Question about Taylor Soft Serve C706-27 Machine
I have a c712 model.how do you change the viscosity setting?
Product is too soft temp only getting down to 44 degrees f
2 Suggested Answers
  • 30 Answers
SOURCE: Hello. We have Taylor c712 with air mix pump.
it is over freezing, you need to have the viscosity adjusted and also make sure you are removing all the water when you are priming unit.
Posted on Sep 05, 2011
Brush Cleaning did not clear the (L / R) HPR> 45F (7C) AFTER 1 HR fault on my Taylor Model C723 soft serve ice cream freezer.
Certain conditions must be met. The machine needs to be empty. The freezer door must be off the machine. The power switch must be off. Once the machine is off, a 5 minute countdown will show. It will also show 4 temperature readings. All 4 of them must be above 60 degrees F. before the countdown will start. Once the counter reaches zero, the Brush Clean Cycle will be reset along with any temperature vs. time error codes. If at any time, one of the temp readings drop below 60 degrees F. before the end of the 5 minute countdown, the countdown will reset to 5 minutes and the machine will not reset. Generally, the freezing cylinders take longer to come to temperature. Even when you run warm water through it first, there is sometimes enough residual cold to bring the temperature back below 60. A successful Brush clean Cycle will display "Power Switch Off---Unit Cleaned" and the 2 digit green display under the main display will reset to 00. if this happens and you turn the machine back on and you are hit with the same message then you may have an issue with one of your boards.
Aug 02, 2017 | Taylor Ice Cream Makers
My C713 water cooled yogurt machine keeps locking and only works when cleaned but only for a few hours then it locks again. Does anyone know why?
The temperature of the product is too high. If the product either in the cylinders or the hopper goes above safe temperature for too long the freezer will lock until the product is removed and the unit is properly cleaned. I would guess it's the hopper temperature because I think you would notice if the product that's dispensed is above 40 degrees. Soft Serve Parts C713
Aug 01, 2016 | Taylor 2008 C713-27 Soft Serve Ice Cream...
How to recognize why 339 raylor is not giving good product viscosity
If the machine runs and runs and can't satisfy your viscosity setting there is a refrigeration problem. The longer the machine runs the more the product breaks down, so you're problems get worse as the day goes on. It's not uncommon for these machines to lose refrigerant. I would guess that is the issue here.
You will need a refrigeration repair person to put gauges on the machine.
Here is some information I put together about the logic board adjustments on your machine. I think you might find this helpful.
Taylor Softech Control Boards
May 28, 2017 | Taylor Ice Cream Makers
How to find why 339-27 taylor not good product viscosity?
It could be a couple things. The most common is worn down scraper blades. Try new ones first. Worn scraper blades don't scrapers the cylinder walls and the ice cream that's stuck on the walls acts like insulation and it will take a lot longer to freeze this ice cream. If that doesn't solve the problem then you are likely low on refrigerant on that side. Your machine measures the viscosity by reading the amp draw of the beater motor. The harder the ice cream gets, the harder the motor works. If the ice cream isn't getting hard enough because of one of the reasons above, your machine wont shut off.
www.softserveparts.com
May 26, 2017 | Taylor Ice Cream Makers
Will not go down in temp after cleaning inside
I'm not familiar with that model, but in general, if the unit has an internal fan (evaporator fan), it could be stuck or not working. This will not allow proper heat transfer to cool the unit and the box will hang at a certain temp which is not cold enough. Sometimes when a unit is turned off the moisture inside the box can cause rust to form on the fan motor. It could be as simple as accessing the fan, if there is one, turning it manually, and adding a small amount of oil.
Nov 08, 2013 | Master-Bilt Products IHC-27 Ice Cream...
What is the temp for frozen yogurt?
Yogurt should be served between 18-22 degrees F.
Mar 30, 2013 | Ice Cream Makers
Recently bought a used Taylor Shake/Slush Freezer Model 430 to be used for shakes. It was used for aheks in the past and no problems, however, we put it together and the ice cream is too hard. Even...
The Taylor 430 thermistor model has two adjustments a fine adjustment, which is made by turning the knob, and a coarse adjustment that is made by turning the screw in the center of the knob. I suspect you are trying the fine adjustment, which will change the product + or - 2 degrees F. The coarse adjustment will let you set the product temperature between 10 and 30 degrees F.
As far as the clunking, those machines clunk a little. It would do it more if the product was too hard.
You are correct the machine will leak drops into the drip tray, but if it is more than drops, you want to address it. Should be as simple as a new tune up kit.
X39969Tune up kit for most Taylor Slush Machine non Carbonated machines...
If this doesn't help, or if you have any other questions, you can reach me at
Soft Serve Parts Supplies
Mar 15, 2017 | Taylor Ice Cream Makers
My Taylor 754-27 on the right side will stop workng just as the porduct gets up to consistancy. Do you think it is a weak or bad motor. The motor just stops and then when the product starts to warm up I...
Hi Lori and welcome to FixYa. I am Kelly,
If you have someone capable of swapping controllers between units move the controllers side to side by exchanging positions. I think you have a controller problem. Via the viscosity control (soft / hard) it senses amperage of the motor while in use. You either have a bad controller or a bad temp control. If you swap controllers and the problem persists then the temp control is bad. If the symptom changes to the other side then the controller is bad.
Thanks for choosing FixYa,
Kelly
Mar 26, 2011 | Taylor 632-27 Ice Cream Maker
Taylor 754-27 runs good until ice cream is made then trips-not able to restart in auto or wash-able to turn beater with hand-not binding - after ice cream becomes liquid able to start again in auto or...
It is possible that your viscosity is set too cold. You should check the temperature of your product to see if it is too cold. Is the Ice Cream hard? It sounds like maybe the beater overload is tripping. Some of the overloads can reset on their own. If you have and know how to use an ammeter, it would be beneficial to check the amp draw of the beater motor to determine if you are exceeding the overload or not. Ice cream is generally good at a temp between 16 and 20 degrees F. Temps vary with product and product brands. I hope this information helps, it is hard to determine exact problem without being there.
Oct 04, 2010 | Taylor 632-33 Ice Cream Maker
Taylor 150-44 soft-ice machine: auger O-ring and bearing assy.
http://www.taylor-company.com/ There should be parts available,check this link to help locate a parts house near you. I am not sure where they are available in Australia.
Mar 20, 2009 | Ice Cream Makers
Taylor Soft Serve C706-27 Machine Logo
170 people viewed this question
Top Taylor Ice Cream Makers Experts
Dennis Boxerman
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Are you a Taylor Ice Cream Maker Expert? Answer questions, earn points and help others
