Question about Summa S75-T - 30in Tangential And Drag Blade Cutter With Friction
Not finishing cuts
My cuts are not meeting up. For example a O will have a gap between the beginning and the end of the cut. I have checked offset and the blade is fairly new. I'm stumped.
    Problem Solver:
  • 5 Answers
If you are using a tangential knife, offset is 0. You can change your user to a new one to have all the parameters correctly tuned. Use only original knifes.
http://www.rotutech.com/en/consumibles/851-cuchilla-estandar-tangencial-de-36-5und.html
Posted on Aug 01, 2015
I have a large gap to seal btwn tile and tub. Any suggestions?
how big is large ?
if it is over 1/2" but under 1" cut a slice of tile to fill the gap
if under 1/2 inch use a silicon sealer ( no more gaps) to fill the space
to get a smooth finish on the sealer use your finger --wet it in water or suitable applicator that is wet with water
once the desired finish is achieved , let it dry and it becomes water resistant
Nov 11, 2016 | Washing Machines
Tip
Temp cut off/cut in
Any thermostat, it's calibrating to cut off at the end of 2nd beginning and cut in 2nd ending of temp.<br /> Ex: In heat mode, If you set @ 68 degree, it will cut off 70 degree beginning and cut in at the end of 66 degree. <br />In cool mode, if you set at 68 C degree it will cut off at the end of 66 and cut in will be at the beginning of 70 degree.<br /><br />
on Jan 10, 2011 | Heating & Cooling
Change plug an won't start
Make sure you have the correct spark plug for your maching. and Make sure the gap is correct on the spark plug. Look in your owners manual for the correct gap. Check inside the spark plug wire end that connects to the spark plug and make sure the metal part is still in there to make the connection to the spark plug.
Jun 10, 2014 | Husqvarna Partner Gas Powered Cut Off Saw...
Not finishing cuts
STANDARD TANG KNIFE 36 5X Rotutech
Mar 24, 2014 | Summa S75-T - 30in Tangential And Drag...
What can i do with kitchen shears?
Kitchen shears are a very useful item to have in a kitchen. They can easily and comfortably substitute a knife in many tasks. For example:
- Cutting fresh herbs and spices
- Cutting the roots off vegetables before using them
- Cutting all kinds of raw pastries (like phyllo) and doughs (pizza, pasta etc)
- Snipping pieces of cheese
- Cutting poultry, meet and fish both raw and cooked (for example cutting off wings, cutting poultry into smaller pieces, cutting scales and finns off fish, cutting rotisserie chicken, cutting open crab legs, trimming fat off meat etc)
- Cutting fruits and dried fruit
Shears are also very useful in a kitchen as normal scissors, to cut string, wrapping paper etc
Oct 17, 2013 | Home
DT92E room stat appears to be very inacurate with its room tempreture, our normal room temp is about 22c we have to set the stat at 25c to get heat and the stat cuts out after a temp rise of 1c
All thermostat is calibrated @ difference of 2 degree.to cut in and cut off.
In heat mode, if you keep 25 and your room temp 23. it will start at the end of 24 or beginning of 25 degree.Cut off also @27 degree beginning. Please check Tips & how to do's in Fixya
Jan 11, 2011 | Honeywell Heating & Cooling
I just got a new heating unit installed. However it runs constantly. If the target temp is 68 degrees it will hit 68 degrees and just keep running. It does the same at 63 degrees. Is this normal?
Dear friend! Any thermostat, it's calibrating to cut off at the end of 2nd beginning and cut in 2nd ending of temp.
Hope it's helpful to you?
Jan 10, 2011 | Intertherm Heating & Cooling
Why is there such a big temperature gap between on-off. room temperature is either hot or cold. thermostat tried in different rooms and varying temperature settings
Normally all thermostat calibrated at the end or beginning of -2 or +2 degree difference.
I fyou set 24 degree for cool, it will cut off at the end of 22 and cut in at the beginning of 26degree
Jan 04, 2011 | Heating & Cooling
Hi there, I have a 80 series 1F87-361 thermostat. My indoor temperatures are consistently reading lower than what what I programmed. For example, I had it set for 22 degrees last night and when I woke up...
I understood from your statement that the sensor bulb is not in position. Check it should facing towards return air. And normally, if you set 20 degree, it will cut off at the end of 18 degree and cut in at the beginning of 22 degree.
Dec 05, 2010 | Heating & Cooling
Summa S75-T - 30in Tangential And Drag Blade Cutter With Friction Logo
1,011 people viewed this question
Top Summa Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Summa Office Equipment and Supply Expert? Answer questions, earn points and help others
