Question about Icom Radio Communications
Icom 251e mode switch display wrong setting on display, i.e. F displays U
5 Suggested Answers
  • 628 Answers
SOURCE: I have Toshiba e studio 207 copier machine. After
If not the contrast switch problem, u can try reset the machine by pressing "*13" and ON the machine.
Posted on Jan 01, 2010
lbrown1806
  • 488 Answers
SOURCE: my casio pcr t2100 display "wrong mode"
Your mode switch position was changed before finalization. You will need to return the mode switch to its original setting and finalize the operation.
Posted on Dec 27, 2011
  • 6771 Answers
SOURCE: set on standby mode,no display aiwa nsz-20hr
There is a short in the power supply board, shorted regulator transistor, or diode, and capacitor, "sometimes a bulge at top" cheaper to replace than repair.
Posted on Apr 03, 2012
  • 607 Answers
SOURCE: icom ic-r70 display
Hi Gary,
to give you the best advice and all the info you require, may i suggest you join yahoo group SPECIFIC to your radio Make/Model, the techs, there will give you all the info you need, but describe the problem fully, don't be afraid to give as much info regarding your radio as you can, the more you ask, the quicker the solution to your problem, you can download manuals, schematics, and other goodies for your radio and all is free.
Best regards,
Peter
Posted on Mar 06, 2013
Display has stripes
This is a typical failure mode for this rig. The only repair is to replace the display. Check with Icom, I think they still stock the proII displays, if not, out of a scrap radio is your only hope
Feb 21, 2014 | Icom IC-756PROII Transceiver 3205669
My casio pcr t2100 display "wrong mode"
Sep 13, 2011 | Casio PCR-T2100 BLACK DELUXE 96-DEPARTMENT...
I have been using my Iogear kvm switch for almost 2 years now to switch between a desktop and a laptop, both Windows XP. I unplugged the laptop in a hurry to go do a presentation, and plugged everything...
This almost sounds like the display setting on your laptop was changed to an external device. Most laptops are designed to be hooked up to an external display, such as a monitor or projector, specifically for presentations. You can alternate the display options in the following ways:
  1. Laptop display only
  2. External display only
  3. Laptop+External clone
  4. Laptop display + extended desktop on external display (dual monitor setup)
Check your laptop display settings and make sure that it's not in presentation mode (options 2-4) before connecting the KVM switch to it. It may be recognizing the KVM switch as an external display in option 4 mode.
Mar 25, 2011 | IOGear GCS634U KVM Switch
I bought a new logic unit (front face) of Icom F121 and it needs to be restored. How do you restore a logic unit for the Icom F121?
1- You have to to "Reserve" mode.2- Change Set Mode Access: Inhibit to Enable3- Common>>Secutity Change Set Mode Access : Inhibit to Enable4- Enter RX TX frequency and write to the radio.
or you can download version Rev 1.7 from here:
http://www.two-way-radio-tools.com/icom-softwares.html
http://www.two-way-radio-tools.com/icom-radio.html
Aug 27, 2010 | ICOM Informatique IC-F121 VHF 136-174MHz...
I have an Icom-M700 pro, serial number2404380 installed on my yacht. I entered in set mode and probably did something wrong because since that moment the radio only transmit in AM and FSK mode. I am now in...
Under some circumstances the transceiver’s internal
CPU may cause erroneous indications on the display.
If this happens, reset the CPU as follows:
While pushing [ENT] + [0], push [POWER] to turn
power on.
• The CPU is reset and the display at right appears.
CAUTION: Resetting the CPU returns set mode
contents to their default values.
that's the quickest way to do it, hopefully you don't have alot of stored frequecies in memory.
you can get a pdf copy of the manual here
http://www.icomamerica.com/en/products/marine/ssb/m700pro/default.aspx
robert
Oct 21, 2009 | ICOM Informatique M700Pro (150 Channels)...
Programming an Icom IC R5 scanner
This is a problem with any scanner which has no keypad..
First set the squelch (gets rid of the hissing noise and allows the radio to scan)
to do this....
On the side are 2 buttons, the bottom one is monitor.
press and hold then look at the display,
turn the top dial until "AUTO" appears,
The squelch should now keep the radio quiet.
Now the tuning step..
You need to set this because if your radio was on 450.000 and you wanted to listen to 450.012.5 you would miss it if your radio was making 000.025 "steps". IE you would need 12.5 steps. This is the most common step used by ambulance etc in the UK, you will need to check local band plans.
Stick with 12.5 and you should get most stuff on VHF / UHF.
For airband 12.5 will get most stuff, but some is now changing to 8.33.
For HF (below) 136 Mhz I'd use 5
To set the step....
On the front there are 4 big buttons.
press [V/M.S.MW.SKIP] to select VFO mode,
then press [BAND.LOCK] to select the band you want to listen to,
then press [TS.SET] to enter the step
turn the dial to select your step (stick with 12.5 for now)
press [TS.SET] to exit back to VFO mode
To scan...
First set the scan type...
Press and hold the one that says [MODE.SCAN] for 2 seconds and look at the display,
turn the top dial until the screen reads ALL,
press [MODE.SCAN] again and the radio should start to scan with the 12.5 steps you set earlier.
If you want to change scan direction, just turn the top dial.
If you want to stop the scan, just press [MODE.SCAN].
When you hear something interesting, make a note of the frequency on the display.
To set memories (store frequencies).....
to get close to the frequency you made a note of, press [BAND.LOCK]
Then set the actual frequency with the top dial,
press and hold [V/M.S.MW.SKIP] for 2 seconds to select memory write mode (1 short and 1 long beep)
turn the top dial to select which channel you would like to overwrite. Start with 01.
press [V/M.S.MW.SKIP] for 2 seconds. ( 3 beeps )
Thats it!
Any more problems just post on here and either me or someone else will help.
M3ODQ
Dec 22, 2008 | Icom IC-R5 Handheld Scanner
LCD Computer monitor
This problem may occur due to wrong driver of display card or wrong display settings.
Solution:
1- Start you computer in safe mode.
2- Remove display card driver.
3- Restart you computer.
4- Install display card driver (if it does not pick automatically).
Now it should show default settings. I hope it would solve your problem.
Aug 17, 2008 | Gateway FPD2275W LCD Monitor
Icom r5
A quick "get you started" guide.....
to do this....
To set the step....
To scan...
Thats it!
M3ODQ
Jun 24, 2008 | Icom IC-R5 Handheld Scanner
Radio Communications Logo
Top Icom Radio Communications Experts
peter0911
Steve
Are you an Icom Radio Communication Expert? Answer questions, earn points and help others
