Question about Gigabyte Technology gigabyte Ga-78lmt-USB3 Socket Am3/ Amd 760g/ Ddr3/ USB3.0/ A&Gbe/ Microatx Motherboard
Unable to access bios
I am unable to access bios or boot menu. tried changing keyboards but no luck.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Gigabyte Tec... Master
  • 2,226 Answers
You need to go in cmos the del key or f1 or f2 or alt key should get you in if not then clear cmos ok
Posted on Mar 31, 2014
Cant access bios or boot menu on ga-78lmt-usb3. tried changing keyboard but no luck.
Does the board work? Maybe you tried an unsuccessful BIOS upgrade?
How about explaining exactly what happens when you try hitting F2?
Mar 25, 2014 | Gigabyte Technology gigabyte Ga-78lmt-USB3...
Lenovo g500 bios access
Near the power button there is a smaller button. Instead of power press this button and a menu will appear. You just have to choose BIOS Setup or Boot menu if you just want to change the boot order.
Aug 03, 2013 | Lenovo ThinkPad Computers & Internet
Won't read keyboard
usb or ps2 keyboard ? might need to be enabled in BIOS
If you want to use a USB keyboard to access Windows command prompt options, make changes in the BIOS (Basic Input/Output System), or to operate legacy operating systems, you must enable support for the device inside the BIOS.
Shut down the computer and disconnect the USB keyboard. Connect a PS/2 keyboard to the PS/2 connector port on the rear of the computer. Turn on the computer and press the "Delete" key several times as soon as you see the initial boot or company logo screen. Wait for the main BIOS setup screen to appear. Press the right or left arrow keys to move the cursor to the "Advanced" or "Advanced Settings" menu option. Press the "Enter" key. Move the cursor to the "Integrated Peripherals" or "Peripheral Configuration" menu option. Press the "Enter" key. Press the down-arrow key to navigate to the "USB Controllers" option. Press the "+" or "-" key to change the menu option to "Enabled." Move the cursor to the "USB Legacy Support" or "USB Legacy Function" field. Press the "+" key repeatedly until the value option changes to "Enabled." Press the "F10" key to save changes to the BIOS settings and exit the setup utility. Wait until the computer begins to restart and then press the power button and hold it for approximately four or five seconds. The computer shuts down completely. Unplug the PS/2 keyboard from the computer and set it aside. Reconnect the USB keyboard restart the computer. As soon as you see the initial boot screen, tap the "Delete" key several times and wait for the BIOS setup screen to appear. If you are able to access the BIOS setup screen with the USB keyboard, USB support is active in the BIOS.
Feb 15, 2013 | Dell OptiPlex GX110 PC Desktop
Screen is black and only shows cursor blinking in upper left hand corner. Keyboard not responding. Changed the keyboard 3 times.
Start the computer up and repeadetly keep pressing DELETE to access BIOS menu, Once BIOS menu is aquired make sure that BIOS can see your main harddrive, If that checks out then you may need to set your booting device order to boot the harddrive that contains your Operating System. If that still does not work then you may have a bad motherboard.
Jan 04, 2011 | Dell Computers & Internet
I want change my first boot device as cd rom. my system is ibm p3 slot processor
Restart your computer. When you see the first screen you will have 2 options. One is a BIOS setup. It's either F8 or F1. Once you get into your BIOS (screen will be mostly blue). There will be a boot option screen. Make sure you chance the #1 device to CD-Rom.
Sep 22, 2009 | IBM PORTMASTER WITH 512KB 53F2656
I have an Hp Pavillion a1547c and when I boot up the keyboard is unresponsive. I can use esc to get into the boot menu and f1 to enter setup but once those screens load the keyboard is no longer...
Go into the Bios utility and enable all the USB controllers, then save the changes, exit the bios. The computer will restart, plug the keyboard into another USB port and let the computer boot up, wait about 5 minutes before trying to use the keyboard because the drivers maybe trying to install themselves.
If you get no luck you will need a standard PS/2 keyboard, connect that and boot your machine, log into your account and install the drivers for the USB keyboard.
Good luck.
Jul 01, 2009 | HP D8597A Keyboard
I can't install vista any mouse or keyboard detected
Often times this happens when using a USB keyboard / Mouse.
Or when using a USB keyboard through a PS/2 Converter.
Try using a PS/2 Keyboard if available
(Small Round connector with a small amount of pins, similar to a S-Video connector.)
Also. Access your BIOS settings and assure that you have Legacy USB keyboard support.
Depending on your computer the BIOS / Setup Menu / Options Menu/ Etc. can be accessed by pressing the following key during boot:
F1
F2
ESC
DEL
F12
Let us know your setup(KB and Mouse Port type), and if you have any other issues.
Good luck
Apr 14, 2009 | ASUS P5V800-MX Motherboard
Can't start my computer
does the monitor is getting on....do you see anything in the monitor?
Mar 05, 2008 | Computers & Internet
Changing Sony Vaio BIOS
you should be able to exit and save changes, which my guess is you are exiting without saving the changes. theres is a way around this, by pressing either F8, F9, F10, or F12 to access the boot menu, and then you can boot from cd to install your linux operating system
Jan 09, 2008 | Sony VAIO PCV-RX511 PC Desktop
Gigabyte Technology gigabyte Ga-78lmt-USB3 Socket Am3/ Amd 760g/ Ddr3/ USB3.0/ A&Gbe/ Microatx Motherboard Logo
113 people viewed this question
Top Gigabyte Technology Computers & Internet Experts
David Payne
David Payne
Are you a Gigabyte Technology Computer and Internet Expert? Answer questions, earn points and help others
