Question about 2005 E350 Diesel Cargo Van
Dashboard fuse location
Dashboard gauges of
  • Ford Master
  • 906 Answers
Check the fuse box, It IS in there, It may be market tail lights as it is the same fuse, So remember if you have no dash lights you also have no tail lights.
Posted on Jan 29, 2015
    Sergeant:
  • Ford Expert
  • 327 Answers
If you don't have the owners manual that came with this vehicle when new (these manuals usually have the fuse box "map" in them), then the best thing to do is check every fuse. Even if it doesn't seem to have relation to the problem. My little car lost turn signals. Checked the fuses. Took it to shop. It was a fuse I didn't check because I thought it had no relation to problem. Car maker decided to have dash/turn signals on fuse marked "meter." Cost me 65.00 to find this out.
Posted on Apr 11, 2014
Where is the fuse for the driver side power window located?
Look up under your driver's side dashboard for the fuse panel check the gauge fuse and the power fuse to see if the fuses are blown, use your owner's manual to indicate where the fuses are located.
Aug 31, 2014 | 2005 Pontiac Vibe
2000 Lexus LS400 Instrument panel fuse
It's more likely a fuse is blown, the tail lights are on the same fuse as the dash illumination, check the tail lights if they are not working replace the fuse marked 'tail' in the fuse panel on the inside at the left side of the dash under the cover. At the same time check the 'gauge' fuse', there is a fuse location diagram on the cover.
Apr 13, 2014 | 2000 Lexus LS 400
Fuse for Dash Board Light and Gauges
Check your Owner's Manual. If your look in the back of the manual, you'll find a diagram which shows each fuse and its location on the fuse block.
Mar 23, 2014 | Covercraft Block-It 200 Custom-Fit Car...
99 ford winstar dashboard stoped working
Check fuses, plug to insturment cluster, or ground location for insturment cluster.
Feb 22, 2013 | Cars & Trucks
2008 COROLLA DASHBOARD FUSE
dash not lighting up is USUALLy an indication of rear tail lights being out, generally brake lights, but not always. Check all lights and replace any burnt out... check gauges then.
Aug 02, 2012 | 2008 Toyota Corolla
Dashboard gauges are not lit? whichn fuse controls this? my gauges and transmission gear lights arent lit. seemingly controlled by dimmer interior switch? is there a fuse i should check and whick one?
most vehicles use the the side light fuse for the gauges so i would check out the dimmer switch -feed in and feed out before you go any further
Jan 07, 2011 | 2001 Nissan Pathfinder
Gauge light does not work
CHECK THE GAUGE FUSE IN THE INTERIOR FUSE BOX LOCATED ON THE DASHBOARD ON THE LEFT OF THE STEERING COLUMN.
Nov 20, 2010 | 2003 Toyota Corolla
1998 Jeep Cherokee, dashboard went out. All
I would check my gauge fuse,look in manule for location
Mar 25, 2010 | 1998 Jeep Cherokee
How do I replace the dashboard light?
if all the dashboard did not turn on, check the fuse for instrument gauges. you have to remove the dashboard to locate the bulbs.
Aug 10, 2009 | 1999 Mitsubishi Galant
Alarm system
I noted the same problem when I pulled one of the 20Amp fuses out of the fuse block. Check your fuse box under the dash (driver's side) and locate the fuse for the speedometer/ dashboard gauges. Worth replacing ($2) as a check even if it looks like it's okay.
Sep 17, 2008 | 1998 Chrysler Town & Country
2005 E350 Diesel Cargo Van Logo
93 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
