Question about Maytag MAH2400A Front Load Washer
Dryer doesn't dry
Siemens 1260
  • maniman May 17, 2014
    the MAH2400A is a washer model so it wont dry anything
Siemens iq 750 keeps stopping after 3/4 mins of drying
Is your water jacket empty? Could be something simple like that.
Aug 07, 2016 | Siemens Dryers
Siemens dryer service centre
Yes, it is true. A Siemens dealer will have one and the price will depend on where you buy it from.
Oct 13, 2013 | Computers & Internet
My dryer will not dry clothes. it doesn't seem to be heating
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
May 15, 2011 | Siemens Dryers
I do not have a manual for the 1260 wash n dry and I have no idea how to make the dryer work It washes fine, just that everything ois still wet. Does it automatically dry or do you need to push a button...
Methinks you could do with a manual now and for the future as I'm sure it would act as translation!
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
You could also try the manufacturer's web site direct.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Apr 20, 2011 | Siemens WD61392GB Front Load Washer /...
How do I turn off the alarm beeper on my WXD 1260
Hi
The sound for program status can be set by pressing and holding the button with a T-Shirt marked on it. Hold the button until a sound emits from it. Wait until the sound level changes to the level you want it at - release the button and the setting will be saved.
Hope this helps. Please remember to rate my answer. Thanks.
Jul 19, 2009 | AT&T Siemens S46 GSM Cellular Phone
I have a Siemens Washer/Dryer WDI 1440. The problem is that when I put it to dry, no heat is produced and my clothes are staying wet. What do I do? Many thanks
take top off. you will see dry manifold running across the top with various stats mounted on it. one of these stats will be resetteble ie with a small knob in middle. press and stat will reset. also check continuity thro the dryer heater and the other stats.
if a resettable stat has popped out, check also for lint blockage in the dryer duct
Nov 17, 2008 | Siemens Dryers
Bosch wvt 1260
dry heater is located under an aluminium housing on top of the machine. take it to bits and easy to fit. however, why do you need a heater? if no heat on dry, cause is probably overheat stat operated
Mar 30, 2007 | Bosch Classixx WVF 2402 Front Load...
Maytag MAH2400A Front Load Washer Logo
20 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
