Question about Canon PIXMA Office Equipment & Supplies
Installed new cartridges; message continues to say out of ink
MX330 will not acknowledge that cartridges are new. Message U162
  • 128 Answers
We see LOTS of problems with non-Canon ink.. are they Canon brand?
Posted on Apr 03, 2014
SOURCE: Epson rx580 printer
I just started calling Epson's customer service line every time. They always offered to FEDEX new ink. I got tired of waiting for it to come and began returning bad cartridges to office depot where I had bought it and found out that they will take it back if it doesn't work. Now I've decided that some (a lot) of Epson's ink cartridges for the RX580 are bad and that I just have to keep trying until I get ink cartridges that work. I had tried the qtip cleaning, checking the ink/sensor connection, and making sure I had them snapped in tight. I've finally figured out it IS the ink. BTW, I always use the ink Epson reccomends, so it is definately that many of their cartridges are faulty. It's a pain to have to return them but as long as I can return and replace them and eventually have a machine that will print when I need it to, I can live with that.
Posted on Mar 12, 2008
patemi
  • 366 Answers
SOURCE: hp c7180 printer does not recognize new ink cartridge
be sure you removed tapes from cartridge.
Follow the instruction and reinstall new cart.
Posted on Feb 09, 2009
SOURCE: low ink message
just ignore the message and print
if it doesn't print try to dip the lower part of cartridge in warm water, not hot, for five mins and dry it with tissue and try to print
Posted on Mar 06, 2009
CompuFirm
  • 89 Answers
SOURCE: Error message on HP 2800 business inkjet, message reads 1% ink left on brand new cartridge
View the user manual here. http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00449611/c00449611.pdf
go to page 60 and follow the instructions for replacing the ink cartridge, remember to have the printer on when you do.
Then go to page 62 and allign the print head automaticly following the instructions it gives.
This will re-callibrate the ink level on the printer and should read correctly for you.
Thanks
CompuFirm
Posted on May 27, 2009
manuel-d
  • 5 Answers
SOURCE: Canon Pixma ip1900 Printer wont print
i think you need a canon resetter just download it and it will fix your problem. gud luck ellyhill
Posted on Nov 16, 2009
Tip
Canon MP 460 An Error Message Is Displayed On The LCD
If an error message is displayed on the LCD, take the corresponding countermeasure described
below.
Message Action
There are no photos in memory
card.
There are only invalid images on the memory card.
Photo data edited/processed on a computer should be printed from the
computer, not from the camera.
There is no paper. Reload the paper correctly and press [OK].
The paper is jammed. If paper has jammed in the machine, clear the jam, reload the paper in the
machine correctly and then press [OK].
Ink has run out.
U041
Replace the FINE Cartridge, and close the Scanning Unit.
If printing is not finished yet, just press [OK] on the machine to continue
printing in the “no ink” state.
Replace the FINE Cartridge with a new one as soon as possible after
printing finishes. The machine may be damaged if printing is continued
under the ink out condition.
The following ink cartridge cannot
be recognized.
U051
U052
U053
U059
The FINE Cartridge may not be installed properly, or the Cartridge may not
be the compatible with this machine. Install the appropriate FINE
Cartridge. If lines are misaligned or the resulting output is not satisfactory,
carry out the FINE Cartridge Alignment.
Some ink cartridges are not installed
in place.
U075
U076
Confirm that the FINE Cartridges are installed in the appropriate positions.
See “Replacing A FINE Cartridge” on page 75.
The ink absorber is almost full.
Press [OK] to continue printing.
Contact the service center.
The ink absorber is almost full. Printing will no longer be possible once
the ink absorber is full. Contact the service center immediately. Press [OK]
Incompatible device detected. Depending on the model or brand of your device, you may have to select a
print mode compliant with PictBridge before connecting the device.
You may also have to turn ON the device or select Play mode manually
after connecting the device to the machine. Perform the necessary
operations according to the instruction manual supplied with your device.
If the error is still unresolved, there is a possibility that you are using a
digital camera or digital video camcorder that is not supported by this
machine. Use a digital cameras or digital video camcorder compatible with
this machine.
Auto head align has failed. Make sure all required boxes on the head alignment sheet are filled in, and
that the sheet is set in the correct position and orientation on the Platen
Glass.
If the machine is connected to the computer, you can align the FINE
Cartridge using the MP Driver. Follow the procedures described in the
Printer Driver Guide.
The following ink may have run out.
U162
This FINE Cartridge may have previously been used, or the ink may have
run out. The function for detecting the remaining ink level will be disabled
since the remaining ink level cannot be correctly detected. If you want to
continue printing without this function, press [OK]. Canon recommends to
use new genuine Canon Cartridges in order to obtain optimum qualities.
on Dec 08, 2009 | Office Equipment & Supplies
Replaced new color ink and getting a u162 error code on my cannon pixma mx340 wireless office all in one inkjet printer
he ink may have run out. Replacing the ink tank is recommended.U162
The Ink may have run out.
The function for detecting the remaining ink level will be disabled since the ink level cannot be correctly detected.
If you want to continue printing without this function, press the Stop/Reset button for at least 5 seconds.
Canon recommends to use new genuine Canon cartridges in order to obtain optimum qualities.
Please be advised that Canon shall not be liable for any malfunction or trouble caused by continuation of printing under the ink out condition.
NOTE
If the function for detecting the remaining ink level is disabled, the ink cartridge
in grey is displayed in the remaining ink volume screen on the LCD.
Feb 04, 2015 | Cannon Office Equipment & Supplies
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
I have replaced the black in ink in my canon MP470 with a refilled ink cartdige but keep getting a U162 (the ink may have run out, please replace) error message. hoe do i get rid of this meesgae and get...
Pressing the OK button will allow you to continue to print. Since the cartridge has been refilled, the printer ink level monitoring function will not work
Mar 27, 2011 | Canon PIXMA MP470 All-in-One Printer
Oct 24, 2009 | Canon Office Equipment & Supplies
Thanks
CompuFirm
May 27, 2009 | HP Business InkJet 2800 Printer
Error message
try to re-instal the driver or check the cable
Mar 16, 2009 | Office Equipment & Supplies
Canon PIXMA MP450
I had the same problem and spoke to canon australia technician. Any 4 number code means it is a servicable error. 6500 code specifically says take to a service centre...
bugger....but thats what they told me...
Jun 08, 2008 | Canon Pixma MP450 All-In-One InkJet...
171 people viewed this question
old marine
old marine
