what is recommended by the mfg.
Make sure the thread from the bobbin is feeding from the bobbin in the correct direction and through the correct guides.
After inserting the bobbin and threading the machine, lower the needle (hold on to the thread tail) and then raise it by turning the hand wheel by hand to pull up the bobbin thread.
Gently pull the two threads under the presser foot and to the back of the sewing machine before you begin to sew.
Posted on Feb 19, 2010
Obertelli
  • 3006 Answers
SOURCE: The thread is bunching up
Your problem stems from the faulty foot lever mechanism. It's coupled to the upper thread tension control which only provides tension when the presser foot is in the locked down position.
If the presser foot won't positively engage in the down position, there's no upper thread tension and the thread bunches up below. Everything else stems from there. If the needle has hit the bobbin case too frequently then the bobbin timing may also be slightly out and the needle itself will be damaged and won't pass straight through the fabric; it only takes a tiny deflection from the vertical as it passes through the workpiece for the needle to flex and hit the bobbin case.
In summary, your machine is in desperate need of repair and adjustment. You haven't stated which exact Singer model you have, but they are usually easy to get servicing manuals for or you can take the machine to a sewing machine servicing specialist. Most singer spare parts (even for 100 year old machines) are usually still available fairly cheaply from a variety of sources, just enter "Singer spares" into your search engine to find suppliers.
To prevent re-occurrence, clean the mechanism regularly and lubricate it as directed by the manufacturer using sewing machine oil. Depending on how often you use the machine, do (or have done) a more thorough service periodically to check the timing and also that all mechanism screws remain tightly fastened.
I hope that my reply has shed some light on your problem and enables you to decide what to do next. Please take a moment to rate my answer.
Posted on Sep 30, 2010
I sewed a support seam on neck line. got the bumpy stitches from bobbin. rewound bobbin, threaded machine. went to sew and now nothing works. it wont sew.
Not quite sure since the symptoms are not clear. "Bumpy stitches from bobbin"--does that mean there were thread nests on the bobbin side of the fabric? That is thread nesting or bird nesting resulting usually from mis-threading, upper thread not completely seated in tension disk, or upper tension too loose. Remove the upper thread from the machine. ALWAYS RAISE the presser foot and rethread from the beginning--verify the thread path is correct. Set the upper tension to the midway point between high & low number and retest the machine. (Upper tension may need to be tweaked because fabric, thread, and age of the machine will have an affect.)
Check that the bobbin is wound smoothly--no lumps, bumps, or thread ends/pieces sticking out of the bobbin. Check that the bobbin is installed in the bobbin case correctly (turning the proper direction) and the bobbin tension is threaded completely.
If the upper thread is not picking up the bobbin thread, make sure to install a brand new needle. If it still won't pick up the bobbin thread, then the machine's timing has probably been knocked out of alignment. Search for sewing machine timing or take it for service.
Jan 14, 2017 | Sewing Machines
My upper thread wont pick up the bobbin thread suddenly. How do I fix that problem?
Install a brand new needle. A bent/dull/damaged needle sometimes will not pick up bobbin thread.
Check that the needle is installed facing the correct direction.
Also check that the bobbin is wound smoothly, the bobbin is turning the correct direction in the bobbin case, and the bobbin tension is threaded correctly.
If it still will not pick up the bobbin thread, there is most likely a timing issue, ie the needle is arriving at the wrong time to intercept the bobbin thread. Search the internet for sewing machine timing discussions or take it for service.
Nov 03, 2016 | Sewing Machines
My tension went out of sync now its not even picking the thread up
Try installing a brand new needle. Verify you are using the correct needle for your machine.
Remove the upper thread. Always raise the presser foot and rethread from the beginning. Make sure the threading path is correct.
Set the tension to the midway point between high & low numbers (this is usually the factory standard, although each machine may need a slight tweak and the type of fabric & thread may require a tension adjustment).
Check that the bobbin is inserted properly in the bobbin case and that the bobbin case is threaded correctly.
Retest your machine.
If it is still not picking up the bobbin thread, most likely there is a needle/hook timing issue. Take it for service.
May 15, 2016 | Janome Sewing Machines
The needle with top thread couldn't draw the bottom thread from the bobbin to ready the machine for sewing
Are you saying that the upper thread is not pulling the bobbin thread up to the top?
Remove the thread. RAISE the presser foot and rethread from the beginning--allows the thread to seat completely in the upper tension disk.
Check that the bobbin thread is inserted in the bobbin case facing the correct direction and that the bobbin case is threaded correctly through the bobbin case tension. Be sure to leave at least a 6" tail of thread on both the upper and lower threads.
Retest.
If it is still not picking up the bobbin thread, the bobbin case may be defective/malfunctioning or your machine probably needs professional service.
Feb 27, 2016 | Sewing Machines
When I press on the pedal the machine just makes a 'vruuuuuu' sound, and when it sews it tangles around the bobbin! It also does not pick up the bobbin thread
1. The bobbin may be in backwards.
2. The bobbin thread & top thread need to be pulled to the back before starting the stitching
3. You need a ballpoint rather than universal needle to sew on t-shirt knits.
4. the needle is in the machine backwards
5. Make sure the needle is the correct one for the fabric being sewed
6. Needle inserted wrong in the needle holder
7. Damaged needle
8. Warped bobbin
9.First make sure the bobbin-winding spindle (located on top of your machine) has been pushed back to the left for sewing.
10.If it is not in the correct position, the needle will not go down and pick-up your bobbin thread.
11.Next make sure your needle is inserted correctly, with the flat side facing back.
12.Also, make sure your bobbin is in correctly
13.the upper tension disks of your machine are threaded correctly.
14.Make sure the presser foot is up when seating the thread through the upper tension.
15.Turn the handwheel towards you only and hold the needle thread lightly.
16.could be a timing problem
1611
Feb 25, 2016 | Bernina BERNETTE 65 Mechanical Sewing...
I have singer 4423.The needle thread in bunching up in the bobbin case and not sewing! When it didn't pick up bobbin thread I loosened bobbin tension which fixed that problem.
Sounds like bird nesting.
Remove the upper thread completely. RAISE the presser foot and rethread from the beginning. Make sure it is threaded correctly according to the manual.
Set the upper tension to the midway point between high & low numbers. Retest on a scrap of fabric.
P.S.--once you get the upper tension correct, you may find you will need to readjust the bobbin tension.
Also make sure that your needle, thread, and fabric are compatible.
All About Needles
Feb 15, 2016 | Singer Sewing Machines
My riccar 1900 won't thread; needle to bobbin
If this doesn't help solve your problem, the machine may have a timing problem.
Jan 18, 2016 | Riccar Sewing Machines
Singer 328 is not stiching
if upper thread correct, check bobbin is wound and inserted correctly. Pulling bobbin thread, the bobbin should turn counter clockwise. make sure thread is under bobbin case tension spring. With cover plate open hold needle thread and turn hand wheel towards you to see if hook picks up needle thread and passes it around bobbin case. if not check hook timing
Jan 05, 2014 | Sewing Machines
Needle will not pick up bobbin thread when sewing
double check the upper and lower tensions they often need to be changed to suit types of fabric and threads
Dec 12, 2009 | Singer Sewing Machines
Singer Featherweight 132Q Mechanical Sewing Machine Logo
136 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
